Won't accept win xp
Good day sir,
i have this jetway v6du mobo, and my problem is it won't accept winxp it only accept win 98. the cpu is a amd athlon xp 2000+ . wiil you please help with these sir. ty
  • Anonymous Aug 27, 2008
    I'm using ASUS P4V8X-X and it works well on win 98.. I want to upgrade it to winxp but it won't accept it..what really is the problem, pls help
  • ColieandTaz Dec 22, 2008
    The pc just keeps crashing. I can't get it to even let me install it all the way, can the bord take the upgrade?
The minimum hardware specification of the win XP is
atleast PIII-800 Processor
128MB Memory
32 mB videocard
Posted on Aug 15, 2008
My athalon xp2000 processor died. What can I replace it with that is compatible with k7s5a motherboard?
There are several versions of the K78S5A. The following answer applies only to v.3.x.
CPU: AMD Duron 200Mhz FSB CPU - 950 AMD Duron 266Mhz FSB CPU - 1800
AMD Morgan 200Mhz FSB CPU - 1.3G
AMD Athlon 200Mhz FSB CPU - 1.4G AMD Athlon 266Mhz FSB CPU - 1.4G
AMD Palomino 266Mhz FSB CPU - 1.2G
AMD Athlon XP (0.18u) 266Mhz FSB CPU - 2100+ AMD Athlon XP (0.13u) 266Mhz FSB CPU - 2600+
I hope that helps! Good luck.
Mar 06, 2011 | EliteGroup K7S5A Pro Motherboard
Amd athlon xp 2400+ problems witha epox ep-8kra2+ motherboard?
It sounds to me like the processor that you bought is not fully supported in the current bios in your mobo. I would check the epox website for newer bios. Be careful flashing the bios, if you misstep in the flash, you may end up with a brick. If you are successful, you should be able to run the processor at the speeds you expected, though within the limits of the hardware on the mobo. Also look at the spec's for the mobo on the site to see if your processor is listed as being supported.
Feb 14, 2010 | EPoX EP-8KRA2+ Motherboard
What processor can i put in my jetway v2dp. I currently have an athlon xp 1660
Hello there burberryjam.
Here's your GEEK-steer ...
Per the manufacturer's webpage for its motherboard "V2DP", it will "...Support Socket-A for AMD Athlon /Duron TM uni-proccessor at 266/333MHz Front Side Bus with double data rate".
More specificically, here's its "CPU Support" list.
Good luck, and thanks in advance for posting back ...
  • to let me (and others) know how things worked out,
  • if you have any further questions,
  • to provide clarification or feedback.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Craig
Sep 25, 2009 | Jetway V2DP Motherboard
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Jun 29, 2009 | Syntax SV266M Motherboard
Cpu update
basing from MSI website cpu support for this mobo,
the best AMD processor you can fit on this mobo is
Barton (0.13u) 200/400MHz FSB 512KB L2 Cache AthlonXP 3000+ 200 Auto OK AthlonXP 3200+ 200 Auto OK
Oct 13, 2008 | Intel Motherboard
Fastest CPU available for the K7N2G?
Look for socket A processors and ignore the XXXX+ and focus on the XXXXMHz rating (the MoBo's manufacturer's support site will give you the max processor your Board will handle). Since you mention that your MoBo is 4 to 5 years old, you'll probably better serve yourself to replace the MoBo and processor (you'll be able to upgrade to a much better/faster processor by upgrading both, and shouldn't cost that much more), and probably be happier with the result. You may want/need to upgrade your Power supply while you are at it too.
Mar 29, 2008 | MSI K7N2G-L Motherboard
Cmos resetting
Ok so you know the bat is good cause you checked the voltage. You double checked the bios jumper making sure it is not set to clear. Looking in your manual you can go to AMD XP3200+, & you are under that. So either you have a short or your bios needs flashed because it's messed up. Could have went when the cpu died.
Jan 15, 2008 | Biostar M7NCD ULTRA Motherboard
JetwayV266b (REV: 3.00) - Max processor speed??
Design ATX form factor 4 layers PCB size: 30.5x24.4cm Chipset VIA KT266A/VT8233A Chipset CPU Socket Support AMD Athlon 700MHz∼1.4GHz processor Support AMD Athlon XP 1500+ 2600+ processor Support AMD Duron 600MHz 1.3GHz processor Support 200MHz/266MHz (Double Data Rate) Front Side Bus frequency processors Reserves support for future AMD processors 2600+ is the highest it will go. page 3
Sep 17, 2007 | Jetway V266B Motherboard
Problem with mobo upgrade ... From Intel CPU to AMD CPU
hi dale, itsnot a good thing when you see the blue screen of death, cause recent changes hardware normaly maybeif you have changed from intel to amd using mobo and all parts are amd now , maybe if you reinstalled your operating system the new hardware that is installed will accept you software cheers steve good luck
Apr 26, 2007 | Jetway 939GT4-SLI-G Motherboard
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
