Question about Simrad AP35 GPS Receiver
I AP 35 Setup
I have a ap 35 that will not pass the rudder test.The unit shows correct rudder on the rudder angle function of the autopilot.When the unit hits about 13 degrees of rudder angle it fails in either direction.
  • 2 more comments
  • beanier Aug 14, 2008
    Are you referring to the rudder calibration setup values on page 75 of the manual? If so, the values have been set up and are being stored properly in memory.
    We have a AP 35 Auto pilot that fails the rudder center test We have checked the rudder calibration in memory ok this sysem is driven by solid state relays to a constant running pump Teh rudder indicater works in tha the angle indicator of the auto pilot is showing correct angle
    we have an AP 35 Autopilot the will not pass the rudder center test THE calibration in the memory is correct The rudder feedback works correctly in rudder angle mode
    I have an AP 35 Auto pilot It will not pass the rudderr feed back centering test The rudder feedback reads ok in the rudder angle screen.I already have the manual do u have any suggestions This unit drives solenoids the steering functions ok
  • 1,800 Answers
1. Check all connections.
2. Check the alignment as per the
installation instructions
3. Replace rudder feedback unit
if not work try:
1. Check all connections again
2. Check Rudder FB transm. link.
3. Check Drive unit motor/brushes.
4. Replace junction unit Power PCB.
Posted on Aug 14, 2008
  • 813 Answers
    Master:
  • 521 Answers
I have heard of this problem before from one of my clients. we tried a lot to get it work properly but nothing helped. finally replacing the rudder feed back unit is the only thing which helps in resolving this problem.so i would you to replace the rudder feed back unit either then trying solutions that doesnot help to solve this problem.thanks.
  • tech expert12 Aug 14, 2008
    Did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further.
  • 19,396 Answers
Ensure you are setting correct rudder value.
  • Ginko
    Ginko Aug 14, 2008
    here is
    AP35 Autopilot Instruction Manualfind instructions on how to check rudder values stored on memory in the manual.
  • Ginko
    Ginko Aug 14, 2008
    Yes, if rudder calibration values are OK, then there is a real problem with
    calibration, it can be a mechanical problem or a faulty rudder
    feedback unit. Follow procedure at page 93 of user manual :
    to troubleshoot the error, if you cannot get rid of the error message
    you may have to replace the rudder feedback unit or to have the unit
    inspected by a technician.
Problem: Autopilot does not engage. This is a new problem as it was working quite recently. Model: Simrad NSE8/AP24 with AC42 Autopilot Computer. Attempts to engage the autopilot result in an...
jimtippettau:
Which drive are you using with the AP24, is it just a hydraulic pump on a powerboat, like our RPU80, or is it a hydraulic linear drive (like our HLD-2000) or draglink drive (like our DD-15) on a sailboat?
Mar 24, 2011 | Simrad AP24 AUTOPILOT DISPLAY UNIT
MY SIMRAD AUTO pilot is telling me rudder error what is the problem is it the linear feed back cylinder
Has it ever worked?
What has changed?
Is it the a "pole/linear" or a "rotary" FB unit?
Out of the 5 basic parts of the AP system, the RFB is the most replaced due to the environment (Splash, heat, vibration, mech movemnet).
"Rudder feedback error"
does not see the RFB at all.
check the connections in the J-box first.
you should be able to manually turn your wheel and see the RFB indicator change on the control head.
"rudder responce error"
does not see the RFB move when the AP is given a command.
then check physical connections.
could be loose, could be backward?
Nov 28, 2010 | Simrad Lf3000 Linear Feedback 20188074...
MOT POW SWAPPED, this is the message which appear just like that. the autopilot is working last 5 years, i have checked the wires connections, all is set as the diagram. one thing: my rudder has some...
Check if rudder reference unit is installed as before ,it seems that the pilot sense that the rudder is turning the wrong way. check when giving +10 command the
rudder turns to increase the heading,if yes, it could be the wiring of the rudder reference unit or it was installed the wrong way after service on the rudder.
Is rudder position indicating correctly?
Jun 24, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
Simrad AP 11 Autopilot control head
I happen to have an ap11 head unit in good condition, please contact me.
Oct 28, 2009 | Simrad Boating
Autopilot shows "no rudref"
The rudder sensor works like a light dimmer, so you get 5V and ground on the outside two connections and a varying voltage between about 1 and 4 volts depending on rudder position
847-746-0100 www.technicalmarine.com
Jul 07, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
Linear rudder refernce Furuno 500 auto pilot will not pass test?
light on board is probably normal no, this is an inductive pickup, can not test with ohmeter, sorry. Test with display, observing rudder angle display. Do rudder setup repeatedly until it works, it is a little fussy for placement and clearance but patience and the correct "bracketry" will make this pilot perform great.
Apr 06, 2009 | Furuno Navpilot 500 Navigational Autopilot...
Raymarine autopilot swings hard over immediatly i select auto
CHECK RUDDER REFERENCE UNIT FOR CONTINUITY(IT IS A POTMETER) CHECK IF MOTOR IS RUNNING IN THE CORRECT DIRECTION ,CHECK CONNECTION OF RUDDER REF UNIT.
Apr 04, 2009 | Raymarine St8002 Smartpilot Autopilot...
St6000
The linear drive should have an adjustment screw on the arm so that it can be adjusted to show when the rudders are central. you will need to centre upm the rudders then loosen the screw and adjust until the guage shows the centre position. May take some fiddling to get right cause sometimes when you centre it the guage won't read correctly in the port or starbord directions (won't go all the way over). May need to re-position the whole unit.
Sep 02, 2008 | Raymarine Smartpilot Autopilot St6002 S1g...
AP35 Autopilot
Yep, if rudder calibration values are OK, then there is a real problem with calibration, it can be a mechanical problem or a faulty rudder feedback unit. Follow procedure at page 93 of user manual :
AP35 Autopilot Instruction Manualto troubleshoot the error, if you cannot get rid of the error message you may have to replace the rudder feedback unit or to have the unit inspected by a technician.
Aug 14, 2008 | Simrad AP35 GPS Receiver
Simrad AP35 GPS Receiver Logo
213 people viewed this question
Top Simrad GPS Experts
Will Halftowaite
Are you a Simrad GPS Expert? Answer questions, earn points and help others
