Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Works except for humming sound on audio
Worked fine until sudden developement of a humming sound on audio. Unplugged all connections to rule out feedback loop. Still humming. Is there a seperate sound board?
I have the same problem> Only lasts for a few minutes, but, it hurts a little and its an incredible annoyance. Besides being annoying I'm afraid the tv is dying soon and the noise its its high pitched scream of pain agony as it slowly finds its way to its final resing place.t
Posted on Nov 07, 2008
    Genius:
  • 2,920 Answers
Sounds like you may have a bad transformer
Posted on Aug 18, 2008
Our gas oven has not worked in over a year. The electric panel was malfunctioning. The burners work fine. We just had some work done and had to turn off the radiators and manually fill the boiler an
The hum may be a b ad regulator in the stove. Pull stove out and see if regulator is humming. It's where the gas line connects to stove.
Maybe the power was interupted to the stove which may have reset power to control board.
Oct 22, 2014 | Kitchen Ranges
Sound Issues with Stereo System
It is more than likely the audio output transistors have shorted out, test equipment will be needed to find out the extent of damage.
Sep 02, 2012 | Audio Players & Recorders
Have an older (6 + Yrs) VX-10A model, that's worked fine up until now. I recently moved, hooked up the same stereo and surround sound speakers, which worked fine, but the subwoofer made a loud hum as...
Disconnect the input and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Mar 03, 2011 | Velodyne VX-10 Subwoofer
Sound doesn't work on Toshiba 36"
Unplugged the TV for 5 minutes and the audio is working now . . . what a pain to have to do this with how complicated theater systems are today!
Sep 02, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
321System No sound just humming with TV connected to Video1 or 2
Hi...
Get new audio cables . It seems there's a broken Ground (shield ) wire somewhere in the cable. NO ground means HUM usually
Dec 30, 2008 | Bose (321GS) System
Olympic InfoGlove Blue
How do you reset this id caller?
Jul 10, 2008 | Olympia InfoGlobe Caller ID
Sony bravia intermittent sound
Yep, same problem with mine. After many trial fixes, I discovered that it's the HDMI connection. I tried two different new HDMI cables in two of HDMI ports on the TV, but still got intermittent sound. The only way I solved it was going to component cables (RGB) with a separate audio cable. Works great now. Other Web sites say that HDMI connections do not always electronically "handshake" well between devices. Not sure how this HDMI problem can be permanently fixed, but using the component connection works fine.
Feb 20, 2008 | Sony BRAVIA KDL52XBR2 Television
No Audio
Check the menus to make sure the audio is not turned off. If that is OK and you have the means, try using other inputs. If it works on some inputs and not on others, that would imply a system control problem, which is unusual for that model.
Oct 15, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Strange audio problems
called a tve repair man tha is a buddy of minr hr had me unplug the tv to reset the ic ship and it worked !!! thanx and good luck
Jun 10, 2007 | RCA F27665 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
112 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
