Question about Excalibur Digital Weather Station 8500
Lost the manual for the digital compass and need it to set the compass
How can I reset jeep compass comput(er) after replacing battery?
is this a compass car?
or are you say fiddling he electronic compass on a grand Cherokee.
or the compass on a compass, OMG.
if fiddling the electronic compass
the operators guide covers that.
lost that.
its here.
2004 and up
http://www.jeep.com/en/owners/manuals/
read the manual first, then ask for help of lost.
it is there, read it.
Feb 16, 2016 | Jeep Cars & Trucks
What is calibrate compass on 2004 Buick Rendezvous
Manual Compass Calibration If the compass appears erratic and the calibration symbol does not appear, you must manually put the compass into the calibration mode. To get into this mode, do the following: 1. Turn the ignition on and cycle the DIC to the compass/temperature mode. 2. Press and hold the SET button for longer than three seconds. ZONE # PRESS & HOLD SET TO CHANGE: This display mode will be displayed when you are manually calibrating the system. The current zone number for compass variance will be displayed in place of the # symbol. Use the SET button to select the zone number from the graphic shown to select the current area of the country that you are driving in. PRESS SET TO CALIBRATE COMPASS: After selecting your zone, press the MODE button and this will be displayed on the DIC. Press the SET button and complete three 360 degree turns in an area free from large metal objects. The following two messages will toggle in the display until you calibrate the compass: • DRIVE VEHICLE IN CIRCLE • CALIBRATING COMPASS When calibration is complete, the display will return to its normal mode. 3-61 info obtained from MANUAL OWL
press the helpful button and follow me on fixya for more tips
Compass Variance Zone Procedure DIC Compass Driver Information Center DIC...
http://www.manuals365.com/swf/buick/2004_buick_rendezvous_owners.html?page=200
http://repair.chiltondiy.com/Buick/Rendezvous/Repair-Manual-Online
http://www.repairservicemanuals.com/Buick
Feb 02, 2016 | Buick Cars & Trucks
What is calibrate compass on 2004 Buick Rendezvous Vous
Compass not working right
Each zone of the United States has a specific zone number that the compass has to be set with..
It depends where you live...Check dealer or owners manual for zone setting...You should have a reset button at dash area....If you ever change battery you will have to reset compass zone normally.....Zone numbers are all single digit I believe.....I am on east coast...S.East...Which is 8 or 9...pending state...................Hope this helps............Metalpoet..........
Apr 17, 2011 | 1996 Nissan Pathfinder
Lost my manual for my TX T3B881. How do I adjust and use the compass?
Hello i Managed to find a PDF Manual for your Timex T3B881. To view you must have Adobe reader installed this can be downloaded from here. The Manual can be downloaded from here.
compass calibration starts on page 8 and compass operation starts on page 12
Mar 06, 2011 | Timex Watches
WS-110 digital compass, instruction manual needed. Lost the owners manual Repalced batteries and need to redue settings.
http://www.dealextreme.com/details.dx/sku.25903
There is a JPG of the manual on this page, Look under "Customer images"
It is not a US version but it works.
Good luck.
Mar 13, 2010 | Exercise & Fitness
How to set the compass on a casio SGW 100
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 24, 2010 | Casio Digital Compass Twin Sensor Sport...
Compass calibration Hummer H2 2005. Compass shows "CAL" sign and the standard procedure described in Owner Manual doesn't help. What else? Thanks!
There is an offset that is used. I need to know what area of the world you live in. Then there is a digit that you set the compass to. and it is then CLOSER to actual.
Sep 01, 2009 | 2005 Hummer H2
Early Warning EW-3400 Radar Detector Digital Compass Calibration??
I looked at another simuilar Detector and read on Digital Compass Calibration and through the process of elimination found that if I Press CITY for 3 sec.'s COMPASS CALIBRATION showed on the display. Then it says TURN YOUR VEHICLE SLOWLY 2 TIMES to CALIBRATE. Then press the CITY button to complete the calibration. Done. It worked my Early Warning EW-3400 Radar Detector's Compass is now Calibrated.
Thanks for asking.
May 11, 2008 | EW3100 Radar Detector
TCM Digital Watch
v:* {behavior:url(#default#VML);}o:* {behavior:url(#default#VML);}w:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Cmpass (COM)
The integrated compass tells you the direction (e.g.SSW for south­southwest) as well as the number of degrees. To determine a direc­tion,hold the watch horizontally with the 12 o'clock position poin­ting in thedirection you want to know.
General information about the compass
The compass always points to the magnetic north pole.Maps are always drawn in alignment with the geographic north pole (verticallyupwards at 90 ). The declination angle denotes the deviation between themagnetic north pole and the geographic north pole. This deviation depends onwhere you are located. To obtain exact results, the declination angle must beentered into the compass.Remember to change the angle when travelling abroad.Within the UKthere is no need to change the angle because deviati­ons are only slight.Overleaf you will find a table showing the declination angles for a number ofcities around the world.A fault has occurred if the display shows"ERR" while taking a direction or calibrating the compass. Thecompass must be re-calibrated (refer to section after next) .
Table of declination angles
Amsterdam 01 W Little Rock 03 E San Francisco 15E Atlanta 04 W Livingston, MT 14 E Seattle 19E Bombay 01 W Munich01 E Shanghai 05W Boston 16 W NewYork City 14 W Toronto 11W Calgary 18 W Orlando 05 W Vancouver 20W Chicago 03 W Oslo 02 W Warsaw 04E Denver 10 E Paris 02 W Washington DC 10W Jerusalem 03 E Prague 02 E London 03 W Rio de Janeiro 21 W
Mar 05, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Excalibur Digital Weather Station 8500 Logo
149 people viewed this question
Top Excalibur Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Excalibur Measuring Tool and Sensor Expert? Answer questions, earn points and help others
