Question about Whirlpool LGV4634JQ Gas Dryer
My whirlpool gas LGB6300PW0 dryer won't start. I press the start button and hear a humming noise, but no motor turning over. Please tell me that my 5 yr old dryer doesn't already need a new motor! Already checked to see is fuses / circuit breaker blew and socket works with blow dryer.
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on May 18, 2011
How can I fix my HE4 Gas dyer it will not start
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Jun 21, 2014 | Kenmore 659 Electric Dryer
I have i kitchen aid gas dryer,when i press the start button it makes noise for about 3-4 second s then it stops and it won't start
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced.
Now if you press the start button and the machine starts to hum and continues to hum its possible that something has gotten caught in the blower wheel and binding the motor up. Depending on the make and model the location and access to it vaaries.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Feb 27, 2012 | KitchenAid Dryers
Kenmore dryer Tub will not turn freely. Feels as if it's hung up. When you you press the start button it will just make a humming noise.
A guess, sounds like you are hearing the motor running but no tub belt as it is probably broke. If you are asking then you probably don't know how to fix it so you should call a repairman. Or the tub guides are wore out either way a repairman can help.
Nov 22, 2011 | Kenmore Dryers
My gas dryer is a whirlpool LGR4634eq0. Timer starts but when I press the power button i hear a load noise( like a stuck hinge) and the dryer wont start. Help
The power button is usually called a "start" button. For as long as you hold it down, it provides power to the motor. When the motor gets up to speed, centrifugal force holds the switch closed for you. This is why a quick (short) opening of the door will not stop the dryer and a quick press of the start button will not start the dryer.
This, however, does not explain the noise...
The motor turns a belt which wraps (sort of) around a pulley which is on a spring (and also around the drum). The spring should hold tension on the belt, but the belt should not be so resistive (drum refuse to turn) to cause the tensioner to strike anything.
Can you turn the drum by hand?
The drum rides on two wheels. They should roll smoothly.
:o).
Jun 04, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Drum not turning, hear humming noise
the humming noise is from the motor,see if you can spin the drum by hand,if it moves you have a bad motor,if it's hard to turn you could have something stuck in the blower wheel or the belt is jammed somewhere,the blower wheel is behind the duct that the lint filter slides into
Mar 20, 2010 | Whirlpool LER4634J Electric Dryer
Kenmore Series 80 Gas Dryer only Hums when start button pressed, but won't start
Hi, Does the dryer only hum when you push the start button?
Might be a bad motor.
Does the motor hum but, the drum doesn't turn?
Please let me know and get me a model # so I can assist you further.
Vic
Jun 01, 2009 | Dryers
Whirlpool gas dryer won't start
you most likely have a bad motor. Motors run around 100 dollars since the machine is 20 years old it would be a good idea to replace it with a new dryer. if i were you i would stick with a whirlpool product.
Oct 13, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool Clean tough gas dryer
Probably, you are hearing the motor turning. The belt likely broke.
Dec 24, 2007 | Whirlpool GEQ9800P Electric Dryer
Whirlpool LGV4634JQ Gas Dryer Logo
267 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
