Question about Bernina Activa 140
My bernina activa 240 is knotting below the fabric and I don't really know what to do to fix it.
    Novelist:
  • 233 Answers
What you're getting is called a "bird's nest" and it has happened to everyone who sews (and will, at some point, happen again I'm afraid!). Take courage, it can be solved.
First, are you sewing a really thick fabric or a bunch of layers? If so, this can cause a problem. You may have to go very slowly with the machine and pull the fabric out, put it back in and start sewing where you left off each time you hear the machine start straining. If you're not stitching thick fabric or a lot of layers, try changing the needle. If the needle is even slightly bent, so slight you may not even be able to see it, it can cause problems with the bobbin thread and cause a bird's nest.
Not solving the problem? Let's rethread both the top of the machine AND the bobbin completely. Check and make sure that the thread on your bobbin is wound nice and tight around the bobbin, just as it would look around a spool of thread you just bought at the store. If not, you need to rewind your bobbin. You can always rewind a new bobbin from the old one so that you don't waste the thread.
Still not solving the problem? Take all the fabric out of the machine and look down in the bobbin area while you're turning the machine's wheel by hand. Is the thread looping and catching on something in the bobbin area? CAREFULLY inspect in there (there is delicate plastic that can break if you're too aggressive, so be gentle.) Did something fall in there? Take the top plate off if you need to. Does it look like there's a piece of plastic that's been "bitten" out of the bobbin casing if you have that type of bobbin case? Or is the thread catching on a part of the bobbin casing, no matter what type you have? Then you may need to replace it. They aren't terribly expensive (less than $30), easy to replace yourself, and are usually easy to find online. Do a search on Google using your machine's name and model number (Singer Futura CE-100 and "parts"). A lot of times you can find the casings on eBay, too.
If you need further help, leave me a comment. I check back daily, so I should get back to you within 24 hours. We'll get the problem solved for you and save your sewing sanity.
Posted on May 18, 2011
My fabric is puckering. I have an activa 230. I know it is a tension problem. I can't find my manual so I can't figure out how to fix it. Thank so!
How to Achieve Ideal Sewing Machine Thread Tension Threads
Understanding Thread Tension Threads
Here's the manual:
https://www.bernina.com/en-US/Support-US/Machines/BERNINA-activa/BERNINA-activa-230
Interestingly, I just went through all sorts of gyrations today because the fabric was pulling up like it was being gathered. Turns out after I'd tried nearly everything, the thread had slipped down the thread spool and wrapped around the spool pin. Problem fixed...
Oct 19, 2017 | Sewing Machines
Sews 1/4" and then sews in place
1) remove upper and bottom threads. Try sew without threads.
Is fabric transported corectly?
NO:
- Drop feed dog button is OFF
- Dust under stitch plate
- Transporter malfunction (must be taken for a service to the BERNINA dealer)
YES:
- Upper or bottom thread jammed
- The upper thread tension is too tight.
- Wrong needle used (probably small ...)
Nov 20, 2013 | Bernina Bernette Deco 600
My Bernina Activa 240 won't turn on. I checked the outlets and they are fine. I even plugged it into different outlets hoping for something to work and it didn't. Can I take it apart and fix it...
Likely the problem is a blown fuse in the S-Print (power supply). You must have a grounding wrist strap when working with a Bernina Activa. They are extremely sensitive and can easily destroy the main circuit board if you don't use a wrist strap. You can get one at Radio Shack for less than $5. The power supply is the square 1/3 of the machine on the back on the handwheel side. You can remove the power supply by removing the long torx screw on the rear of the machine and tilting out enough to unplug the connector. Then dismantle the power supply until you can get to the fuse. Test the fuse with a continuity tester. If the fuse is blown, buy an exact fuse. Don not deviate. If the fuse is not blown, you may need a new power supply.
Jun 02, 2011 | Bernina Activa 140
I have a bernina 210 model sewing machine. I'm
#1 Use only Mettler or Gutermann thread. Coats thread is very rough and will pucker the fabric. #2 Make sure that the tensions are balanced. #3 Use the regular zig zag foot. #4 Use a new needle, universal, size 80/12. A blunted point will pucker the fabric.
Is there a way to lower the feed dogs ''a little''?
I thought this was free . . . didn't know I'd be asking to join. So, I called the shop where I purchased the machine. They were able to help me fix the problem.
Nov 12, 2009 | Bernina Artista 180
Bernina Aurora 440 knotting below my fabric and into bobbin area.
Are you sure you have the bobbin the right way round in the holder....when you look at the bobbin and tug the thread, the bobbin should move clockwise.
Pull out the foot pedal and use bsr2 with the start/stop button.
Bring bobbin thread to top of work before starting to sew. This may help knotting problem
May 25, 2009 | Bernina Activa 140
Bernina Activa 240
There is also a tension adjustment on teh bobbin. It's just a little screw. Turn it about 1/4 to 1/2 turn and try again. Adjust as needed a little at a time.
Oct 19, 2008 | Bernina Activa 140
Owners manual
Unfortunately this is a purchase site. The closest I could get would be for an Activa 220 230 240 . You can download the manual.
Check the picture on no. 7 and see if this isn't your machine.
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Bernina.htm
Hope this helps. Luck!
Dec 20, 2007 | Bernina Activa 130
Sewing Machines Logo
203 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
