Question about Candy CNW136 Front Load Washer/Dryer
Water not pumping out
Can anybody help me. I have a Candy CNW 136. Was working okay till yesterday. Now suddenly it is not pumping water out. The motor makes a usual noise which it use to make while pumping out but not doing its job.
Any help.
Prashant
  • Anonymous Oct 08, 2008
    water not draining out and not spinning
HI
I had a similar problem which I solved by cleaning the filter which had a blockage. It then worked fine. Hope this helps
Jamie B
Posted on Sep 07, 2008
SOURCE:
HI THERE I have a candy aquaviva 800 washing machine and it seems to not want to drain all of a sudden, i have taken out the hose at the back and given a good wiggle and sat with it in a bucket while
Your drain pump is dead. Have a serviceman replace the pump. How old is the unit? If it's old enough that it has the old belt-driven style, have them check to see if the belt is stretched or broken.
Apr 30, 2012 | Washing Machines
Candy washer cwb 741d pump does not work on a brand new washer
Check its plumbed okay hold hose over the sink to check operation of the pump
Feb 27, 2011 | Candy Washing Machines
My Candy C514 Washing Machine stops half way through the cycle and lights flashing.Yesterday mechanic came and checked everything ok Motor, pump and water goes in fine, any idea? What this can be? Many...
first does the water drain in the machine or stays if so it can be your pump that sucks the water out or cloged check, next if its electronical screen it could be screen problem ,or even door lock somtime s pops half way will need to be change ,check step by step,, if helpful plz rate.
Jan 19, 2011 | Candy Washing Machines
Candy CNW 136 washer dryer not spnning
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Candy CNW136 Front Load Washer/Dryer
No pressure at all on pump gauge
Without knowing your pip and valve layout, it is difficult to assess the stiuation, but it sounds to me as if either a valve that lets the water into the filter is shut, or the filter is full of air and needs to be primed. On some models if you loosen the top ring until the water fills the chamber and starts to overflow that takes care of the problem. But if you cannot tell by looking at the layou if a valve that should be open is closed, or don't know how to prime it, don't run the pump until they can come back.
May 31, 2009 | Hayward SAND FILTER, PRO SERIES
No water from screen washer Ford Focus C-Max TDCi 54 reg
washer jets are clear but after the cold weather no water coming out and pump making no noise is pump knackered if so how do u get at it and is it a quick fix
Jan 21, 2009 | 2004 Ford Focus
Candy Aqua 1000
hi there,
try the following, it may help:
Some washing machines allow hot water to enter only during certain cycles. Others intermittently
allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual
if you are unsure about whether the machine is acting abnormally.
If you're sure the machine isn't working the way it used to--or should--try these tests:
* Is the hot water turned on? If not, turn it on.
* Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Oct 21, 2008 | Candy AQW130 Front Load Washer / Dryer
Door lock , wont light up , therefor wont start washing.
Click on "Candy" (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
You can also go to "troubleshooting" above, you are sure to find some solutions. And dont forget to rate me on this great site.
Jan 07, 2008 | Candy CNW136 Front Load Washer/Dryer
Candy CNW136 Front Load Washer/Dryer Logo
188 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
