Question about Steamist SM-46 4600
I Have the SM-46 model,and when I press the start/stop button I can hear the generator start but no steam comes out, just cold water.I've noticed this happening recently,the system work fine but now I don't know what the problem is. I hope to hear from you soon, Thank You Jerry
  • 43,501 Answers
Hi Jerry,
Most likely your problem is that the heating elements are burnt out... the water runs through but it is not being heated to turn it to steam....
To check it out for sure some testing should be done on the elements to see if they have continuity. and OHM meter can be used to do this.
There also looks like there is a circuit board with relays that could be a problem, but if you are hearing it kick in then I think the relays are pulling in but the heating elements are bad...
heatman101
Posted on May 18, 2011
The iron has been all descaled, however we cannot get any steam when pressing the button. It is a Tefal express generator model 3 years old.
Once you have descaled the boiler and refilled your frontpiece of the iron itself (hopefully with distilled water - any supermarket) you press the "reset"/ "restart" button on the back end of the steam generating unit. When the water is hot enough press steam button & turbo button a few times - WARNING: make sure iron is facing downwards and cover ironing board with old rag because initially brown steam splatter will come out on first few steam releases.
Feb 14, 2015 | Tefal Irons
Mr Steam MS Super-1 kW: 10 doesn't generate steam
the first thing the generator should do when you hit the on button is fill. You will hear the water entering the tank. Once the water stops it indicates that the water has reached the water satisfied level, after which you should hear a loud click(your contactor engaging for the heat cycle, newer units will have all three light on the side lit). After this point is you aren't getting any steam after 5 minutes it probably means your heating element may be damaged. It would be best to remove the element at this point from the left side of the unit via 6 bolts and 2 wire leads. Any physical damage on the element such as a pinhole pop, burn mark, melting, or scar will surely prevent the element from heating
Jan 10, 2014 | Mr Steam Electrical Supplies
SM-9-901 Generator Steam Shower
There are three things that affect this:
1. Incoming water temp.
2. Incoming water volume.
3.Temp of the device.
There are some other minute things like humitidty and altitude too.
Jul 21, 2013 | Steamist SM-9-901 Generator Steam Shower
The iron heats up, but when the steam generator button is pressed no steam gets through at all.
Chemicals and minerals in the water have probably clogged the vents. Empty the water. Pour 1/2 cup WHITE vinegar into the reservoir. Turn on your iron and let it heat. Then press the steam generator button several times until the vinegar is gone. Unplug the iron. As it is cooling, take acotton swab and gently wipe the surface of the vents. You can probe GENTLY with the swab, but don't push it into the vent or the cotton head may get stuck.
As you're pressing the steam button, keep the iron in the ironing position, not standing. If the vinegar just will not come out of the vents, use a wooden toothpick to loosen the build up.
This always works well for me and I hope it does for you.
If so, please come back to Fixya and rate my advice!
Jul 20, 2011 | Russell Hobbs 13153 Iron
I have a Bionaire Steam Mop, Model SM-02. The water appears to be heating up, but no steam comes out. It was purchased at Macy's last spring for limited use in a summer cottage. So, it's less than...
Solition: 1 tbsp of vinegar in the 1 cup of water added to mop reservoir
I purchased my Bionaire steam mop in Nov. 2010 but did not try it out until just recently (Mar. 2011) - and had the exact same problem as you... green light on, base feels warm, sounds like it's working, but no steam coming out.
I called Bionaire customer service and the lady there told me to try adding 1 tablespoon of vinegar to the 1 cup of water that you put in the mop. Then she said to leave the mop plugged-in (but not switched on) for about 30 minutes; so the green light is on; then to turn the switch to "on". I did this and, when I switched it on, it still did not produce steam. In frustration, I unplugged it and left the mop (with the water/vinegar mixture still in it) sitting upright for two days. After the two days, I was just about to empty the mixture out of the mop and thought I would try it one more time... and IT WORKED!!!
I hope this solution works for you, too!
Nov 02, 2010 | Kitchen Ranges
Need manual for swan steam generater iron model s15040
you have probably solved this by now but
I just got the same model new
switch on instructions as follows
press and HOLD the POWER button for 3 seconds to switch the unit on
once temperature has been reached, press and HOLD the steam button on top of the iron for up to 20 seconds
this will prime the steam pump and only has to be done once for each ironing session
the pump noise will stop once it has been primed with water
hope this helps if still needed
if you need the user guide, let me know, I'll scan it for you
Wendy
Jun 29, 2009 | Black & Decker Steam Generator SG200 Iron
Tefal express
The rumbling noise is the steam generator working - make sure the water reservoir is full and press the on button. Inside the machine will be doing its stuff and generating steam - this is the noise that you are hearing and when you press the release switch (normally under the handle of the iron) then the steam will be expelled. The noiose comes on and off as it is making more steam - this is normal. I use ordinary tap water but don't have hard water so have no problems - also make sure you empty out the base occassionally - should be a large pressure screw behind the cable holder - make sure iron is off and cold before doing this and then shake it out and residue bits will come out - then flush out with water. These are brilliant to use and you will wonder how you managed before having this - Happy ironing.
Aug 23, 2008 | Irons
Tefal Steam Generator Model 2911
NO THERMOSTART LIGHT,BUT THE WARNING LIGHT COMES ON
Jan 28, 2008 | Tefal Ultraglide 1549 Iron
Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Nov 12, 2007 | Tefal Ultraglide 1549 Iron
My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Nov 08, 2006 | Tefal Ultraglide 1549 Iron
Steamist SM-46 4600 Logo
202 people viewed this question
Top Steamist Electrical Supplies Experts
ray gallant
Tom Chichester
Are you a Steamist Electrical Supply Expert? Answer questions, earn points and help others
