Question about HP Mini 1000 Netbook
Windows will not load can not get to desk top .notebook start files and or boot log is corrupt.system will not boot .windows 7 was just installed.
    Sergeant:
    Habit-Forming:
  • 200 Answers
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
Posted on May 18, 2011
I cannot boot up my Microsoft Windows 7 due to a corrupt ntfs.sys file. I can access command prompt through computer or cd. Please help!
As you are able to access command prompt, you can run the "System File Checker" tool to repair/ replace the corrupted ntfs.sys file. To do this, follow the instructions below:
1.Restart your system and tap F8 key repeatedly until you see Advanced Boot Options menu on your screen. If you miss reaching the screen in the first attempt, repeat this step until you reach the screen.
2.On the Advanced Boot Options screen, select "Safe Mode with command prompt"
3.In the command prompt window, type "SFC /scannow" (without quotes).
Note: There is a space between C and / in the command above.
This will scan all your protected system files and replace the corrupted files with a cached copy stored in your system.
Important: Please do not close the command prompt window until the verification is 100% complete. After the process is completed, the scan results will be displayed on your screen.
To know more about System File Checker, you can refer to the following Microsoft support page:
http://support.microsoft.com/kb/929833
Hope this will help you.
GuruAid.com
Aug 17, 2014 | Computers & Internet
Tip
Reboot and run in safe mode in windows 7,Vista,XP or 2000
Insert the CD then reboot. While the system is booting, hit the F12 key to access the boot menu (this could be a different key depending on your system.
1.) Click the "Start" button from the taskbar. Select the "Turn off computer" option if you are running a Windows OS Operating System before Windows Vista, or select the right arrow in Vista. Select the "Restart" option
2.) Press and hold the Ctrl+Alt+Del keys simultaneously. Do it again. This will reboot the computer
3.) Shut down the computer. Sometimes the computer will not respond to a reboot. Maybe the keys are temporarily disabled or the system has chosen to completely ignore you. In these rare cases, it may be better to shut the computer off using the power button. If you do shut off the computer, press and hold the power button for 3 to 5 seconds. Then be sure to wait a minimum of 45 seconds before turning it back on. This allows the capacitors in the computer time to discharge, which allows the memory (not the hard drive) to do a full dump of data. This allows a cleaner restart when you turn the computer back on.
4.)Disconnect the power cord. Do this as a last resort. Unsaved data may not be retrievable with this option, but sometimes it is the only option. Reconnect the power cord. Turn the computer on. else Insert the CD then reboot. While the system is booting, hit the F12 key to access the boot menu (this could be a different key depending on your system. If you have a problem with your hardware configuration or your computer's display drivers that prevents Windows from loading normally, you may be able to resolve the problem by booting into Safe Mode and changing the relevant settings. To enter Safe Mode in Windows 7, Vista, XP, or 2000:
Note: If you have more than one partition installed, you may need to select an operating system and press Enter before entering Safe Mode.
Turn on or restart your computer.
After the memory test, the words "Starting Windows" will appear on a black background. When this happens, press and hold the F8 key. This will present a screen with the following options to choose from. The exact moment that F8 is pressed will determine the contents of the list, and the list may vary from computer to computer. For example, your computer may not do a memory test or it may have a SCSI BIOS to load in addition to the motherboard's BIOS. If you have trouble getting the list below to appear, restart the computer and then press F8 repeatedly while the computer is starting.
Safe Mode: Boots Windows with only the basic drivers needed to load the operating system. Uses basic drivers for mouse, keyboard, display (VGA), mass storage, and default system services and drivers, with no network components. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.
Safe Mode with Networking: Loads the Safe Mode configuration, but also enables network devices and services. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.
Safe Mode with Command Prompt: Loads Windows in Safe Mode, and, after logging in, opens a command prompt instead of the normal desktop. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.Note: You should try booting to the command prompt only if you feel comfortable operating within the DOS environment.
Enable Boot Logging: Boots Windows with all of the normal files and drivers, but writes their status to a log file at each step. In Windows 2000, this log file is located in the Windows 2000 folder and is named ntbtlog.txt.
Enable VGA Mode: Boots Windows using a plain VGA 16-color 640x480 display driver for the highest level of compatibility with video cards. In Windows 7 and Vista, this mode is called Enable Low-Resolution Video. It is otherwise identical.
Last Known Good Configuration: Boots Windows using the last registry configuration that is known to work. This is a way of undoing problems created by installing incorrect drivers or possibly by registry corruption. It will not, however, fix problems caused by corrupted or missing files.
Use the arrow keys to move up or down this menu to make your selection, and then press Enter. If you need to update software or access the Internet while in Safe Mode, select "Safe Mode with Networking".
on Sep 15, 2010 | Computers & Internet
Boot log 1525
venkatachalam,
How to Enable Boot Logging in Windows By Dan Gookin from Troubleshooting Your PC For Dummies, 3rd Edition
Two event log files that come in handy for troubleshooting your PC are the boot log files. These files are created when you specify boot logging as a start-up option. The files are named either ntbtlog.txt or bootlog.txt, depending on how old your PC is. These files, found in the Windows folder, list the success or failure of various pieces of Windows as it's loaded into memory from the PC's mass storage system.
You can enable or disable boot logging by using the MSCONFIG utility. Follow these steps in Windows 7 and Windows Vista:
  1. Press Win+R to summon the Run dialog box.
  2. Type msconfig and press Enter.
  3. In Windows Vista, type the administrator's password or click the Continue button.
  4. Click the Boot tab.
  5. Place a check mark by the item Boot Log.
  6. Click OK.
  7. Click the Restart button to restart now. Otherwise, click Exit without Restart.
    The logging doesn't take effect until you restart Windows, and you have no reason to do so immediately unless you really want to see the boot log.
In Windows XP, you can enable boot logging by pressing the F8 key when Windows first starts and choose the item Enable Boot Logging.
The boot log is overwritten every time you start Windows. And, the log is produced only when you turn on the boot logging option.
What can you do with the boot log? You can check for the failed installation of certain pieces of Windows or device drivers. The drivers or files are obviously flagged in the log. Because you know the filename, you can then either disable it from loading or look for an update.
  • Activating the boot log in Windows 7 or Windows Vista means that you configured your PC for a custom start-up. If that bothers you, disable the boot log after you cull whatever useful information you need from the boot log file; repeat the steps used to enable boot logging, but in Step 5, remove the check mark.
  • Traditionally, computer logs are all text files. They may have the filename extension log, or they may use txt instead.
  • You can search for log files by using the Windows Search command. Simply look for files named *log* anywhere on the hard drive, including system, hidden, and non-indexed locations.
  • Most log files are in plain text, but the text may be organized by using the XML, or Extensible Markup Language. XML is merely a way to organize information, and although XML files are readable as text, to get the most from the information, you should use an XML reader, such as the Event Viewer program.
  • If you find the file boot.ini on your Windows XP computer, you can enable boot logging by modifying the file. Open it in Notepad and look for the line that contains this text:
    Windows="Windows XP (That's only a portion of the line; in the file, it's longer). Add the text /bootlog to the end of the line. Save the file. When you restart Windows, boot logging takes place automatically.
Thank You,Dell-Jesse LDell Social Media and Communities
Aug 19, 2013 | Dell Inspiron M5030 Laptop
When i try to start up my laptop it first goes to the windows start up window with the F2 and F12 saying thing at the bottom, but then goes to a black screen that reads "Windows could not start because the...
you operating system files corrupted. below you can steps to be taken to solve it . but if you are not having much knowledge on system side, dont follow this. better find an hardware engineer and he will solve it..
Method 1
Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
1. Use the Windows XP CD-ROM to start your computer.
2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key.
3. Select the Windows installation that you want, and then type the administrator password when prompted.
4. Type bootcfg /rebuild, and then press ENTER.
5. When the Windows installation is located, the following instructions are displayed:
Add installation to boot list? (Yes/No/All)
[Type Y in response to this message.]
Enter Load Identifier:
[This is the name of the operating system. Type Windows XP Professional or Windows XP Home Edition.]
Enter OS Load options:
[Leave this field blank, and then press ENTER].
After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
Method 2
1. Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
2. After the setup files are finished loading press R to repair using Recovery Console.
3. When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
4. Login to the Administrator account by typing the password for this account, and then press ENTER.
5. At the recovery console command prompt, type the following command, and then press ENTER:
For Uni-Processor systems:
expand <cd-drive>:\i386\ntoskrnl.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
For Multi-Processor systems:
expand <cd-drive>:\i386\ntkrnlmp.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
Note In these two commands, the <cd-drive> placeholder represents the drive letter of your CD drive, and the <hd-drive> placeholder represents the drive letter of the hard disk on which windows is installed.
6. If you receive a prompt to overwrite the file, press Y.
7. Type exit, and press ENTER at the command prompt.
Method 3
Start the computer by using the Recovery Console, and then run theCHKDSK /rcommand.
Note You do not have to include the /p switch in the Chkdsk command-line because the /r switch causes the Chkdsk utility to locate bad sectors and recover readable information. This command implies the /p switch..
Aug 14, 2010 | Toshiba Satellite A105 Notebook
Windows vista isn't starting up due to corrupted file. How do I log in/
If windows Vista OS isnt loading then your Operating System ( OS ) is corrupted. Try running the installation disk and repairing your system. If this fails you will need to do a FULL operating system re-installation.
May 20, 2010 | Dell Inspiron 1525 Notebook
Error loading operaiting system
if you get that error, then the operating system is corrupted..
  1. restart the computer
  2. when you see the VAIO logo on the screen, start pressing F10 key on top of the keyboard for 5-7 secs until you see windows is loading files or edit boot options
  3. if you see edit boot option, press enter
  4. it will load vaio recovery center
  5. from vaio reocvery center, select restore c: drive on the left side. (it will format the hdd. make sure to back up your files first before starting the recovery)
hope this helps ü
Mar 11, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
Installed webroot not compatiblewith windows 7
the antivirus that u installed is stoping some critical windows files getting loaded...as it sees these DLL files/exe files as potential trojens/virus....the same issue is with Avira Antivirus....try useing Mcafee or AVG AV...they r good free AVs....
to get ur desktop....when u boot press F8 and if get to the option screen...chose Safe mode to load windows...if u get to work in Safe mode.....uninstall the Webroot AV...and run a chkdsk in DOS prompt...
to go to dos prompt...do this
Start / Run / type cmd there in the box...in the balck screen....go to c:\
type cd windows
type chkdsk
after chkdsk is complete shut down and restart...
this should fix...
then install AVG or Mcafee
Dec 25, 2009 | Computers & Internet
Boot manager is missing and wont load windows 7 on compaq presario c700, no matter what i do it keeps returning to the boot manager missing press ctl alt dlt.screen how do i fix it
If your using a DVD to install the operating system, it could be either dirty (just needs a wipe) or the files on the disk are corrupt.
If you are getting this error while Windows 7 is starting up perhaps you can try doing a "repair". Boot off the DVD do a repair (not from the recovery console) and see if this helps.
Hope this helps.
Nov 08, 2009 | Compaq Presario 700 470024-192 Notebook
Bios setting problem
This happens because Windows is corrupted.
You need to start the computer with a windows install disk, or a factory recovery disk inside to reinstall the system.
Get a windows install disk and reinstall the system.
Nov 17, 2008 | Computers & Internet
HP Mini 1000 Netbook Logo
158 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
