Question about Home
The unit said the wateur is at105 and the real temperature was at 90 what part is broken and where i can find them
  • 43,501 Answers
The problem part would be either the temperature sensor or the control board, but i need to know make and model of what you have to be able to tell you where to get parts from...
heatman101
Posted on May 18, 2011
I have a 2003 Nissan Maxima SE. Occasionally, the ABS activates during times where conditions don't warrant. Sometimes downhill, coming to a stop on flat, dry surfaces, etc. No real pattern.
Broken/damaged wiring,most likely at one of the front wheels.
90% chance broken wire.
5% chance ABS unit.
5% chance pickup sensor at one of the wheels.
Plug it into a scanner and check feed at every wheel while flexing and pulling on the ABS wiring at each wheel.
Apr 08, 2017 | 2003 Nissan Maxima
How do I fix support code 6000?
Code
6000
Description
Broken fuser heater wire (main)
When the fuser thermistor 1 reaches primary stable temperature after a warm-up start and the fuser thermistor 2 is less than 90 ° C/194 °F.
Causes
Fuser unit. Main/Engine PWB. Power source PWB. Fuser heater.
Jul 20, 2016 | Office Equipment & Supplies
My temp gadge isnt working. I changed the sencer and checked feweses what else can it be?
temp gauges work from a temperature sender unit which is different to a temperature sensor unit
you probably change the wrong sender.
Aug 31, 2014 | Crown Jeep Cherokee 96 95 94 93 92 91 90...
I followed the instructions to a T. I turned my iHeater on using the--O switch located on the back. I adjusted the desired room temperature to 74 degrees. I adjusted the room size to Large. The iHeater...
I would read the customer reviews on this product , looks like nearly 70% of consumers are less than happy with this unit.
1500 watts is the units peak output, and drops to around 600 as it warms up. My hair blower puts out more power.
1500 watts is LESS than the output of a small element on your stove top. The real measure of heat is not watts, its BTUs and btus from gas are much cheaper than they are from electricity.
Nov 12, 2013 | IHeater 1500 Advanced Infrared Heater...
Km2030 showing code c610
C610 Broken fixing heater wire
• Warm-up does not end within 90 s.
• The secondary stabilization fixing
temperature drops to 100°C/212°F or
below.
• The fixing temperature remains below
40°C/104°F for 7 s or longer after the
fixing heaters have been turned on.
Causes
  • Fixing heater installed incorrectly (Check and reinstall if necessary.)
  • Broken fixing heater wire. (Check for continuity. If none, replace fixing heater.)
  • Poor contact in the fixing unit thermistor connector terminals.(Check the connection of connector CN12 on the main PCB and the continuity across the connector terminals.Remedy or replace if necessary.)
  • Broken fixing unit thermistor wire.(Measure the resistance. If it is ∞ ?, replace
    the fixing unit thermistor.)
  • Fixing unit thermistor installed incorrectly.(Check and reinstall if necessary.)
  • Fixing unit thermostat triggered.(Check for continuity. If none, replace the
    fixing unit thermostat. Check the operation of the cooling fan and repair if necessary.)
Jul 09, 2011 | Kyocera KM-1505 Copier
Why does my temperature gage go over half when i drive with the ac on in a 90 degree climate? when i dont have the ac on, it stays on half. i had the radiator and engine flushed out and i'm using the...
A/C increases Engine Temp in two ways.
1, extra 2-6hp load on engine.
2, hot condenser in front of radiator heating air going through cooling system.
A small difference in engine temp can be expected, but if the car is running hot get it sorted out.
Oct 07, 2017 | Chevrolet TrailBlazer Cars & Trucks
Looking for freon capacity for 5 ton goodman package unit, cannot read serial or model number.. unit is 1998-2000 model ,, we just replaced the accumulator and we are not sure how much freon to put in.....
check low side which is the bigger of the two, make sure you tighten the hose good. your reading should be 65 psig.If not add refrigerant/r22 . if r410a 110 to 115.
Apr 14, 2010 | Goodman GPC1342H21A Air Conditioner
MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
Apr 09, 2010 | Copystar CS-1620 Copier
Does not heat real hot or cool real cold . dometic duotherm penguin markings on 85 or so unit
Heat real hot? Is this a heat pump or do you have a heat strip installed. Get a regular thermometer and put it in the outgoing vents of the unit. Register the temperature there and then the outside temp. If it is cooling at 17 to 23 degrees below ambient temperature, the manufacturer says this is fine. Try cleaning the condenser out on the top of the rv. Gently hose the rear condenser out until all the dirt and grime is removed the unit. Try cooling again and see if it is better.
Jul 04, 2009 | Dometic Rooftop RV Air Conditioner
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
