Question about Lexmark X2470 All-In-One InkJet Printer
How do i replace my ink cartages - Lexmark X2470 All-In-One InkJet Printer
  • Official Brand Answer
  • 3,344 Answers
Removing a used print cartridge:
  1. Make sure the printer is on.
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the lever to raise the cartridge lid.
  4. Remove the used print cartridge.
To install a new cartridge, remove the sticker from the back and bottom of cartridge. Insert the new cartridge in the slot. Close the lid. Lift the scanner unit, press the scanner support back until it slides into the slot, and close the scanner unit.
Source: Lexmark X2400 Series User's Guide
Posted on May 31, 2011
How to fix 5B00 error code canon ip2770 continuous ink
this is the ink cartage problem you need to replace ink cartage
May 11, 2011 | Computers & Internet
It will only scan not print
If you refill you Ink Cartage on this Please make sure the Ink is primed. If you touch a paper towel to the bottom of the ink cartage and the tale stays dry It is the cartage.
If that is ok Make sure that the door and the contact(If you can see it) Is closed and in good shape
Jun 24, 2010 | HP PSC 1315 All-In-One InkJet Printer
Suddenly it wont priny black, have tried to replace with i new. Paper is offcourse removed, but it wont print black. Have run all cleaning programs. Could it be under the ink tank? How can i get to it?
Maybe you need new black ink cartage, or new color if its one pint cartage. follow the procedure under the bonet to change the ink cartages,. hope this helps
Nov 30, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
The dont know how to switch the ink cartages
The large black ink cartridge is used for printing text and other general black printing. The small black cartridge is used when printing graphics and other fine details. Each cartridge feeds to a different part of the print head, which is used for different purposes.
May 27, 2009 | Canon PIXMA iP3600 Photo Printer
Ink Cartage CYAN for Brother Printer Model MFG 440 CN replaced
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 07, 2008 | Brother MultiFunction Center MFC-440CN...
Epson CX5500 does not see cartage replacements as being full ,so will not print !!
Ok
If your printer cartages are full filled and will not able to print. Please follow the following steps-
1- Uninstall the printer driver and disconnect printer from PC.
2- Download the latest Epson Stylus CX5500 Driver 6.5b Windows 2000/XP  from given web link
    http://down3.driversdown.com/Printer/CX5500_W2K_65bE.zip
3- Install the printer driver from downloaded file and connect printer as setup ask.
4- Now remove the cartages from printer and clean the connecting points & inkjet point by soft cloath.
5- While cleaning the cartage's injet points you will must see the ink on cloath. If ink does not see on cloath may be your cartages are dry. try to clean them by little force.
6- connect the cartages to printer. tyr to print.
It will help you.
Nov 22, 2008 | Office Equipment & Supplies
Ink cartridge
once install a demo cartages then printer will be inilitize fullely and it will except your old cartages also
Aug 01, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink cartage replacement
could you please give us the brand name and model no.?
Nov 13, 2007 | Office Equipment & Supplies
Lexmark X2470 All-In-One InkJet Printer Logo
134 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
