Question about Cameras
Hi i have apanasonic DMC-FX01 ...it has been working fine..with my 1 GB SD card. but recently it asked if i want to format.. i selected NO..as i had some omportant pictures..later whenever i turn on the camera..it sayd MEMORY CARD ERROR PLEASE CHECK THE CARD...my PC cannot detct the card anymore...please help
  • 5 Answers
SOURCE: Format Error in Sony Cybershot
i think this problem arises when you fail to regularly format the card ie. take lots of pictures and delete some and repeat the process over and over instead of downloading every session and formatting the card causing coruption. Also if you've bought pro duo memory stick off ebay poss. its a very good forgery (again i've been caught out by this).
Posted on Jan 16, 2008
  • 4 Answers
SOURCE: software for panasonic DMC-FX01 digital camera
PROBABLY NOT - YOU SHOULD TRY AND GET THE ''WIZARD'' TO INSTALL YOUR CAMERA...IT SHOULD RECOGNIZE IT AND THEN INSTALL...YOU SHOULD BE ABLE TO DOWNLOAD YOUR PICTURES THEN...
Posted on Jan 03, 2009
  • 3 Answers
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
Posted on Jan 28, 2009
SOURCE: I put a 4GB Sandisk SDHC card into my Panasonic
no way to solve...only SD is applicable...4G SDHC is not suitable for it
Posted on Jun 13, 2009
Hacklet
  • 18 Answers
SOURCE: when I zoom useing my panasonic lumix DMC-FX01 it turns off
Have you had problems when you turn it on and off from scratch before? It sounds like you have a problem with the lense extension. Now if you are lucky, it's just a bit of dirt in there and the best cure (I know, it sounds horrible) is to put the end of a shop-vac over the lense when it's closed and it will probably **** the obstruction out. If you are less lucky, the problem is with the gearing inside and in the middle of the luck-vs-effort range it could just have been bashed, in which case, you can try and push it back into alignment but be careful with it (he says, after he hit his last one with a large lump of wood to put it back).
Good luck :)
Posted on Jul 13, 2009
What SD Cards will work with Lumex DMC-FZ7 ?
It will work with any SD card, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Apr 30, 2014 | Panasonic Lumix DMC-FX01 Digital Camera
Why does the lumix panasonic DMC-FZ20 camera keeps saying memory card error
The FZ20 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Feb 22, 2013 | Panasonic Lumix DMC-FX01 Digital Camera
I bought a SDHC 4GB card and introduced in the camera. When turn on, came the message "memory error". What should I do?
Check your instructions, is a 4GB SDHC card compatible with your camera.
if you don't have a manual, just google "panasonic lumix dmc-fx01 manual" several options will appear.
Page 16 deals with card compatibility, it states that the maximum you can use is a 2GB Sd card, no mention of SDHC.
Nov 19, 2010 | Panasonic Lumix DMC-FX01 Digital Camera
Cannot format a maxwell class 2 4 gb card for my lumix dmc-lc33
The DMC-LC33 is designed to work with SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card. While it fits into the slot it will not work. You need to use SD cards, 2GB and smaller.
Aug 24, 2010 | Panasonic Lumix DMC-LC20 Digital Camera
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
Hi: I have a lumix/Panasonic DMC-FS3. I keep getting a message "Memory Card Error. Please check the card." Nothing has happened to the card. What could cause that?
Has the memory card ever worked in this camera? If yes, try downloading all the pictures to your computer then format the memory card using the camera setip menu. If this is a new camera, Make sure the camera can use the SD HC type memory cards. Some older cameras cannot read the SDHC but are fine with the SD cards.
Nov 21, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
Memory card error
Did you format the card before using it on your camera? Try using a memory card reader instead of the printer's SD card slot to transfer the video. Also check if the memory card is locked (check the position of the yellow slider at the right side of the card). If this does not work, then you will have to format the card. Unfortunately this will erase all the data in your card.
Feb 04, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
4gb Sandisk sd card -
this camera will only take up to 2gb
Feb 29, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Cameras Logo
22 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
