Question about Omega 6147 Sewing Machine
Omega 386 xom is breaking thread - Omega 6147 Sewing Machine
I have a Necchi Omega 6147. How can I adjust the drop-in bobbin to use upholstery thread to sew heavy fabrics or leather?
You would need to adjust the tension screw so the tension is looser than usual. However, remember to mark the setting BEFORE making any adjustments so you will know where to return the original setting.
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
Feb 10, 2017 | Necchi Sewing Machines
Correct bobbin size for a Necchi Omega 6030
You can use either 16 or 16J. If your threads are loopy on the bottom side of fabric, the problem is either your needle thread tension is too loose or you have a snag in your needle plate where you have broken a needle. Check needle plate and clear snag if any. Then tighten up your needle thread tension until both needle and bobbin threads are in middle of fabric.
Jan 30, 2015 | Necchi 6030 Mechanical Sewing Machine
How to thread and set the tension on my Omega sewing machine model 3730 m please help
http://www.howcast.com/videos/214712-How-to-Thread-a-Sewing-Machine
Jul 31, 2014 | Omega Sewing Machines
Omega Serger 303 SI thread keeps breaking. How to fix it.
Make sure both needles are new and THE SAME SIZE. Look if there are any needle punctures onthe needle plate and stich fingers.
Machine Tech
Oct 22, 2013 | Sewing Machines
How to thread sewing machine omega
Necchi makes omega...
Order your manual here.
http://www.allynint.com/access.htm
Aug 29, 2012 | Omega Sewing Machines
I have an omega 3730m sewing machine and i find that when i am sewing, the stitching underneath balls up nad is not tight. i tried to adjust the tension but nothing seems to work. any suggestions?
I find that re-threading both top and bottom threads fixes the problem. Sometimes the thread has not gone through the tension springs properly. try a new needle too.
Dec 08, 2010 | Necchi 6015 Mechanical Sewing Machine
I cleaned my machine and now the bottom thread making huge loops and it is jamming up. i have a necchi omega 6015
have you cleaned under the needle plate
change the needle
make sure the thread has not come off the thread take up lever
some thread & needle don't work togeather--try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 21, 2010 | Necchi 6015 Mechanical Sewing Machine
How to thread omega model 3730m?
dear Friend
I need the sewing manual or threading sequence for Omega sewing machine model #3730M.
Cheers
Roxanne
Apr 27, 2010 | Euro-Pro 7500XH Mechanical Sewing Machine
Operations instructions needed for an Omega sewing machine
The company that handles OMEGA sewing machines is Euro-Pro. Just enter the model. This is how I got mine for a 7100.
http://www.euro-pro.com/europro/default.aspx
Apr 16, 2009 | Sewing Machines
Open Questions:
See all Omega 6147 Sewing Machine Questions
Omega 6147 Sewing Machine Logo
150 people viewed this question
Top Omega Sewing Machines Experts
Ruth summersides
ray gallant
Are you an Omega Sewing Machine Expert? Answer questions, earn points and help others
