I have a toshiba 2060 copier and need replacement glass
  • 60 Answers
U can make another one but the same size and thickness
Posted on May 23, 2011
My toshiba 2060 copier easy printing but print paper some line missing please or broken,please solved my prob.
if white lines appear in your toshiba 2060 inaccuracies.
almbres replace the corona charging and transfer, do not forget to check the development unit if turevelador is too old replace
Feb 25, 2015 | Toshiba 2060 Copier
My company keeps their copier till it absolutely dies. The top lid/cover needs to be replaced. Where can I find this replacement part?
Depending on what part is bad or broken, you can get your parts from precisionroller.com
Over to the upper right is a search box. Just put in toshiba 2060 platen cover and you will get the cover and the cushion. If you Hinge is broken which is more common just search for Toshiba 2060 Hinge and you will find those.
Good Luck and Thank You for using Fixya.
Sep 02, 2010 | Toshiba 2060 Copier
I have a Toshiba 2060. Runs great except for one issue. The cartridge has the paper oriented landscape with the label LTR. When I copy using the eith the ADF or platen glass and the paper is also...
As far as I know the Toshiba 2060 does not have an auto rotate function. This means that whatever drawer you pick to copy from is what the scanner will scan. To change which way you copy your sheets you will have to change the physical size of the drawer to copy the other way.
Aug 31, 2010 | Toshiba 2060 Copier
Plz help me we have a toshiba 2060 its need a user code
have you checked out the site Toshiba Copier Parts they seem to have everything for your unit.
Copier Parts In Stock 800-634-9329
Wish you well ; they seem friendly. Asking a question will not get you shot.
Aug 12, 2010 | Toshiba 2060 Copier
Copies come out with gray streaks all the way through the entire page
if you are copying through the feeder check the small glass under the lid has not got any typex or ink stuck to it you check by placing a copy on the glass under the lid and do a copy here.. if no streaks apear then check the glass area.. also if you are printing to it and no streaks appear this area is the cause.. if it happens on teh print side too then you have a drum /dev wear issue and it may need replacing.
Jul 12, 2010 | Toshiba 2060 Copier
Can you get an adaptor for a usb port to print from your computer? Also does this scan from computer? Renee' Weiss 865-680-5564 realtyplus.renee@live.com
If you are refering to a Toshiba 2060 being able to print or scan....the answer is no. Toshiba 2060 is an analog copier.
Oct 13, 2009 | Toshiba 2060 Copier
Have toshiba 2060 copies are coming out with gray and blk stripe
Hello sir; Everything you can clean but drum, that's most sensity part, UNTOUCHABLE , I believed you damaged the drum already, go change one meanwhile change cleaning blade too.
Mar 09, 2009 | Toshiba 2060 Copier
Leaving a black line at the top of the page
make sure paper guides are secure other then that could b dirty optics (mirrors under the glass) or drum / fusing unit
Feb 26, 2009 | Toshiba 2060 Copier
Toshiba 2060 marks on papaer
There is no such paper for copiers that I know of in 18 years. What you can do is try to run some blank pages throw the copier. This can tell 2 things if the line gets lighter in may be in the fixing ***'y and the upper fusing roller is shoot, needs to be replaced and or if it dose not clear up you may need a cleaning blade for the drum(OPC) and or the drum and blade as a set. It depends on how old the parts are? You may need to replace all 3 items and a general cleaning. Here is a idea for you are you running LTR or LTR-R you may be able to switch the paper arould to avoid the line all togather. Good Luck.... You may need a service call on the copier. With the age of the copier I might just go with the cheap fix first.
Mar 12, 2008 | Toshiba 2060 Copier
12 people viewed this question
k24674
jasbo
jasbo
