Question about LG WM2487HWMA Front Load Stacked Washer / Dryer
Consistent problems with LG Tromm WM2487HRM PF code - tried unplugging and waiting, replugging... sometimes it runs all the way until the rinse cycle, sometimes it stops in first 5 min, other times half way through a cycle. Any ideas?
    Brigadier General:
  • 3,917 Answers
Hi
The "PF" error code that appears in an LG Tromm washer has experienced a power failure. To clear the error, simply restart the washer cycle.
Also make sure the entire plug in wire connectors are making a positive grab on the main control board and also the unbalanced sensor.
Please check this official website link of LG thoroughly to get a detailed idea about the error:-
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6333
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 18, 2011
LG Tromm wm1814cw LE flashing on digital display,
Here are few troubleshooting tips that i have found. If you acquire further assistance please let me know...
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
Apr 13, 2010 | LG WM1814CW Front Load Washer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
We have an LG Tromm WM2487HWM that has an upside down f and e error code. The machine will sometimes start and then quit after about a minute into the run. Unplugging and replugging in does not seem to...
We have the same problem on our washer - same model as yours. Home Depot has the warranty on this thank goodness we bought it. They replaced the motor and water pump - didn't fix the problem longer than a month. A new repairman has come out and says we need a new heater and thermistor (whatever that is - I checked - not a thermostat but possibly related??) Approx a $300 fix. Good luck.
Jun 20, 2009 | LG Washing Machines
Tromm LG front loader error code
Already answered by an expert :-
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
Thanks.
Jun 17, 2009 | LG WM-2277HW Front Load Washer
Washing machine
Peace,
ngafm at your service!
Lets try this first!
Unplug the washer for 5 minutes and then replug and try it to see if this reboots the system like when a computer acts up, we do the same thing for most electronic devices!
If for some reason this is not helpful, open the user guide and see what the tell you is the meaning of a code"le" on your specific machine!
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Jul 12, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM2487HWMA Front Load Stacked Washer / Dryer Logo
320 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
