Question about Sport & Outdoor - Others
I HAVE A GO-KART 5HP MODEL 136212-0026-01 THAT EVERY TIME YOU PRESS ON THE GAS PEDAL IT DIES WHAT CAN I DO TO FIX IT??
5 Suggested Answers
SOURCE: accellaration problem
the problem might be your throttle postioning senser .or i could be an intake gasket leak. mine does the same thing but it a turbo with no waste gate vac line.
Posted on Sep 15, 2008
  • 5676 Answers
SOURCE: 96 grand marquis won't start
The switch at the throttle is called a TPS, throttle position sensor. It is fairly easy to change, has 2 screws and 1 electric connector. When you put your foot on the gas pedal a cable running to the Airhorn will move a part which the TPS is connected to.
The TPS is a variable resistor and it is possible to be bad on one end and good further up. Now if replacing the TPS does not solve your problem, something else is slightly off that can be compensated with the footpedal. You may have low fuelpump pressure or a low Vacuum pressure level contributing to the starting problem.
Both Autozone and Oreillys can scan your car and they do it free. You may find another component is bad. The scans will help, but do not cover every system. The TPS is not an expensive part and it is where I would start.
I hope this is helpful to you. Thanks for using Fixya.
Posted on Dec 30, 2010
raw_deezel
SOURCE: Sebring will die when i press on gas pedal
have you checked the stributor if present or the injectors on the fuelpump?
Posted on Apr 25, 2012
  • 100 Answers
SOURCE: 1990 toyota pickup v6 starts-up step on gas pedel motor then dies
does thr engine rev upwhen started than idels back down.try idel control switch and map sensor
Posted on Oct 27, 2012
Idles fine,,push pedal and it dies
Idles FINE but stalls when pedal is pressed - Yamaha Rhino Forum ...
www.rhinoforums.net > ... > Technical > Engine
Feb 6, 2012 - 9 posts - ‎5 authors it starts fine but stalls when I press the gas pedal. what do I need to check now. Sponsored Links. RhinoForums.net is the premier Yamaha Rhino UTV/ATV Forum on the internet. Registered ... Does it seem to Idle smoothly and does it start right back up after it dies? Does it .... astro push accelerator and dies.
Oct 07, 2015 | ATVs
Car starts but dies
Check your TPS ( throttle position sensor) and MAP (manifold absolute pressure) and change your fuel filter
Mar 28, 2014 | 2004 Chevrolet Malibu
A part for coleman go kart
well if it's the wire that goes from the throttle pedal to the engine it's called the throttle cable assy... if it's not then you need to explain where it hooks up at both ends... or take pictures
Dec 30, 2013 | Coleman Powersports Coleman CK150 150cc Go...
2009 mini cooper clubman with sport button-delay when press on gas.
The fuel pressure and fuel system needs to be inspected.
I suggest you few helk links.Click the link below and follow its troubleshooting procedure:------------------Pushing on the gas pedal, but the car slows down? Gas pedal to the floor and the car slows down? http://technoanswers.blogspot.in/2012/02/pushing-on-gas-pedal-but-car-slows-down.html
Car dies when gas pedal is pressed? http://schematicsdiagram.blogspot.com/2011/12/car-dies-when-gas-pedal-is-pressed.html
Car won't start without hitting the gas pedal? http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-without-hitting-gas.html
-------------Car only starts when gas pedal is pressed? http://technoanswers.blogspot.com/2012/01/car-only-starts-when-gas-pedal-is.html
----------1999 Ford F-150 Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
----------Delay starting on Toyota Prius? http://schematicsdiagram.blogspot.in/2012/02/delay-starting-on-toyota-prius.html
These will help.
Thanks.
Nov 26, 2012 | Cars & Trucks
Oct 27, 2012 | Cars & Trucks
1986 hyundai excel gl
Try changing the fuel filter. You may want to consider a Weber carburetor conversion. That Asian carb is old
May 24, 2017 | 1986 Hyundai Excel
Accellaration problem
Sep 04, 2008 | 1989 Pontiac Sunbird
Sport & Outdoor - Others Logo
87 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
