Question about Akai LCT2715 27 in. LCD Television
The power light is constantly blinking in yellow. before this happened the yellow light was on without blinking I turned it off, once I turned it back on the light turned green but the screen wasn't showing me anything. I held down the power button for a couple of seconds and it turned on. Few minutes later it went off again and the power light kept blinking in yellow.
Change the batteries in your remote! This works!
Posted on Feb 19, 2013
  • 56 Answers
Try unplugging your t.v for 10-20 seconds. plug it back in. if your power light continues to flash your t.v is the issue. you should be able to google your issue or check your owners manual about the problem. unplugging the t.v is the last ditch effort. Good Luck!
Posted on May 18, 2011
Yellow light constantly flashes on all handsets
Yellow light constantly blinks on top of all the cordless phones
www.faqqq.com/.../yellow-light-constantly-blinks-on-top-of-all-the-cord...
Question Product: Panasonic KX-TG5432 Digital Dual Cordless Telephone Question Details: Yellow light constantly blinks on top of all the cordless phones The.
Panasonic KX-TGP550 Normal Status Lights
www.statuslights.com/panasonic/panasonic-kx-tgp550.html
Red (Rapidly Flashing), The Base Unit is paging handsets. (KX-TGP-500 only). Amber(Solid), The Base Unit's IP address may conflict with the IP addresses of ..
Jan 16, 2016 | Panasonic KX-TG7641M KX TG7641M KXTG7641M...
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Center (yellow) light blinks consantly
actually that one blink says a user fault, says to release joystick and put it innuetral and try again,can only tell you what manual for invacare says,me id have a dealer tech look at it, check voltage of batterys,first please
Dec 06, 2013 | Invacare Health & Beauty
Head unit not getting the right constant power
normally when an aftermarket stereo is installed the yellow wire is for constant power gets connected with the ignition power wire and what you said is what happens in result. get a multimeter, set it onto dc volts and put the black lead onto something metal and then id use the red lead to test wires for a constant 12volts when key is in the off position. Once a wire is found connect it to the yellow wire of the stereo
Feb 19, 2013 | 1999 Acura Integra
When I turn on My RCA L40fhd41 40" television, the LCD screen constantly blinks on and off like a strobe light. The power light stays on constantly, but the screen continues to blink
Dec 12, 2010 | RCA L40FHD41 40. in HDTV
Canon i470D Printer will not work. Yellow light
1. Turn off the printer ( "Power" button).
2. Hold the button "Resume", include printer (click "Power").
3. Hold the "Power" button, release the button "Resume" (power indicator / preparedness must turns green)
4. Not releasing the "Power" button, double click "Resume" and release both buttons
-- each time you click "Resume" power indicator / willingness to change color (one-click - yellow, the second hitting - green). U printers with more than one indicator - indication switches (power indicator / preparedness - green indicator error - yellow)
-- after the buttons are released, power indicator / preparedness will be for some time to blink green (Stamford time depends on the printer model), and then the green light permanently
-- If after these actions instead of constantly burning green printer continues to display error, or you are mistaken in paragraphs 1-4 (turn off the printer and repeat with paragraph 1), or if additional printer error that must be corrected, or it will not go down to a service mode.
5. Four times click "Resume" (each time you click "Resume" power indicator / willingness to change color, and the printers with more than one indicator - indication switches: the willingness / error).
6. Once you click "Power" to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again.
For some printers (for example, iP2000) to switch off clicking "Power" again, that is three in a row.
May 08, 2010 | Canon i 470D InkJet Printer
Flashing red light
This is known as the yellow light of death for the PS3 (ironic, I know. Because it blinks a red light). This is caused when the unit overheats causing solder on the board to melt and bridge (connect). Once this happens it shorts out the board causing the error you have now. Contact Sony and see if the unit is still under warranty with this site: https://service1.us.playstation.com/rma.htm?_flowExecutionKey=_c71000C59-AA41-E39E-0F5C-E9201DBE7B2B_kA7F58291-2AE5-F8BD-E0D2-C63AAC401CB1
Jan 20, 2010 | Sony Video Game Consoles & Games
Powers on immediately powers off
ok well there is somwhere to start i would see if you can get it to take a charge ok and if it does than try to start it without the ac power on and see what it does if it wont take a charge your battery may be bad or your charging circuit may not be connected correctly ok lrt me know best regards mike
Aug 27, 2008 | Dell Inspiron 5160 Notebook
Power & Yellow Resume Button flashing constantly & will not print
Ok please try
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Akai LCT2715 27 in. LCD Television Logo
744 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
