Question about Home
Water over flowing from the toilet - Home
    President:
  • 1,607 Answers
It must be clogged. Try using a plunger first. If thayt doesn't work, consider using a "toilet snake". Simply place the end of the flexible cable into the toilet bowl and begin unwinding. The cable will extend round the bends in your trap way dislodging any clogs as it goes. If you come to the point where you feel some resistance, you will need to rewind the cable back into the bowl and remove anything that comes up with it. Repeat this process until your toilet runs clear.
Posted on May 18, 2011
1.6 toilet will not fill
Make sure the water valve to the toilet is actually letting water into the fill valve. Turn off valve, remove from fill valve, run water into a pan to see pressure and confirm water flow. If water flow and pressure good, replace the fill valve.
Aug 12, 2014 | American Standard Home
What is a flush cylinder
It is really the valve that opens up to let water flow through the bowl when activated by the flush lever, to flush the toilet. it should prohibit water from flowing after the toilet flushes.
Aug 03, 2014 | Kohler - Toilet - One-piece - Santa Rosa -...
Why does water flow from toilet when flushed into bath tub.
Hi bubba
You have a blockage between the toilet and the septic tank or drain that is causing the water to flow into the tub
Bud
Apr 16, 2013 | Kohler Cimarron 2-PC Elongated Toilet with...
The toilet tank takes a long time to fill up
if the water keeps flowing then try replacing the flapper if it still flows then the fill tube gasket or tank to bowl gasket need to be replaced.
Mar 23, 2013 | Home
Takes a long time to fill tank
You need to replace the gasket in the fill valve if it is a problem that was not there when it was new. If it is new? Check the water flow from the supply line to the toilet. Turn of the water to the toilet, remove water line from toilet, run water into a bucket to check flow. @ the bottom of the fill valve where the water connects, on the inside there may be a screen that in plugged
Dec 12, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
When I flush my toilet, the water in the bowl rises all the way to the top like it is going to overflow but stops just short of over flowing. Then it drains out but very LITTLE water stays in the bowl. ...
You have some type of obstruction in your drain. Try a plunger when the toilet is still fairly full. The reason the water level is so low is the toilet was finished filling when the water went all the way down. a714b1a.jpg
If you can't get it open with a plunger, a closet auger works well 7163d19.jpg
Aug 17, 2010 | American Standard Cadet 3 Right Height...
Toto Dorian toilet does not flush clean
Don't know if you have calcium build up problems. If you do you could pour a calcium cleaner into the tank to try and clear up the problem. This would be the only way to possibly clean the enclosed area. Good Luck. Jeff
Apr 05, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Toto Toilet - no water flow to refill tank after flush
Remove the tank lid and look at the fill valve. Is it a yellow valve?
This fill valve is common on the Toto Toilets and can easliy plug with debrie.
They can be disassmbled and cleaned. however, I usually just replace the valve with Fluid Master Fill valve.
You will also want to check the water coming into the toilet by turning off the water that supplies the toilet and disconnecting the water supply line. After removing the water supply line turn on the water at the valve to make sure that the water is flowing properly. Check the supply line also to make sure it is not plugged.
Be sure and place a small container to catch the water that will come from the valve. A towell will also help from making too much of a mess.
If the Supply line and the valve are clear the problem is in the fill valve.
The G-Max system denotes the Flushiing system which is a 3" flapper that allows the water from the tank to flow into the bowl quicker.
Good Toilets!
sanray
Jan 05, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Toilet not flushing properly
there are allot holes around rime inside they get clogged over time because water quality very hard to get there to clean best bet replace toilet
Dec 28, 2008 | Jacuzzi Bath Era BK37 959 White toilet...
Home Logo
62 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
