Question about Amana ARB9058C Bottom Freezer Refrigerator
Amana ARB9058CSO defrost system isn't working. I tested the timer and it seems fine. When in defrost mode there is 120V at the heater but no heat is generated, so i assume the heater is dead but can the thermostat have killed it if it never switches to open?
  • Amana Master
  • 2,183 Answers
That's a calrod heater,they hardly ever go bad but it could be bad,try this,it's a good idea to change out the thermostat to while you're in there so do this,shut down the freezer control or unplug the machine,cut the two wires going to the thermostat located on top of the evap coil,wire the two wires together bypassing the thermostat,plug it in and put it in defrost,if the heater gets hot then you know the t-stat was bad and the heater is good,if it's in defrost and the heater doesn't get hot change out the heater and the t-stat and you shouldn't have to worry about either one of them going bad a gain.,also you can look at the t-stat,if it has clear plastic cap on top and it looks popped up on one side,it's bad,you can tell just by looking at the t-stat.hope this helps,when you cut the wires off of the t-stat cut them as close as you can to it so you can connect the new t-stat to the wires,when you get the new one the wire connectors come with the thermostat
Posted on May 18, 2011
My Amana refridgerator does not cool but the freezer works
If you have noticed a rise in temperature in the fridge, and there seems to be fromst building up in the freezer than your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
Sep 07, 2012 | Amana Refrigerators
The refrigerator isn't getting cold, the freezer works fine, but this morning there was a stream of water on the floor. it seems when its hot out is when I have problems with it.
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
Jun 22, 2012 | Amana 22.6 cu. ft. Side-By-Side...
Ice is melting in 14 year old amana refrigerator. Should I look into replacing or calling a repairman?
I would see if the old girl still has a chance at life before replacing it. First, make sure that the condenser grill (under your refrigerator) is not extremely dirty and that the fan is operating. Make sure that you have good air flow from front to back. You would be surprised how much lint, dog hair and lint will accumulate on the inside of the back panel. Clean it out!
If that isn't the case then I would check for ice build up behind the inner panel of the freezer compartment. If there is, then your defrost system is not working and you will need to figure out which component needs to be replaced (defrost heater, defrost thermostat or the defrost timer).
If you do have ice build up then you can defrost the system by unplugging the unit and using a hair dryer to melt the ice, but be ready for the amount of water!
I have a old Amana that I bought in 1983 and it is still working great! They have excellent components that stand the test of time.
Jul 28, 2011 | Amana Refrigerators
The freezer is working but the fridge is not. We unplugged and defrosted it for 24 hr and it was fine for 1 week and now it's doing it again.
Assuming that the fan in the freezer is working, then your auto defrost system has failed- either the timer or the defrost heater assembly(heater and defrost thermostat)
Jul 19, 2011 | Amana ARB190ZCS Bottom Freezer...
I have an Amana 25 Side by Side Refrigerator, approximately 20 + years old. The freezer side doesn't seem to maintain the cold for freezing. I have vacummed and cleaned around the coil, in...
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Jun 20, 2011 | Amana Refrigerators
Automatic defrost not working, but manual is?
Yes if the heater and defrost thermostat are good then the problem is the control board.
Sep 04, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Why is my Amana Fridge (Model number SSD522T) not defrosting and fan only works sometimes?
When the refrigerator is running ( cooling mode ) the defrost timer contacts prevents any power from getting to the defrost heater. When the defrost timer turns off the power to the compressor and fan motor(s) the power is then redirected to the defrost system. The defrost timer motor
Defrost thermostat:
During a defrost cycle, the defrost heater causes the metal alloy in the switch to warm and as it does it curls back and breaks the circuit. As the metal cools, it makes a closed circuit again. A defective thermostat can prevent the defrost heater from coming on or allow it to overheat which could result in heat damage or fire.
The defrost thermostat is located near the defrost heater and is wired in series. It is usually located at the back of a side by side freezer, behind the freezer back wall of a top freezer or under the floor. It will be necessary to remove obstructions such as the contents of the freezer, freezer shelves, icemaker and the inside rear or bottom panel of the freezer. At room temperature the defrost thermostat is an open circuit ( no continuity ) and when cooled down the defrost thermostat closes the circuit ( has full continuity ) to allow the defrost heater to come on.
Defrost timers:
The defrost timer is sometimes found behind the front grill of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector.
Locate the timer switch and turn it clockwise until you hear it click. One click and the refrigerator shuts off = defrost mode, second click the compressor and fans come back on = run/cooling mode.
*Some defrost timers are a constant or continuous run timer, which means when ever the refrigerator is plugged in the defrost timer is powered up and running. Some defrost timers are an accumulative run timer, which means when the refrigerator is off the defrost timer is off and not running, when the refrigerator is running the defrost timer is running. This is also sometimes called a demand defrost. The power for the defrost timer goes through the cold control first on an accumulative defrost system. The timers are often the same but will be wired differently to get the different operations.
Defrost heater:
Test the heating element for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading somewhere between zero and infinity. Because of the number of different elements we cannot tell what your reading should be, but we can be certain of what it shouldn't be. If the reading is zero or infinity the heating element is definitely bad and should be replaced. Proper power ( careful!! ) to the heating element ( 110-120 volts AC ) and the defrost heater does not come on = bad defrost heater.
Jan 06, 2009 | Refrigerators
Defrost heater wont heat up
so you seems to have done your homework. all the inputs are great.
you said you have 206 volts at the heater connection prior to connecting the heater.
and would become zero once the heater is connected.
so you have a loose connection from the timer to the defrost thermostat then to the heater.
does the defrost thermostat you are talking about is the same as the bi-metal that we used to refer in our technical language.( it is the part that would open up as the temperature inside the evaporator rises to a certain level.)
because if you are referring to the fridge thermostat which controls the compressor. ( this is also 0 ohm when closed), then the problem could be in your bi-metal.
this is the part in between the timer and the defrost heater.
it terminates the power once the temperature of the evaporator coil is about 5 degrees Celsius.
here's what you can do.
run the fridge for a day ( so that we would be sure that the bi-metal is close) then put the heater in place, turn the timer to heating mode by turning it slowly.
then place the test leads across the bi-metal, if you can measure 220 volts then that is the problem.
it is not shorting out even with a freezing temperature. you can further test the system by putting a jumper wire between the bi-metal and you heater should be heating up now.
tnx 4 using fixya,
drcool
Oct 31, 2008 | Refrigerators
Amana side by freezer fan frozen will not run
Fan not operating could be caused by the excess frost buildup in the freezer coil. Defrost problems are related to a failure of the timer, heater, or defrost thermostat. Locate the timer and rotate the clutch head screw clockwise until you hear one audible click. That puts the system into defrost mode. If the system restarts after 18-22 minutes your problem is in the heater circuit. Heater and defrost thermostat is located behind the back wall of the freezer section.
Jun 29, 2008 | Amana ACD2232HR Side by Side Refrigerator
Amana ARB9058C Bottom Freezer Refrigerator Logo
119 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
