Can you tell me where the wireless switch is? I seem to inadvertently disabled my internet wireless network.
  • 111 Answers
If ur using a netbook or laptop most of them or in the top left hand corner with a little antenna icon press that button and it should turn back on the internet
Posted on May 18, 2011
How to turn on your wifi
If you are operating on a laptop, you may have a function key that enables/disables wireless connection. If not, go to your control panel > network and sharing center, and on the left side there should be a link that says "Manage wireless networks". You should find everything you need there.
Aug 25, 2014 | Toshiba Satellite Computers & Internet
Cannot connect to the internet. The device is telling me to Turn On Wireless Capability. But, when I went into the Control Panel, then to Device Mgr and Network adapter - it shows that the Wireless is...
Cindy, you may have inadvertently turned off the wireless receiver on the side of the laptop. look for a switch it will be a slide switch on the side or even a push button on the top and make sure you have it on.
My name is Ed Pinero I am a 10 year IT veteran and field service technician.
Dec 29, 2012 | Computers & Internet
How can i do wireless connection..........................plz tell meeeeeeeeee
First, check if the wireless switch on the computer is ON.
Second, you should see a blue light on thwireless indicator.
Third, press and hold "Fn" key and press "F5" (this enables/disables wireless capability of the computer)
Last, try to detect wireless networks by going to START>CONTROL PANEL>NETWORK AND INTERNET/NETWORK AND SHARING CENTER/NETWORK CONNECTIONS>click on "connect or disconnect" and it will display available networks.
(sorry for the delayed reply)
Oct 02, 2010 | Toshiba Satellite M35X-S149 Notebook
My wireless adapter seems to only work sometimes. The physical switch is switched to on but it still says that my wireless is disabled
Try to enable through network connections.
I have a compaq laptop that was like yours, now it has stopped working, i have to use a usb dongle.
Google your model number to see if its a common problem for you laptop.
Your adapter can be found here
Control Panel\Network and Internet\Network Connections
right click on the adapter and enable
Aug 03, 2010 | Computers & Internet
I have a Toshiba lap top A 105. I have lost my internet
It is possible to disable the wireless connection with the keyboard. Try the combination of Fn and F8 buttons (this is a common Toshiba shortcut) to turn it back on. If that doesn't work, look at your Network Connections (through the Control Panel, assuming a Windows OS, if needed). Check the settings and if it is enabled. In the device manager, check if the wireless adapter has an exclamation point in a yellow triangle. If you have the exclamation point try letting Windows repair the driver. (You may need to access the Toshiba website for the correct driver. Either use a different machine and put the driver on a disc or USB driver or your machine's wired connection.) If that tells you it has no problems, remove the wireless connection (and uninstall the driver) and reboot the computer and it should see new hardware and start reinstalling the driver. Then you can try to establish a new wireless connection.
If the above solutions do not help, it's likely to be a hardware failure. You could get a new wireless adapter (USB or an appropriate card for your laptop add-on card slot), use the wired network (if that has worked), or consider a new machine.
Nov 15, 2009 | Toshiba Satellite A105 Notebook
Where is the switch or function key combination to turn on wireless connection?
It's difficult to tell, but there seems to be a small switch on the front, that may activate the wireless connection. If that isn't it, you can usually access the modems through control panel, under 'network and internet,' and the wireless assistant, or possibly the network and sharing center; if the wireless modem is disabled, right clicking on the icon will usually give you an option to activate it, or you can connect to a network through the network and sharing center, as well as detecting networks, and that will tell you whether or not the thing is working.
Oct 23, 2009 | Acer Aspire 4720 Notebook
Wireless switch is on but wireless indicator isn't light
Either your wireless card is broken and not receiving power, or its disabled from the network connection folder
Mar 12, 2009 | Sony VAIO vGN-NS235J/L Notebook PC
My Laptops Internet switch has stopped working
Then install your USB device with your CD
Then do this
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Nov 17, 2008 | Compaq Presario 700 470024-192 Notebook
NO wireless device
Go an Acer site and download the NIC dirvers and make sure the wireless switch is moved to the on spot. The wireless switch should be on the side or back, marked on & off and a pic of a satlite or dish.
Nov 10, 2008 | Acer (BCM94318MPG) Wireless Adapter
Trying to connect to the internet wirelessly
is it detecting in the device manger if it detects in the device manager it show in the network connections . i think there is a switch for wireless enable or disable on the laptop
Mar 24, 2008 | Fujitsu LifeBook S6231 Notebook
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
