Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Describe how to change printer to print only black from my computer. I am out of color ink and don't know how to change the settings from my computer.
  • Kodak Master
  • 4,338 Answers
Unfortunately, you need both ink cartridges to print with this printer.
you can print grayscale (black/white) by:
This for XP:
Start
Settings
Printers and faxes
Right click the printer icon an select printer preferences
Click the color tab and select grayscale
Windows 7:
Start
Devices and Printers
Select printer preferences
Select features tab
Scroll down and add a dot to grayscale
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on May 18, 2011
Why is my black ink not printing
Hi Colleen,
Try this > open a document (from the computer) and select print from the menu,
- In the print screen window select 'properties' Or 'Preferences' or 'Properties'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc... , there click 'Ink cartridge settings'.
- A small windows opens, there select black only. See the image
- try printing, if it fails to print, just return the cartridge to the shop and get a genuine branded one. (dont forget to change the 'ink cartridge settings to normal to 'both black and color')
Hope this help, if you are not able to fix it still, then better come to chat here , thanks! 10_22_2011_5_46_32_am.jpg
Oct 22, 2011 | HP Photosmart C6380 All-In-One InkJet...
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
I bought the wrong printer for my needs and the cartridges for my HP Photosmart C309g-m run out when I don't even want color. Is there a way to set permanately, not with every printing secssion to use...
Hi
Yes you can set it to print permanently. You have to go to Printer proprieties and go to color option and choose Gray scale printing only and this will not use the other inks at all but black cartridge only for printing.
Jul 27, 2011 | Office Equipment & Supplies
I have a HP Designjet100 Plus. The black went from ok to light to nothing. I have cleaned the printer head manually and thru the maintainance setting on the machine. Any suggestions? Do i need to buy a new...
You can try to disassemble the printhead and check for contamination.
First remove cap 1
than using a small flat screwdriver disassemble printhead (engagement points 2 and 3)
Warning - a printhead is filled with 8 ml ink
After disassembly - clean the printhead with fluid compatible with pigment ink (for black color) or compatible with water based ink (color printheads)
during reassembly - don't forget to fill the printhead with ink (2/3 of its volume)
May 19, 2011 | HP DesignJet 100 Plus InkJet Printer
I need to print a lot of only black and white documents, I have full cartridges of black ink but the color is empty. For some reason it keeps printing the black off the color cartridge. I need to find out...
Since I don't know what operating system you have on your computer, here are the steps for all Windows operating system from Canon for your printer. If these don't work, let me know but usually once you change the settings for black and white only, it works fine.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#ServiceAndSupport
Apr 16, 2011 | Canon PIXMA MX310 All-In-One Printer
My epson stylus color 400 will not print in black...I have replaced the two ink cartridges...if I type in color it prints in color...if I type with black ink...it does not print...please help
I had the same problem.
Solution: The black don't print in standard resolution (regular paper)
Set your printer in higher quality paper and your black will print.
This is another problem with Epson nx 415..................
Good luck !!
Mar 03, 2011 | Epson Stylus NX400 InkJet Printer
My black ink will not print. Do I have to have
The larger of the two black cartridges is used for text only printing.
The saller cartridge is used for black in graphic images or pictures.
This saves you color ink . It allows you to put the black ink on the image without making the color inks blend the black ink.
Don
Jan 31, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Same problem
HP printers use a little bit of color ink, even if you only print in black. This is done by HP inorder to keep the color printhead jets clear.
You can select "greyscale only" by clicking on [Preferences] and going to the advanced screen. Choose "use greyscale only".
When you print a color page, the printer will only print black/grey. However ... it will still use a tiny bit of each color ink.
Oh, yeah .. they make lots of money, too.
Sep 28, 2009 | HP PSC 950 All-In-One InkJet Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
78 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
