Question about Teledyne Laars Laars Lite2 Heater 400000 BTU NG Elec Ign
My heater wont turn on. It is a model LD400P-B. I suspect the thermostat but not sure. What should I do to trouble shoot?
Pilot will not stay lit on my mr. heater buddy. where do i get a thermocouple for this buddy model no. MH9BX
First follow this trouble shooting guide to make sure you need one-http://www.mrheater.com/product/faqs/little-buddy-troubleshooting/ Then Amazon http://www.amazon.com/Mr-Heater-Pilot-Assembly-Portable/dp/B008DBRB8W Make sure it's the right one for your model heater.0810snp
Feb 24, 2015 | Mr Heater Base Camp Portable Buddy Propane...
How I trouble shoot a model eb23a furnace the blower fan will not turn off when temperature is satisfied?
Is the blower switch at the unit or thermostat set to on or auto? Should be on auto.
Jan 25, 2015 | Heating & Cooling
My cadet wall heater wont turn off
My cadet heater was doing this so I pulled it off of the wall and saw that the two wires coming from the thermostat portion had melted out of their insulation and were crossed. The heat is of some concern, but for now I just wrapped them in electrical tape to insulate them better against melting
Mar 11, 2012 | Cadet Manufacturing Built-In Wall Heater
How to trouble shoot a thermostat : Model # K04A110844
disconnect the wires to check for 220v to the therm. same for the elements disconnect the wires to check continuity that the elements arnt shot. make sure reset is pushed in on upper element
Jan 14, 2011 | Reliance & 50gal Electric Water Heater
I have a Dayton 3E366B hanging my garage, and it starts up -lights the burners - the fan kicks on, and then it shuts off... This cycle goes on and it does not run for long times to really get the heat up....
No I do not believe it is your thermocouple, as that only detects heat from the pilot light and permits the gas valve to open and have main flame ignition. I would be looking at thermostat placement, and safety limits built in to the heater. Making sure that the thermostat is not getting a straight on blast of hot air from the heater is my first guess. Try jumping out the thermostat by first removing the thermostat from it's housing and placing a jumper between the red and white wires as they are usually the control for heat. If your heater stays running it is the thermostat. If not you now have to trouble shoot all safety limits one at a time with a volt ohm meter and run continuity tests the limits should read closed except for the fan high limit it should read open until the temperature of the heat exchanger reaches it's set temperature. Remember to power down your unit when trouble shooting please.
Jan 11, 2011 | Dayton Heating & Cooling
At first my maytag rsd2400 refrigerator would not defrost. i replaced defrost heater. all was fine. now four months later it wont defrost again. i have tried to trouble shoot the three most common...
timer pt # 68233-2 tell it when to defrost and the terminator lets it defrost and the heaters do the defrost . so I would repl the defrost thermo next and then the timer in that order . hope this hepled mm
Oct 15, 2010 | Refrigerators
Heater won't turn off. Wires were troubled
Shut off the gas to the heater. Bad gas valve. Gas should not be leaking from any part of the gas valve.
Oct 21, 2009 | Cozy (W352E) Heater
Teledyne Laars Laars Lite2 Heater 400000 BTU NG Elec Ign Logo
69 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
