Question about HP PSC 1410 All-In-One InkJet Printer
SCANNING PROBLEM WHEN I SCAN A DOCUMENT IT COMES UP BLACK . DOES IT SUPPOSE TO LIGHT UP BECAUSE THE ONLY THING LIGHTING UP IS THE BLUE LINE ON THE SCANNER NOTHING ELSE MY E-MAIL IS hoods@cableone.net
  • salahjan99 Apr 18, 2009
    when scanning or photocoping. it print black only. the whole page
:lm
Posted on Aug 22, 2008
Scan and copy produce a black page
Scan head faulty(which is moving while scanning & copying) , replace it..
Nov 16, 2011 | HP Officejet 6500 Wireless All-in-One...
My scanner scans black Does not scan document.
Does the scanning light come on? The light may be burned out. Also Try cleaning the scanning tip.
Jul 17, 2010 | Visioneer RoadWarrior Patriot Handheld...
Blue line down the right side documents
your not getting the cover closed all the way use the scanning software to make the scan go to the border of the paper onlt and then do a view print to be sure it is the correct size.
Nov 13, 2009 | ScanSoft PaperPort Deluxe 9...
Scanning/copying problem (Lexmark 6500 series x6575)
please just you scan the object to resuleasion in and dp is 600 to 12oo select and you scane object and aply print is dark is ok.
Sep 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
Solid black line down the document when scanning
are you using the autofeeder to feed your documents?
if yes, open the top cover and clean both glasses (big and small).
and take the drum out, move the blue panel to clean up your drum.
after that should be working fine.
May 11, 2009 | Brother MFC 7420 All-In-One Laser Printer
When scanning color document, blue tone is present as background shade
Have long experince with PixEdit program using Kodaks. PixEdit usually comes around it after a firmware upgrade on the scanner. Not sure about this specific model but at least OK on other models of Kodak.
Sep 25, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Black line during scanning
Clean the scanner bed with the clean cloth and try to make a copy if it stills as a black line, if your printer is within one year warranty please get it replaced by the company and use this link:
http://support.lexmark.com/static/229-1-0-549.html
May 20, 2008 | Lexmark X5470 All-In-One InkJet Printer
Scanner problem
Try scanning a double sided document in duplex mode. Reverse the page and scan again. Make sure contrast/rightness settings are okay. If one side output is still not okay, then it possible that the lighting has failed. Either loose contact or failure of the lamp. Some scanners have LEDs and some have a lamp.
S. Mohan
Feb 19, 2008 | Office Equipment & Supplies
HP psc 1210 all in one
When you scan a picture or document try placing some white paper over the picture or document AND more importantly, cover the glass in a manner such that you have all the glass covered. That should solve your scanning issue. If it does not solve the problem, write back, including what happened when you tried the suggestion. Like I always say, try the easiest solution first, and then progress to the next step. Good luck. rey
Oct 24, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1410 All-In-One InkJet Printer Logo
76 people viewed this question
Ben Johnson
