Question about Kenmore 74632 Gas Dryer
My dryers smells like its burning and inside when drying gets really too hot. The air vent going outside is clean. I took off the casing and cleaned the inside of the dryer. The belt seems like its ok. Help!
    Problem Solver:
  • 23 Answers
Lint burns quickly and rarely holds a flame long enough to cause a fire hazard. Metal burning would probably indicate friction on spinning metal, like the motor shaft, or the drum rollers. Plastic/rubber are usually parts that are intended to wear, and can usually be replaced.
Along with the belt, you should also check the idler pulley that takes up the slack in the belt, as well as any drum rollers or nylon glides on the top of the dryer door where the drum rides. Metal, plastic, and lint have distinct smells, and you should be able to determine which one(s) you have by smell.
Lint is a common burner in dryers, and it seems you've looked in some of the obvious places it can accumulate. When you have the cover off, pay special attention to the burner area, and any ducts from the lint screen area. Also, any gaps in insulation where air flows could cause hot spots in the unit. If you can see the flame while its running, make sure its size is not excessive. Flames should not be too low or too high, and should not escape the burner housing.
If you notice soot buildup, your gas/air mixture is off. If you've switched from natural to bottled gas or vice-versa, you may need to swap the burner orifices to match the different pressures of the gas fuel.
Posted on May 18, 2011
I got a burning smell after I cleaned my dryer from Lint.
I have seen this before, cleaning the actual dryer vent trap out is taking the machine apart, I mean taking the cover off and vacuuming the thing out. Just taking the tube off the bottom that goes outside isn't enough some times. We find change and bolts as well when cleaning it "all the way" usually. It could just be residual dust burning from the heat part as well. How is it drying? If the cloths are getting dry at the right amount of time, then you might be OK.
Dec 11, 2017 | Dryers
My hotpoint electric dryer gets very hot in the back in one spot has turned a brown spot in that area
Hi, the most likely cause is that you need to clean out the vent from the dryer to the outside of the house. First check behind the dryer and make sure that the vent is not crimped, crushed or pinched in any way. If it is then replace the ducting from the dryer to the well. If it is venting poorly then it will get pretty hot, the brown spot may be in relation to the ducting inside the dryer. Turn the dryer on and go outside to where the vent comes out, there a good amount of air coming out. If not, and if the vent goes a long distance through the wall you will need to have a vent cleaning service out. If you are getting strong air outside and the clothes are drying fast then you may have a bad thermostat that is letting the dryer get to hot, in which case you'll need to have a tech out to look at it. Good luck.
Sep 24, 2010 | Hotpoint NWXR473EV Dryer
Ge DRYER dpgt750EC2PL back wall of drum gets very hot. Occassional smell as if something starting to burn. How do I open the top lid to get inside to find out problem
This may sound a bit over simplified but when a dryer starts to get hot inside it is a sign of an airflow problem.
Start with the outside vent flapper. Check to see if there is lint build up on the flapper / louvers.
Pull off the vent hose and check for lint build up. If the vent hose is a flexible plastic hose they have a tendancy to clog with lint in the sprials and then the lint contines to build up until airflow is restricted.
After checking external vents and ducts next remove the lint filter. If you use dryer sheets wash the filter with white vinegar to remove the build up. It may appear clean but the material from the dryer sheets clogs the filters.
In the area around the lint filter check the ducting / air passages for lint build up and clean it.
In the process of all the cleaning do NOT use anything sharp. A vacuum crevice tool and a Looped metal coat hanger do wonders for cleaning assistance.
Before you reconnect the dryer vent try running the dryer with a light load of anything wet to see if it drys properly with the vent disconnected. After that reconnect the vent and repeat the same drying test to see if the drying times are close to the same.
This should solve your hot dryer problem.. If it does not then respond here and we can talk about taking your dryer apart.
Thanks for using FixYa.
Kelly
the air flow out of the dryer it should be a very high volume.
Mar 15, 2010 | GE Profile Harmony DPGT750EC Electric...
My dryer gets hot but does not dry efficiently. Clothes are still very damp after more than 1.5 hours. I noticed that the lint trap is not really gathering any lint.
your problem might be in the actual vent to the outside. If the vent to the outside from the drier has a clog and will need to be cleaned. Without the proper ventallation the clothes will not dry. I suggest pulling the drier out and removeing the vent hose that connects to the outside and clean it. Once this is done you shouldn't have any problems
Hope this helped
Dave
Feb 23, 2010 | Whirlpool LER4634J Electric Dryer
Dyer really hot, not drying clothes
Is the dryer tumbling? If not, you may have a broken belt or some other drive assembly issue.
Also, turn the dryer on and go outside to the vent discharge - you should feel air coming out at a pretty good clip. If not, the vent line is obstructed and will need to be cleaned out.
Jan 07, 2010 | Dryers
My dryer gets really hot to the touch on the outside in the back and the on the top than it do on the inside and i have to dry my clothes several times for the to get dry
your vent duct is probably plugged. Turn on your dryer and go outside and put your hand in front of the vent and check for air movement. If you do not feel any air then you need to clean or replace the vent tube. Do Not use your dryer until you get this fixed it can be a fire hazard. Another thing it could be is one of your breakers needs to be reset.
good luck
Aug 05, 2009 | Dryers
Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Dec 29, 2008 | Dryers
My dryer gets really hot, but the clothes take a long time to dry and it is really humid inside the dryer. Also, there is a weird smell almost like a burning smell.
It sounds like the dryer isn't getting enough airflow, which might mean a clog.
Make sure you clean the lint filter every time. Also, make sure the vent hose isn't kinked or clogged (if you can, remove the vent hose and clean it out.) Also check between where the vent hose connects to a wall or pipe. There could be a lint clog anywhere between the dryer and where the air leaves the house.
Dec 02, 2008 | Dryers
Dryer Top Hot / New Heating Element Smell
Any time you perform work inside a dryer, lint can get kicked around and settle on components. It is common to have a slight burning smell for a day or so. However, your dryer getting too hot to the touch concerns me. Improper air flow is the number one cause of dryer overheating problems. You may have cleaned the lint out of the interior of your dryer, but did you check the air blower and vent duct lines? In addition, was the heating elements actually bad? Or, did you assume it was bad, because your dryer wasn't drying properly? The following link can explain:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. I would recommend you remove the vent hose from the back of the dryer and attempt to dry another load. If the dryer dries more efficiently and the top panel does not get scorching hot to the touch, then you have a vent clog somewhere EXTERNAL to the dryer. If the dryer air flow exiting the dryer is weak and the dryer still gets too hot to the touch, you have a clog INSIDE the dryer.
Follow these steps, first and see what you find. If you verify your ventilation is clear and not kinked or clogged anywhere, then you might assume you have a component malfunction. I would hope to try to save you from purchasing parts you may not need. I hope you find this information helpful. Let me know if you require additional assistance.
PS Make sure you are using semi-rigid (metal type) vent ducting. It is crush resistant, heat resistant, does not kink easily, and resists rodents. It is what most manufacturers recommend. If you haven't replaced the dryer vent in a while, this may be a good time.
Nov 18, 2008 | Dryers
Dryer smelling hot and smoke detector goes off
clean the venting going to the outside and the dryer really ahould be taken apart and delinted to avoid a fire if the unit is older
Mar 21, 2008 | Whirlpool LER5636P Electric Dryer
Kenmore 74632 Gas Dryer Logo
190 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
