Question about Vizio L32 32 in. LCD HDTV
My vizio changer hard to chg channels have to push hard and move changer around to change channels. I put new batts.still does it. been like that for awhile
    Problem Solver:
  • 17 Answers
Some liquid may have been spilled onto this remote. As the liquid dries, a film is left on the circuit board inside.
Carefully take the remote apart and clean the circuit board with rubbing alcohol.
Take the rubber membrane that has the remote buttons on it, and clean the back side that touches the circuit board when you press a button.
Allow everything to dry completely and put the remote back together.
Posted on May 19, 2011
My 42" Vizio TV turns on and says No Signal, then
push INPUT on remote, select the input source you want, keep changing channel to find a exist channel.
Mar 25, 2011 | Vizio 42 in. LCD TV
My cell get heated when i put charge batt chg circuit of cell isnot functioning i get batt chg from universal charger nokia1100
Usually it is the battery hat is becoming old enough to internally short and this will cause it to work poorly and not ever fully charge, and get warmer than normal or hot when attempting to charge for more than 1/2 hour. Sometimes the chargr can go bad and over charge, thus making the battery too warm. if you have a car cell phone charger that plugs into cigarette lighter outlet , you can atach this and see if battery gets too warm, but these chargers usually charge faster than electric plug-in type, so expect some warmth within 20 minutes, but again if too warm than you know itis the battery. For these unnits batteries are not expensive.
Apr 28, 2010 | Nokia 1100
Car wont start when it gets cold. all ready changer batter this year and last also tail lights dont work changed bulbs
has car been in a damp, wet or coastal enviroment for any length of time,may be electrical ground issues, make sure you have a good engine to body ground strap,turn everything off in car,put your hands around the pos and neg batt. cables,have a friend turn the motor over for 5sec, if either cable gets warm, replace it, if the neg gets worm, hook a jumper cable from batt. to engine block, try again, good luck
Feb 01, 2010 | 2004 Saturn ION
Ch setup on a vizio tv.
( FOR VIZIO TV MODEL VO47L )
Press menu on the remote,
then go to the icon that says TV,
then press down on the remote to change,
"Tuner Mode" for Cable or Antenna.
"Auto Search" for auto search channels
"Skip Channels" for removing the unwanted channels.
If you need a copy of your manual, go here:
http://www.vizio.com/downloads.aspx
May 23, 2009 | Vizio VO47L 47 in. LCD TV
Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
2003 Yamaha R1 not charging
Stupid Question but are all your wires clean and tight connections? Also make sure your batt ground is good too. R1's can be picky like that.
Sincerely,
JC
Nov 15, 2008 | 2003 Yamaha YZF-R1
Keeps shutting down.
The solution is found! There's no need to format your HDD
So.
- Unplug the battery;
- Press and hold the reset button for 20-25 sec;
- Put the battery back to it's place;
- Charge your device (when you plug the cable in, it turns on (note that a blinking lightning icon appears on the charging indicator), then it turns off with it's "shutting down" message, dont pay attention on this, just let it charge for about 10-15 minutes (note that the CHG bulb won't be lit));
- Turn on your device. The CHG bulb is lit, Archos doesn't shut down
- Enjoy
Jan 08, 2008 | Archos 504 500870 Digital Media Player
Vizio L32 32 in. LCD HDTV Logo
65 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
