Question about Garden
How to use the Stanley FatMax Stud Sensor Detector Finder 400
2 Suggested Answers
  • 2841 Answers
SOURCE: I have a Stanley stud
The 77-110 does not detect electrical wiring. The model 77-720 model does detect electrical wiring but not the 77-110. You must first place the stud finder against the wall, press the button and wait for the light and audio signal to stop. Once this happens the unit is calibrated and while still holding the button down, you then move it across the wall to find the studs. Problem is that this unit is very unreliable and does not work as advertised most of the time. It has a lifetime warranty so my advice is to take it back and get a refund if possible. I have tried many stud finders an most are not reliable and cannot be depended on 100% of the time and this Stanley is one of the worst. The best inexpensive stud finder I have found is the Gardner Bender stud seeker at around $12.
Posted on Sep 20, 2010
Stanley stud finder AC sensor continually beeps on 10mm plasterboard wall
Most stud finders have a sensitivity adjustment that should be carefully adjusted per instruction manual before use.
Failure to do this results in erroneous indications.
If you have adjusted exactly per the instructions with the same result the unit is probably faulty.
Sep 22, 2017 | Stanley Measuring Tools & Sensors
How can I calibrate a FatMax digital level?
Mark, Automatic calibration, check the little pockets on case instructions inside, the instructions show how.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Stanley FatMax Digital level mp4
Stanley fatmax digital level instructions Measuring Tools Measuring Tools
STANLEY HAND TOOLS Measuring Leveling Layout Levels Stanley FatMax Digital...
http://www.microprecision.com/equipment/STANLEY-CALIBRATION.html
Mar 04, 2016 | Measuring Tools & Sensors
Stanley instructions
Try using a magnet instead. Move the magnet back and forth against the wall, slowly... until it sticks to one of the ferrous screws hidden in the sheetrock. These hidden screws are holding the wall board/sheetrock onto a stud.
Magnets! Free stud finder! and no batteries to replace!
Aug 26, 2014 | Stanley 77 500 Intellilaser Pro Stud...
How to use a stud finder
The stud finder works by picking up density of the product it is pressed and slid on..Turn your stud finder on make sure the ok light is on...then slightly press it against the wall or surface you are working with,,then slowly moved it right or left still against the surface. As the finder starts to detect more density "thickness" it will. Glow or beep depending what type you have..It will get brighter,louder or what ever it signals are while crossing the stud beneath the surface..keep moving until it stops then move back
again until it stops.....mark or note the position where the signal starts then find the middle...2x4's are 1 1/2 inches across...so center should be 3/4 of an inch...good luck..
Aug 04, 2014 | Stanley 77-720 Stud Sensor 200
Stanley fatmax s300 manual
Go to http://www.youtube.com/watch?v=QInszVD9WpE&feature=youtu.be - doesn't tell you everything, but better than the manual Stanley ship with the product, which is just a collection of hard to decipher graphics.
Feb 03, 2013 | Stanley Measuring Tools & Sensors
Instruction for Stanley FatMax Stud Sensor Finder 400 (77-730)
Please people dont waste your money but a cheap standard one Stanley 77-730 stud finder is bad does not work at all , miss my old cheapy never failed me
Mar 05, 2012 | Stanley Measuring Tools & Sensors
How do i callibrate a draper 63401 detector.regard.
I have never met a stud finder that needed calibration. They should auto calibrate when you begin to search for a stud. Recalibrating is starting the search again. Start in a different location on the wall to get a different calibration. This particular stud finder has bad reports on amazon.
Jun 11, 2011 | Garden
I have plaster walls in an old house the stud finder just keeps beeping how does this thing work?
Your stud finder keeps beeping because old plaster walls have lath boards behind the plaster that are attached to the studs and running horizontally. Try adjusting the sensitivity of the stud finder by placing it on the wall and turning the sensitivity down until it just stops beeping. Then move it back and forth in a wide enough arc to be sure that you have crossed a stud, turning up the sensitivity ever so slightly until you get a tone when you cross a stud. Hope this works out for you.
May 08, 2011 | Stanley Garden
How to operate the Stanley Stud Finder
Hi Gene,
  • Place the unit flat against the wall.
  • Press and hold the button.
  • The LED will come on for a second or two then go out.
  • Slowly move the unit laterally until the LEDs come on again.
  • When they top out, that is the beginning of the stud.
  • When they start to go back down, that is the end of the stud.
That's about it..
Best regards
Mike
Jun 04, 2010 | Stanley 77 115 Intellisensor Plus Stud...
Garden Logo
957 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
