Dear Sir, We have Mimaki JV33-160 We have found a problem on our machine that is "Head memory error" if you put it on. Can you please tell me how to solve this problem
4 Suggested Answers
hattinghbr
  • 214 Answers
SOURCE: backlit print problem on Mimaki JV33
you can also check you feeding compentation.
when you print press fuction. enter and make it higer or lower enter enter
you have to play with it.
Posted on Oct 07, 2011
caroldon
  • 17130 Answers
SOURCE: 1. mimaki jv4-160. during maintaince
The damage to the carriage section can be worse as this might have caused the fault. Now make sure once again that the sensors are connected corrrectly and with the same type.
The printer mechanism must be checked for a free movement as there seems a jamming because the power initiates and cuts off.
Hence the processor is not getting the program executed in time as the power shuts off. Please check the motor drive section , the wires to the motor drive and manually move the mechanism to confirm the free movement without any jamming.
Check on the main board for a possible break or open fusible link to the carriage/motor drive.
Posted on Jan 05, 2011
ablesenov
SOURCE: dear sir, we have Mimaki JV33-160
Myabe this problem for head or FPC?
Posted on Nov 15, 2012
How To Repair Error " Print Unable 4F" in Brother MFC-J415W
Sir/Madam
I suggest You Perform Below mention steps To Fix Your brother Printer Issue,
Step1: To clear the message follow the steps listed below:
  1. Check for foreign objects, such as a paper clip or scrap of paper, inside the machine.
    Unplug the machine from the power outlet and open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
2.If the error continues to appear, the machine may have a mechanical problem.
If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. Please make sure you have followed the instructions in the Step1.
3.If the error still continues to appear, move the print head and examine under the print head.
NOTE: The images shown below are from the representative product and may differ from your Brother machine,but their inner structures are same.
3-1.Disconnect the Brother machine from the poweroutlet.
3-2.Open the scanner cover.
3-3.Check the print head's position.
In the example photo the print head is positioned at the left hand side of the platen area.
If the print head is on the left side, go to step 3-4.
If the print head is on the right side, go to step 3-7.
If you can not find the print head, go to step 3-8.
3-4.Gently move the print head to the center.
3-5.Examine under the print head. If anything is found, remove it. 1b555a0b-2eb3-488c-883c-4c7db77f04ff.gif
Use a flashlight if necessary to check thoroughly.
3-6.Close the cover and reconnect the machine to the power outlet.
If the message continues to appear on the LCD, the machine will require repair.
Please contact Brother Customer Service from "Contact Us".
3-7.If the print head is on the right side.
The print head is positioned at the far right hand side, you cannot move it. The machine has a mechanical malfunction and will require repair.
3-8.If you can not find the print head.
Step2: Check if the machine has faxes in its memory
Note
In order to transfer data from your fax machine to another, you must have the station ID programmed in your fax machine.
1.Transfer the Fax Journal Report
Press Menu/Set or Menu on the Control Panel of the machine.
Press the up or down navigation key until Service appears on the LCD. Then press Menu/Set or Menu.
Press the up or down navigation key until Data Transfer appears on the LCD. Then press Menu/Set or Menu.
Press the up or down navigation key until Report Trans appears on the LCD. Then press Menu/Set or Menu.
The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Black(Mono) Start.
2.Verify and Transfer faxes in memory
Press the up or down navigation key until Fax Transfer appears on the LCD. Then press Menu/Set or Menu.
If there are no faxes saved in memory, NO DATA will appear on the LCD. Continue to Step 3. If faxes are present, the LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the faxes. Press Black(Mono) Start .
3.Reset the machine
After the Fax Journal Report and faxes in memory have been transferred to another fax machine, disconnect the Brother machine from the power source for several minutes and then reconnect it.
If your question was not answered, please check...
How do clear the message Unable to Unable to Chang Brother
Or
If you still need Brother Printer Help Then Follow Us On:
Brother Printer Support
Dec 19, 2012 | Brother Ink for Mfc J415w Printer
I am using fargo direct to card 550 printing machine.In that error displays "HEAD LIFT ERROR". sir how can i solve this problem and also have lots of noise is coming from the printer..please...
In this problem , first check the front side head lift gear and gear belt.
solution : Gear or gear belt may be broken.
by
LAKSHMI KANTH,
CHENNAI.
Aug 02, 2011 | Fargo DTC550 Thermal Card Printer
Sir i am using sandisk 1 gb memory card,which is microSD. i forget the password for that card.sir please give me some help regarding memory card unlock.i am using it on NOKIA 7020; when i am trying to...
Ok , for this do what i say:
1. First of all u should have a file explorer such as FExplorer (If u done have, download it from the net)
2. Install it to your phone memory
3. Now access the c: drive from FExplorer
4. There u will find a file named 'mmcstore'
5. Rename the file to: 'mmcstore.txt'
6. The file will now open in notepad
7. U will get your password written in the notepad file
Nov 18, 2010 | SanDisk 2GB microSD Memory Card
Sir i have dell GX280 system 3.0 GHz optiplex. 1gb ddr2 ram with 80gb sata hard drive. Sir, my problem is this first i brought a system it runs fine but sometimes a day it hangs up. i return this...
Plz check your memory with memtest. It can be downloaded from http://www.memtest.org/download/4.10/memtest86+-4.10.iso.zip .
Unzip the downloaded file and burn the ISO file to a CD and boot your system from the CD. It will check the memory of your system and it will indicate any error replace the memory.
Also check your memory slot is clean .. you can clean your system memory slot using a anti-static brush (you can use a tooth brush if anti-static is not available) and IPA
Sep 12, 2010 | Dell Optiplex GX280 (99301) Motherboard
10.10.00 supply memory error coming on HP Laserjet 5200 Printer.
Dear Sir,
I has change the printer cartridge. After changing the printer cartridge above mentation comming. When I am making printer power on the (10.10.00 supply memory error) display. Please tell me how to solve this problem. Best regards,
Thanking
Ajom Khan Hero
Mobil No.092 5192797.
Al Nahr Co.Ltd
Tripoli - Libya
Jun 17, 2009 | HP Hewlett Packard LaserJet 5200 Printer
Konica 1216 copier makes black dark copies
dear sir i have information P 27 on my konica copier. how do i solve the problem..?
Apr 15, 2008 | Ricoh Aficio 1013F Copier
434 people viewed this question
jasbo
jasbo
