Question about Briggs & Stratton Lawn-Boy 10640 20-Inch 6.5 HP Gas Powered Lawn Mower
I put two stroke oil in the Lawn Boy 10640 and ran it briefly before it quickly became obvious what I had done. I have already drained the oil and replaced it with 4-stroke 10W-30 not just once but twice to make sure it's mostly gone. I also replaced the spark plug and the air filter. Yet when I run it, the exhaust still seems to 'smoke' after i turn it off... Like it's over heating. What do I need to do to fix it???
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Briggs & Str... Master
  • 1,917 Answers
You still have oil in muffler buy new muffler or run like it is it will eventually stop smoking
Posted on Jun 24, 2014
4 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: I just bought the lawn boy 10640. haven't been
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to seat the jet screws.
But before you seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 10, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Describe your Lawn-Boy 10640 20-Inch
Hi haystackcalh...
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Posted on Aug 21, 2011
  • 6468 Answers
SOURCE: Lawn Boy 10641
see if the oil smells like gas the carb maybe sticking and gas gets into the oil washing the oil out this will make hard starting and smoke if so the needle valve is not sealing if you caught in time without major engine damage a sign is the oil being over full and smelling like gas
Posted on Apr 04, 2012
My lawnmower takes 15 -20 mins to warm up.
Check oil may have low oil shutoff and drain gas and start with new
Feb 25, 2014 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Will not start after changing the blade
what side did you tip it to did oil drain into the carb did gas drain into the cylinder flooding it out remove the spark plug and look pull the engine over with the plug out and that can push it out
Apr 25, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
I started my lawn boy mower model 10642C near the cage part on the side it started to smoke and smell like something was burning.
This is the exhaust port. If you over primed it before starting, it will smoke and smell like burning oil.
I have the same one and I've done that before.
var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Aug 24, 2011 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
New Lawn boy 10640 mower - had for approximately 2 months, always worked fine. Saw that it was low in oil (naturally), added oil (did not overfill) and the pull cord won't work. It's stuck - everthing...
Don't throw it out. Remove the top plastic cover and it will be easy to access the starter/recoil unit. It should be easy to remove and take that off and diagnose the problem. Post back if need be.
Aug 13, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
What kind of oil should i use for my 6.5 briggs
Doesn't matter what kind of oil you use, as long as its SAE 10w-30.
Jul 03, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Wont start, ran out of petrol ive put petrol in but it wont start ?
If it has the primer bulb push on it many times and try starting again
Jun 14, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Oil leaking from under the exhaust mower has been
souds like the carb needs cleand out it has stuck open and let the gas run in to the moter
Nov 05, 2009 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
New lawn boy mower pull cord will not pull. Worked first 2x
Did you check the oil before you ran it. They usually come dry and you have to but oil in before running. Sounds like motor might be blown.
Aug 14, 2009 | Garden
Briggs & Stratton Lawn-Boy 10640 20-Inch 6.5 HP  Gas Powered Lawn Mower  Logo
123 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
