Question about 3Com NBX® V3000 (3C10600BUS)
HARDDRIVE FAILED Thanks ayone who could really help me urgently in this problem,caz i am in compnay for the last 48hrs with no sleep and i cannot find a solution for this problem. We have NBX V3000 in our office and 2 days ago power outage happened and then system system didnt get back online , i have consoled in and i found that the system just reboots it self evey few seconds, below is what captured from the console. after i seen this error and tried to fix the hardrive but i couldnt, So Please Someone tellme what to do i know i should make one partition about 320mb FAT16 and the other one is undefined. i tried everything but i am not sure what to do . and if my files are ok or not ************************************************************************************* Microsoft Windows CE Ethernet Bootloader Common Library Version 1.0 Built Jun 28 2004 16:13:10 Copyright (c) 2000-2001 Microsoft Corporation 3Com Loader Version 1.8.6 ======================================================== SuperIO Initilization.... ======================================================== Host PCI Initilization.... No SDRAM expansion module found DDRAM size: 112 MBytes Companion board found (0x6) ... initializing Press any key to break into configuration menu 5 ... Press any key to break into configuration menu 4 ... Press any key to break into configuration menu 3 ... Press any key to break into configuration menu 2 ... Press any key to break into configuration menu 1 ... System ready! Preparing for download... Initializing IDE drive (may take a second)... Microsoft Windows CE Ethernet Bootloader Common Library Version 1.0 Built Jun 28 2004 16:13:10 Copyright (c) 2000-2001 Microsoft Corporation 3Com Loader Version 1.8.6 ======================================================== SuperIO Initilization.... ======================================================== Host PCI Initilization.... No SDRAM expansion module found DDRAM size: 112 MBytes Companion board found (0x6) ... initializing *************************************************************************************
  • Anonymous Sep 09, 2008
    Have Same Issue
    Problem Solver:
  • 10 Answers
Get a new V3000 hard drive. They are cheap. That hard drive is corrupt.
Posted on Jun 11, 2009
6ya staff
SOURCE:
How could I stop snoring.Need an urgent solution
Yes there are many remedies that will help you to stop snoring. First of all snoring can be stopped by changing sleeping habit and eating habit. Overweight is also one of the causes of snoring. There are many cause of snoring and it is really difficult to figure out what cause you snoring.So get help from you figure out by providing you with sleep centers and doctors who are expert in that field. They can provide you with natural remedies as well as other anti snoring products according to your need. How to Stop Snoring Sleep Apnea and Snoring Remedies SnoreWorld
Feb 10, 2014 | plaza7.com plastic no anti snore stop...
Getting error message 80710A06 on my PS3. Use a wireless hub and have tried rebooting everything. Cinfiug shows Playstation Network Failed. Can you help?
Hi there, unfortunately there is nothing you can do at the moment. The playstation network is down worldwide. We just have to wait till sony fixes this http://kotaku.com/#!5794265/is-the-entire-playstation-network-down or http://kotaku.com/#!5794440/sony-playstation-outage-likely-to-last-days or http://blog.us.playstation.com/2011/04/21/latest-update-on-psn-outage/ or http://blog.us.playstation.com/2011/04/20/update-on-psn-service-outages-2/
Check those links for updates. Hope that helps :)
Please rate highly if it answers your question.
ps. I'm also affected by this and pretty annoyed its gone on for so long.
I think this will probably last another 48hrs.
Apr 21, 2011 | Sony Playstation 3 (PS3) Console
HI! My iOmega external harddrive has been working fine ever since I got it. But the other day when I syncronized it with my mac, it didn't show any objects. No folders or files, but it says that it is only...
Several things could be happening here:
1. your electronic controller in the hard case has failed.
2. you didn't properly disconnect the external hard drive on the MAC>
3. if you have a power supply to the USB drive it may have a damaged power connector or not supply proper power to the device.
4. the drive may not be supported by the motherboard for your PC.
Mar 18, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
Hard disk failure for tosiba
If the hard drive has failed, you will need to replace it- generally contact your system manufacturer/consult your system manufacturer's website to find a drive compatible with your system. If you wish to recover files off of that drive- you may need to contact a data recovery firm- or try putting the drive in a freezer bag, then placing the bag in your freezer for 48hrs- try to recover all you can, because that technique is a last-ditch effort.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Oct 03, 2010 | Toshiba (MK1516GAP) 15 GB Hard Drive
Error 0x80040702 while installing corel draw 11
when i install corel draw 11 it shows a message that
'error number: 0x40080702
description: failed to load dll: MC Setup
setup will now terminate'
please help me in installing this software immediately since i have to do an urgent work on it.
Thanks
Feb 18, 2009 | Adobe Photoshop 7.0 for PC
Locked cell phone (LG KG800
Try typin the last 4 digits of ur number, thats the code i used to use, but i changed. caz that is the code they first give u. Hope this helps its all i kno bout locked phones xD
Oct 08, 2008 | LG KG800 Cellular Phone
Help
completly reset the phone
many thanks
Mar 02, 2008 | Motorola Mobility W375 Cellular Phone
URGENT HELP NEEDED (editing a film) G4 0S 10.4
It sounds as if the enclosure has failed. IF THE DRIVE IS GETTING POWER, but not making strange noises, you may just need to extract the drive from the enclosure. Keep your fingers crossed. If the drive has been affected, data recovery may be the solution. Good luck.
Sep 06, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
3Com NBX® V3000 (3C10600BUS) Logo
675 people viewed this question
Top 3Com Computers & Internet Experts
john smith
didi2005
Håkan Sterner
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
