Question about Samsung Digimax A6 Digital Camera
Reply to ekse
It does not work with any battery at all the green power light does not come and therefore camera has no power
  • Samsung Master
  • 13,433 Answers
Try cleaning the battery contacts if there is some corrosion
also I sent you a comment in the premium you pruchased here it is again
Comment by Ekse, posted on Aug 14, 2008 If the camera doesn't work at all, do you have warranty on it? If you got warranty, contact your dealer or samsung for repairs.
if your in the usa you can get a free repair estimate from advance camera
http://www.advancecamera.com/repair
but let me know what the actual problem is.
Thanks,
Ekse
Posted on Aug 14, 2008
DV’s will not work cameras dead power button green also red light on machine
If the battery is properly inserted and fully charged, and the device still does not power on, the battery itself could be defective. Changing the battery would fix this. The specific battery model for the camera is the EN-EL19 lithium ion battery. The battery replacement is a Lenmar DLZ319N.
Nov 12, 2017 | Green Cameras
I bought a power adapter for the camera, but it doesn't seem to work without batteries in the unit. If I use the batteries alone, I will eventually get a red blinking light at the back of the camera,...
Because the camera is what is technically known as 'Portable'and is designed to work purely from the internal battery. the Power Adapter merely charges the internal battery
May 08, 2017 | Kodak EasyShare C330 Digital Camera
Orange light flashes on when turn on Olympus c-50 zoom camera and orange and green lights in upper left corner blink when try to take pictures. Won't take any pictures
The flashing Orange light means the charge is flashing.
The flashing Green light means the focus and exposure are not correct.
Have you recently replaced the batteries? Or are you using rechargeable batteries? Lack of enough "Juice" could allow for the flash to not charge up (Orange) therefore not allowing the camera to get the correct exposure (Green). I would try new fresh batteries or a new battery pack. If that doesn't fix the issue it must be a bad circuitry in the body that is shorting not letting the flash charge.
Regards,
Jacob
Mar 05, 2011 | Olympus Camedia C-50 Zoom Digital Camera
Camera not charging charging light flashing
If the charging light is flashing then this indicates that the charger is okay. But if the camera is not charging still then one of two things could be the problem either the battery has not been properly fixed in its base therefore the power being supplied by the charger is not sufficient enough and therefore the battery does not charge.
On the other hand the battery could have run out of juice completely therefore not be able to retain power anymore.
Hope this solution has been helpful?
Feb 08, 2011 | Cameras
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Wont turn on, new batteries, green light just blinks.
Make sure you are using the correct batteries, and that they are installed correctly. Some cameras require more powerful kinds of batteries and will not work with the cheaper kinds.
A blinking light can mean something is wrong with the power, not enough or something else.
If you have a power adapter or can get one, you may try that, to see if the camera will work without batteries. If it does, then some problem exists in the battery circuit.
Oct 20, 2009 | Samsung S860 Digital Camera
My L200 samsung camara is frozen and the lens are stuck out
I had the same problem - and wondered if if might be that the battery didn't have enough 'grunt' to close the lense - so I am charging it via the actual charger (rather than through the computer) and sure enough, I turned it on and then off, and the lense closed. The green light comes on when I plug the camera into the computer to download photos, and I thought this was therefore charging the battery, but maybe it doesn't charge it properly. Anyway, my lense is now closed and the battery is still charging (light is still red). Good luck.
Jan 06, 2009 | Samsung L200 Digital Camera
Panasonic ds27 camcorder charge
It could need a new battery.  The battery can't hold a charge in it anymore.
Sep 18, 2008 | Panasonic NV-DS27B Mini DV Digital...
Samsung Digimax A6 Digital Camera Logo
63 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
