Question about Kenmore 72062 Gas Dryer
My dryer smells like it is burning. I took it apart and the belt looks ok. The lint filter is clean and also the outgoing lint pipe. Any suggestions why this has a burning smell.
    Genius:
  • 1,140 Answers
Scary, is it like rubber or plastic?
rubber would be belt or drum rollers
plastic would be wiring (possible fire hazard)!!!
Posted on May 18, 2011
My BaByliss blow dryer smells like burnt when I turn it on and I seen like a spark is it going to work anymore
DRYER SMELLS LIKE BURNING:
Answer:First, Stop using your dryer until this problem is resolved. This is a fire hazard and could cause a fire.
Your issue is more than likely alint build up problem. The lint that comes off of your clothes as you dry them becomes trapped in the dryer itself and in the venting duct that connects from the back of the dryer to the wall.
The first thing to do is todisconnect powerby unplugging the dryer cord from the wall. Slide the dryer away from the wall slowly.Remove the hose ductthat attaches to the back of the dryer. Look inside the hose duct and if you see heavy lint build up, that is most likely your problem. If you have a shop vac vacuum or similar, use the long wand attachment tovacuum out the lintthat is in the duct. The best way to do this is to completely remove the vent duct from the wall and dryer.Vacuum the inside of the ductto clean it out. Alsovacuum in the vent hole in the wallwhere the duct attaches to the wall and remove any lint that may be blocking air flow. Put everything back together and test your dryer to see if the burning smell has been resolved.
NOTE: There may be heavy build up of lint deep in the wall. You can purchase aDryer Vent Cleaning Kitthat may make your job of cleaning the vent much easier. However, it may be best to call a Dryer Vent Cleaning Company as they have the equipment that is needed to remove all lint in the wall that could cause a fire. We know everyone wants to save money and "do it yourself" but when it comes to safety, money should not be an issue.
If the burning smell is still present, you cantake the dryer apartandtry vacuuming out any lintthat may be built up on the inside of the dryer. Do a search for your dryer model name and number onGoogleto see how your particular dryer model is disassembled. If you are not comfortable taking your dryer apart then it is advised to call an appliance repair company as your issue can cause a fire.
There are other reasons for your dryer to have a burning smell. There could be an electrical issue inside your dryer. This may mean that a certain part or electrical board is going bad or is bad. Another common reason for this issue is something is near the heating element inside the dryer and causing the burning smell. If you have an older clothes dryer, it may be possible that the components are past its life span and it is time to purchase a new dryer. If you want your dryer to be looked at by a professional, it may be time to call an appliance repair company to come out and check your dryer.
There are plenty of videos that can help you to determine what may be wrong with your dryer. There are a few videos below that may assist you with troubleshooting and disassembling your dryer.
The belt
In some dryers, a belt turns the drum. This belt can slip off, which can cause it to start melting. Because it is usually made of rubber, it will then produce a very strong, unpleasant burning odor. If your drum is not turning smoothly or properly, and you notice a bad burning smell, your belt is probably damaged.
THE MOTOR
Dryers have motors, and as they age, they can burn out just like any other motor. This causes a very strong burning smell, and your dryer will either not run at all, or it will run poorly and with a lot of noise.
Read more :http://www.ehow.com/list_7173741_causes-burning-smell-dryer.html
Causes of Burning Smell in Your Dryer eHow
Apr 22, 2016 | BaByliss Dryers
Smell rubber
i have found that when people start smelling things in the dryer it's from chemicals from like paint or varnish,all the dryer does is move air when it gets hot you start smelling it.you can pull it apart and check the belt and rollers but your dryer has the lint filter on top and there isn't anything in there that could really make it smell,on some of these dryers the belt pulley doesn't have a wheel on it,the pulley is just a piece of metal with no moving parts and the belt rubs on the pulley but i've never smelt anything from that,like i say usually it's from having your floors done over the smell from the polyurethane coating or from paint can make the dryer smell.go here to take dryer apart
http://www.youtube.com/watch?v=xGIG8Wo5-N4
hope this helps
Jan 19, 2014 | Dryers
Burning smell however, motor runs fine, belt looks good, element heats up, vent is clean. i'm at a lose
Dryers collect lint.
Some, like the one I fixed last month, had a whole wastebasket full of lint inside it where you could not get it out without tearing the whole dryer apart.
I\'m suspecting either lint or some other foreign object is burning.
For your safety, please take it completely apart, or get someone else who knows what they are doing to do so, before you have a dryer fire.
( P.S. The last dryer I just fixed had a worn out felt on the drum, allowing the blower fan to suck lint past the screen and fill the inside of the dryer with that lint.)
Be blessed.
Apr 16, 2013 | Dryers
Smell
Hello, In most cases when you have a burning smell a simple fix is your lint lines are dirty. A lot of time when your filter or your hose that goes out the back (by the wall) gets dirty it gets hot and starts to burn. There have been some cases where it will catch on fire, so always make sure lint filter and hoses are clean. Other forms of burning smell can be the dryer belt is waring out or loose, Kind of link when a vacuum cleaner belt gets worn and starts slipping and burning rubber smell. AND Finally could be the main barring that could be going out.
My advice start with simplest first, check vents and lint filter and go from there.
I hope this helps Mike.
Apr 07, 2012 | Kenmore Dryers
Help - problems with screaching/grinding sound - small smell of burning
Did you remove the filter chute? My dryer was making a heck of a racket and I found a wire inside the blower housing:
Service manual and more
Nov 14, 2011 | Kenmore 659 Electric Dryer
My dryers smells like its burning and inside when drying gets really too hot. The air vent going outside is clean. I took off the casing and cleaned the inside of the dryer. The belt seems like its ok....
Lint burns quickly and rarely holds a flame long enough to cause a fire hazard. Metal burning would probably indicate friction on spinning metal, like the motor shaft, or the drum rollers. Plastic/rubber are usually parts that are intended to wear, and can usually be replaced.
Along with the belt, you should also check the idler pulley that takes up the slack in the belt, as well as any drum rollers or nylon glides on the top of the dryer door where the drum rides. Metal, plastic, and lint have distinct smells, and you should be able to determine which one(s) you have by smell.
Lint is a common burner in dryers, and it seems you've looked in some of the obvious places it can accumulate. When you have the cover off, pay special attention to the burner area, and any ducts from the lint screen area. Also, any gaps in insulation where air flows could cause hot spots in the unit. If you can see the flame while its running, make sure its size is not excessive. Flames should not be too low or too high, and should not escape the burner housing.
If you notice soot buildup, your gas/air mixture is off. If you've switched from natural to bottled gas or vice-versa, you may need to swap the burner orifices to match the different pressures of the gas fuel.
May 18, 2011 | Kenmore 74632 Gas Dryer
Roper elctric dryer model RES7648EQ make grinding and scraping noise when i start it. Found a bra hook cought in drum on inside of dryer took it out now when I started it it smelled like the belt was...
belts dont really burn the main reason for buring smell is lint on the element did you take the whole barrel out? as 90% of the lint that burns is formed around the heating coil behind the barrel
best of luck sir
Dec 02, 2010 | Roper RES7648E Dryer
Burning smell in in dryer
Take a flashlight and look inside the drum at the holes on the back end of the drum where the hot air comes in. On mine, there is an air deflector on the back side of the drum and the space between this deflector and the drum was packed with lint. The lint blocked about half the holes. I had to take the drum out, remove this deflector by removing four screws inside the drum then cleaning out the lint. The lint was all brown and scorched.
Jun 07, 2009 | Whirlpool LER4634J Electric Dryer
Scraping noise with burning smell
You quite possibly have something like a penny or a paper clip stuck at the heat duct. ***First-shut off the electric to the dryer***. From behind the dryer, remove the heat tunnel and clean it out. You will be surprised how much lint gets past the filter. It's an easy repair, just a few screws. While you're back there, look around for any buildup in other areas.
Jan 03, 2009 | Whirlpool LEQ8000JQ Electric Dryer
My dryer is giving off a strong odor. Smells a little like rubber or metal on metal. It still works great. Is still getting hot and drying clothes. Can you help? Lg washung machine/dryer combo(front...
Sounds like drive belt or drum supports, if the drier is gas I would check it out, could cause a fire, if it is electric still check to make sure it is not rubbing on the electric heat element, or it could be full of lint which is catching fire during normal operation and melting or burning the belt or drum supports.
Nov 04, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Kenmore 72062 Gas Dryer Logo
253 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
