Question about Bose Lifestyle 48 System
BOSE 48 - Error 801 + 802 - Can I just change Hard Drive, what is the process to format ? In Australia the charge from a 3rd Party Service Centre is in over $400.00 for a 40GB drive.. Would rather replace with SSD. Any help appriciated
  • Anthony Brown May 20, 2011
    Bose indicated (Australia) That they will only sell to service centre and they can format etc..so Im stuck the last price I got was for $443 installed which considering the price of the Hard Drive is ridiculous..
    Any other thought s ??
  • 794 Answers
Hi anthony540,
Unfortunately, the 802 and 801 errors mean irreversible HDD damage. This can happen to any hard disc drive, and there's no way to predict it and no way to fix it from home. Even if you try to replace the hard drive it will not work and will report the same errors since more actions are needed. Obviously you could not format or initialize it with the 'Bose' special stuff. I would highly recommend that you contact Bose because they can repair it for $165 and give a new 1 year warranty. Their technical support number in Australia is 1 800 061 046.
Hope it helps.
Thank you for using FixYa.
Posted on May 18, 2011
How to format transcend 25 storejet 500gb
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you must go back and change the first boot device to your hard drive
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
Jun 27, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
NO FORMAT
what are you trying to Format
hope this helps
Jun 27, 2011 | Computers & Internet
Showing cannot format complete
hope this helps
May 25, 2011 | Computers & Internet
My Bose lifesystem 48 will not start when i start it up error 802 is showing in the display. I can her some nois (tikking) from the harddisk. i am from Norway but my Bose is from USA .I use a transformer...
Purchase a new bose mk4025gas hard drive from impact computers .com for 100 bucks and install, a monkey can take six scews out, pull back up and slide off top remove hard drive from the side of the dvd player, just pull out remove 2 screws from bottom and then pull off ribbon. install back in reverse order.
Dec 22, 2009 | Bose Lifestyle 48 System
Same problem LS 38< two years, error 802, unplug and erase umusic
Sounds like hard drive is failing, 802 and 801 is hard drive problem. i have same problem. only fixable by bose repair man... tryed to change hard drive myself, changed over, looks same as playing but no sound. hope this helps:) common problem with bose other than that i have had not other probs.
Jul 10, 2009 | Bose Lifestyle 48 System
I have a BOSE Lifestyle 48 without sound
Not sure if this is the same problem, but I lost audio from the Stored, TV, Radio and my external speakers, but still had audio for the CD/DVD. I contacted Bose (Australia) support and they talked me through a solution that worked for me.
Remove the power cord from the Media centre, then while holding down the 'All Off' and 'Vol down' buttons on the Media Centre, reconnect the power (and continue to hold the buttons down). After 10 secs, release the buttons and turn the Media centre on. Everything worked fine for me after doing this.
Full marks to Bose for the phone support. I hope this helps someone else.
Jun 24, 2009 | Bose Lifestyle 48 System
Bose lifestyle fault code 802 hi there- i have a bose lifestyle 48 and on display it reads format unsupported when i try to listen to cd's gut not on dvd's - in addition i am unable to store music into the...
Unfortunately, an 802 error is bad. That means hard drive (HDD) failure. This can happen to any hard disc drive, and there's no way to predict it and no way to fix it from home.
If you even try to troubleshoot it (reset etc), you could loose more data (music you've already stored to the system). If you try to access 'stored' music- the error will continue. Also, every time you turn the system off, it checks your HDD, and will probably cause the 802 or 801 errors to display again.
The "Format Unsupported" message may be related, but usually temporary. The 802 (and also 801) errors mean irreversible HDD damage so it doesn't matter.
Call Bose tech support immediately.. They can repair it for $165 and give a new 1 year warranty. And if it's already under warranty they will repair for free. In either case they will replace your HDD with a new one, and transfer any salvaged music files from your existing drive to the new drive.
May 31, 2009 | Bose Lifestyle 48 System
System does not work
try update cd,,,, i might work..
if its hard drive normally says error code, might be somthing like mother board...
Sep 22, 2008 | BOSE48 - Lifestyle 48 Home Entertainment...
Aladinom
Call Bose. It needs a new hard drive. There's a charge if it's out of warrantee, but it is reasonable. Seems like this is a common problem!
Oct 27, 2007 | Bose Lifestyle 48 System
Bose Lifestyle 48 Error code 801
We had this problem. I called Bose, and they reported that the 801 error is a hard drive problem. The unit started squealing while I was on the phone to support, and the guy heard it. Said the hard drive was failing.
$200 to ship the unit to Bose to replace the drive. Wish they had a secret warantee for what seems like a common problem.
Oct 01, 2007 | Bose Lifestyle 48 System
Bose Lifestyle 48 System Logo
116 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
