My iPF8100 cannot do the Adjust Printer-Auto Head adjust-advanced adjust process, the iPF8100 show "Cannot adjust printhead, Press Online to clear the error and readjust printhead" message. Is there anyone who may help?
  • 81 Answers
SOURCE: phaser 8550 error 19,004.40
The printhead was installed in another machine and the codes do not match. You need to manually sync them. Here is the procedure:
Manually synchronize the Printhead and Electronics Module codes.
NOTE: The Printhead and Electronics Module codes should synchronize automatically when a new printhead is installed. If a 19,004.40 error occurs, it is possible that the replacement printhead was previously installed in a different printer. After manually synchronizing the Printhead and Electronics Module codes, be sure to test the new printhead for print quality defects.
To manually synchronize the codes;
1). Power OFF the printer.
2). Disconnect the printer from external devices (A/C power can remain connected).
3). Locate the "Factory Only" port on the electronics module (located between the PS and PE lights (Figure 1).
4). Use a Hard Disk Drive (HDD) jumper (Figure 2) to short the top two pins.
NOTE - If a HDD jumper is not available, use another conductive item, such as a screwdriver, to short the pins. Use caution to avoid contacting the surrounding frame, as this may permanently damage the Electronics Module.
5). With pins shorted, power ON the printer.
6). When printer reaches the mechanical initialization stage of the power on sequence, power the machine back OFF.
7). Remove the HDD jumper.
8). Code should now be synchronized. Power ON machine and verify the 19,004.40 error does not re-occur.
NOTE - If error persists after this procedure, attempt the procedure again, and be sure to allow the printer to complete its BIST and POST test before powering OFF in step 6.
Posted on Jul 23, 2008
SOURCE: Error message: Printhead missing, not installed correctly or has come loose
In regards to the error message with the printhead missing or come loose......I had that issue just shortly after I installed my printer. I was going crazy trying to fix it taking it out and reinstalling which was a pain, removing the cartridges and then the printhead to no avail. Finally I got smart and disconnected the power cord from the printer itself, not directly from the outlet. Once I did that and turned the printer back on the error was gone. It might have been a fluke, but it worked for me, so you might want to try it.
Posted on Aug 30, 2008
IrishDruid
  • 2712 Answers
SOURCE: Lexmark X6570 printer - Cleared
Ok, the paper jam could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
First try a hard reset - unplug printer from power source, wait a minute and replug. If it still does not work, uninstall the driver, reboot PC and reinstall (or download latest version from lexmark.com.
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Posted on Nov 11, 2008
SOURCE: My printer display keep showing " Warning, Ribbon in", cannot print multiple label at a time
i have the same problem , but my printer is ZEBRA S4M ZPL
my solution is:
in your barcode software: change printer settings: 1 and 2
1 . in media setting : change media type --> Thermal transfer
2. in documents options , configuration --> use printer settings
by Lin Yu Hsien
Posted on Dec 10, 2008
psycondric
  • 42 Answers
SOURCE: Display shows "check printhead"
Hello Neil, If the quality of print is fine then i dont think there is a problem with your printer head. It must be some error with the software or some other part in ur printer. Do check the printer for some other faults.
Posted on Jul 08, 2009
HOW TO RESET ERROR E161-403E
  • To enter SERVICE MODE the machine has to be switched OFF. While the machine is off, hold down the sheet or roll feed button and the information button. Keep these pressed and switch the machine on, keeping the buttons pressed until you see an S in the top right-hand corner of the display, then let go of the buttons. You should now be in SERVICE MODE.
first try to print nozzle check in services mode.
Scroll right to the service mode box (rightmost box) and press OK. You should then see the word 'DISPLAY'. Scroll right until you see the choice 'ADJUST' appear. Then scroll down until you see the choice 'NOZZLE 1' appear and press OK. If you haven't already loaded paper, the printer will prompt you to do so and then it will print out the NOZZLE CHECK PATTERN.
check go any nozzle no firing out ink..if ok means printhead problem need replace.
later go to maintenance menu choice replace print head.
then follow their picture image to replace the print head.
May 03, 2016 | Canon imagePROGRAF IPF605 Printer
Dot matrix printer head not properle work head jam problem
check
1- ribbon quality ( it might damaged )
2-Printhead gap - adjust the gap with the scaled arm aside the numbers related to the past thinketh ( no of copies)
3-ribbon mask ( metal plate in front of printhead - might be damaged)
Nov 06, 2014 | Epson LQ-2090 Matrix Printer
My printer prints a blank page what can I do to fix this?
Hi Good day!! Maybe your printer head needs to clean.
Cleaning the printhead
Use one of the following methods to run the printhead-cleaning tool
NOTE: The cleaning process might take several minutes to complete.
Method one: Clean the printhead from the HP All-in-One control panel
Follow these steps to run the printhead-cleaning tool from the product control panel.
1.Load letter, A4, or legal size, unused, plain, white paper into the main input tray.
2.On the product control panel, press the Setup button.
3.Press the Right Arrow button to select Tools , and then press OK .
4.Press the Right Arrow button to select Clean Printhead , and then press OK . The product cleans the printhead.
5.Press the Back button to return to the main screen.
Method two: Clean the printhead using HP Solution Center
Follow these steps to run the printhead-cleaning tool from HP Solution Center, which is a component of the software that shipped with your product.
1. Open HP Solution Center:
Windows XP: Click Start , click All Programs , click HP , and then click HP Solution Center .
Windows Vista: Click the Windows icon, click All Programs , click HP , and then click HP Solution Center .
HP Solution Center opens in a new window.
2.Click Settings, and then click Printer Toolbox . The printer Toolbox opens.
3.Click the Services tab, and then click Clean Printhead .
4.Click Clean to begin the cleaning process, and then follow the on-screen instructions to complete the process. A test page prints after the cleaning process completes.
Oct 17, 2010 | HP Officejet 6500 Wireless All-in-One...
Installed a new printhead. It worked but I tried to align it and got it to the point where it doesn't print at all. Is there a reference point to start over on the head alignment?
Are you talking about Print head Angle? this is a difficult adjustment and you need to adjust the front and back Allen screw at the same time. Usually in 1/4 turn increments.
Aug 06, 2010 | Rimage Prism Plus Thermal Label Printer
Mystery Print Problem with Canon iPF8000
If it's within 12 months of purchase, Canon will replace free, although you may have to hound them a bit. This problem has occured twice (2 new heads) on our IPF8100 each time about 9 months in.
Mar 09, 2010 | Canon imagePROGRAF iPF8000 Printer
Too much lead on each label. Wasting tape. How do you adjust?
You can't adjust the lead since it is just the tape from the printhead to the cutter, the best way to save is to print several labels without cutting and use scissors to cut them apart after all are done. Otherwise it will advance to cut each time and leave the blank space from the head to the cutter blade.
Feb 05, 2010 | Brother P-Touch 1180 Label Printer
How do i adjust the print head gap on a tally genicon 2280+ printer
The 2280+ does NOT have a head gap leaver you can adjust the gap from with the menu on the printer.
The printer has an automatic gap adjust which should set the correct gap for most types of paper.
The print head gap can be changed in the following way;
  1. Put the printer OFFLINE
  2. Press SETUP
  3. Press the button under ADJUST on the display
  4. Press the button under HEAD
  5. You can now change the print head gap, if the Automatic Gap Agjust is working the gap setting should go from -10 to +10.
    If the Automatic Gap Adjust is not working this value will go to values smaller than -10 to larger than +10
If the Head gap will go to values less than -10 and greater than +10, first check the AGA is enabled. This can be done in the following way;
  1. Power the printer OFF
  2. Hold down the ONLINE button and power the printer ON, keep the ONLINE button held down untill the pritner has finished initializing.
  3. Press NEXT repeatedly untill you see AGA
  4. Select AGA
  5. Channge this to ALWAY or ON (cant remember!)
  6. Press SET
  7. Power the pritner OFF and back ON to exit the menu.
If the AGA option does not apear in the TEST menu above the Automatic Gap Adjust is not working and will need to be checked out.
Sep 08, 2009 | TallyGenicom 2280 Matrix Printer
Printer-Genicom 2280+ Printer stopped then continued working, often on LCD Hardware error. When turn on printer- on LCD AGA Error.
The AGA Error on the 2280+ indicates the Automatic Gap adjust is not working.
This may be caused buy;
An obstruction (eg paper jam, ribbon etc) preventing the AGA from working correctly.
The AGA flag becoming detached from the printer or damaged
An incorrectly fitted print head
Fault AGA sensor.
You can overcome the AGA error by disabling the AGA and manually setting the print had gap.
To disable the AGA
Power the pritner on holding down ONLINE, keep ONLINE held down whilst the printer initializes.
When the printer displays ASCII80 ASCII136 release ONLINE
Press NEXT until you see AGA
Select AGA and set this to OFF
You can then manually adjust the print head gap in the normal menu.
Menu>Adjust>Head change the value to increase or decrease the head gap as required.
Jul 21, 2009 | Tally Matrix T2280 Printer
Need to set the head gap on a Genicom 3870. Lost my manual.
If it has a manual adjust, open the top cover and on the right side will be a slide for different head adjustments, it wll be numbered 1-6, 6 being right against the paper which causes smears. Move to around 3. If it has auto adjust (you can tell this when you power up the display will show "adjusting gap" then press off line, the press program, move to head adjust, press enter, press enter again then use the arrows up and down to move to your type of printing, 2part, 3 part ect.
Mar 13, 2009 | Tally Genicom 3810S Printer
73 people viewed this question
jasbo
jasbo
