Question about Troy Bilt Tb70ss Gas Trimmer
Our trimmer won't start. it was working fine, now it won't. we replaced the sparkplug, cleaned the filter, but not having any fuel pumping. how do we fix that problem?
  • Troy Master
  • 7,482 Answers
Hi j k johnson...
Remove your spark plug and check to be sure you are getting fire at the spark plug, if you are then:
Check your fuel filter if you have one, normally they are located in the fuel tank.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please take time to rate me
Posted on May 18, 2011
Engine won't start, doesn't seen to be getting gas.
Potential 'air lock' - try running with out fuel tank cap on
Cap should have a fine breather hole in it
May 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Car cranks but won't start. Already replaced fuel pump & filter
I was told that some fuel pumps do not work more than a day or two, replace the fuel pump again. Mine came with a warrenty
Nov 05, 2012 | 1999 Lincoln Continental
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
Turns over but won't fire
If a starter is able to crank the engine but it won't start you usually have either an electrical or fuel problem. It's also remotely possibly that it's compression.If an engine has proper fuel, spark and compression, it will start when you crank it. So your challange is to find out which part isn't working right. Start with fuel. Spray a little starting fluid into the air intake while someone tries to start the engine. If it starts briefly when you're spraying starting fluid, you probably have a fuel delivery problem. That could be injectors, fuel pump, fuel filter, relay, fuse... who knows what until you check into it.If it doesn't start with starting fluid, check the spark. Pull a plug wire and attach it to a spare sparkplug and set the plug on a solid metal part of the engine. Have a helper crank the engine while you watch the plug. If you have a good spark, it might just be out of timing.In any case, you'll need to start isolating the problem. Find out which part isn't working then you'll know what to replace/repair.
Jun 25, 2012 | Cars & Trucks
97 gmc jimmy cranks but won't start, have replaced everything possible but still won't start, most of the time the brake lights won't work, or the gauges goes crazy. I have changed relays,...
There are two basic reasons for not starting - no spark or no fuel, both of which are controlled by the ECM. You need to check error codes and these items - for the spark, test it at the cylinder 1 sparkplug; for the fuel check the pressure (if too high or low, problem!).
Aug 28, 2017 | 1997 GMC Jimmy
Chevy Malibu 2003 cranks but won't start! I know
You might have a defective fuel tank pressure sensor!
May 05, 2012 | 2003 Chevrolet Malibu
1993 jeep cherokee won't start
MAKE SURE DISTRIBUTOR CAP ,ROTOR, SPARKPLUGS AND WIRES, OKAY IF ALL HAS BEEN REPLACED.IF NOT GETTING SPARK PROBLEM COULD BE IGNITION COIL FAULTY, ASD RELAY FAULTY,DISTRIBUTOR WITH CAMSHAFT SENSOR FAULTY OR YOU HAVE FAULTY PCM. CODE SCAN VECHICLE FOR FAULT CODE, IF YOU ARE GETTING SPARK PROBLEM IN THE FUEL SYSTEM, CHECK FUEL PUMP RELAY AND FUSE MAKE SURE FUEL FILTER BEEN CHANGED AND FUEL PRESSURE IS 39 - 41 PSI. CHECK FOR FUEL SPARK SEE WHAT GOING ON, VECHICLE NEEDS FUEL OR SPARK TO RUN IF ONE NOT WORKING ENGINE WILL NOT START.
Oct 31, 2011 | 1993 Jeep Grand Cherokee
I have a 2001 Chevy Malibu 3.1 Liter. I was driving it last night, and I parked it, everything was fine. 15 minutes later I had to go somewhere, went to fire her up, and it wouldn't start. It's...
Assuming there's enough fuel in the tank - If the fuel filter is extremely clogged - try starting with the fuel cap off so it won't have work against the vacuum in the fuel tank. Fuel caps have breather holes which can be clogged also. The holes release the vacuum in the tank slowly. If it starts ok then, the problem sits in fuel supply - for example the fuel filter.
Smell the exhaust pipe - if it smells strongly like petrol, most likely it's the ignition system requiring service. (sparkplugs, distributer, sparklines)
Jul 01, 2011 | Chevrolet Malibu Cars & Trucks
I have a 25 cc Craftsman weedeater. Using fresh 40:1 gas. I've replaced the fuel lines, cleaned in tank filter, cleaned and rebuilt carb and getting spark, but it still won't start. Also cleaned...
the other possibilities you have is a bad crank seal, or a flywheel came loose and its out of time, will it fire on carb cleaner sprayed in the carb, If it runs for seconds and , then I would say it's not getting fuel, If it only farts once or twice then I would check crank seals cause if they are leaking then your crankcase cannot draw vacumn which in turn causes fuel pump in carb to draw fuel, If you have to check flywheel pull it apart and take flywheel nut off and pull flywheel off and inspect the key that is built into flywheel to see if it is sheared off or messed up, also while checking muffler check for the opening that the mud dobbers havent put mud in muffler pipe, good luck
May 15, 2011 | Craftsman 25cc Gas Line Trimmer
My string trimmer will not start
Possible solutions:
-Kill switch is shorted out-check the wire and connections.
-Buy a new plug.
-Primer bulb needs to be replaced.
-Fuel filter needs to be replaced, and it's located inside the gas tank so it's a bit tricky to replace.
-Try starting it without the air filter attached.
Is it possible an incorrect mix of gas/oil was used (or straight gas) which in turn ruined the motor?
Jul 29, 2009 | Garden
Troy Bilt Tb70ss Gas Trimmer Logo
179 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
