Question about Vehicle Parts & Accessories
I put on earlier that i have a 95 Volkswagen jetta glx vr6 i recently put on a new master cylinder for the clutch and now when i drive the car 1st gear is where reverse should b and i have no reverse any ideas what is wrong?
    Scholar:
  • 113 Answers
It looks like they messed up with the gear shift linkage, they will have to readjust it, that's why you are not able to put it into reverse. That's an easy fix but you still gonna have to take it to the mechanic.(It doesn't take more than 10 minutes to readjust)
Posted on Jul 16, 2011
1998 Volkswagen Jetta. Where is the clutch spring and how do you replace it?
Is your jetta a glx with a 2.8 vr6 engine or a 2.0 4 cyliner?
Jan 10, 2014 | 1997 Volkswagen Jetta
1996 volkswagen jetta glx vr6
I am sorry but these manuls are not free to share as they are copyrighted by VW.
May 07, 2013 | Cars & Trucks
Ignition coil firing order for 2000 VW Jetta VR6
Jetta GL & Jetta GLS (two versions with 2.0 l and 115 CV engine)
2000 Volkswagen 2.0 liter SOHC L4 (AEG)
Jetta GLS VR6 y Jetta GLX VR6 (2.8 l VR6 and 200 CV engine)
2000 Volkswagen 2.8 liter DOHC V-6 (ATQ)
Hope helps.
Mar 22, 2011 | Volkswagen Jetta Cars & Trucks
Where do I add clutch fluid to a 1995 volkswagen Jetta glx?
There are two 5 speed manual transmissions possible in your vehicle. One of them is controlled by a cable. (there is no fluid) For the other one, you would put the fluid in the clutch reservoir which would be mounted just above the clutch master cylinder in the engine compartment. The clutch master cylinder is directly in front (on the engine side of the firewall) of the clutch pedal.
NOTE: If you are having to add fluid to a hydraulic clutch, you have a leak in the system that needs to be fixed. You should never have to add fluid to the clutch reservoir.
Jan 16, 2011 | 1995 Volkswagen Jetta
My transmission on my 1995 vw jetta lll glx vr6
the clutch may burn out on those gear, check the fluid if it smell burn
Feb 24, 2010 | 1995 Volkswagen Jetta
95 v.w. jetta 3 4 cyl. clutch adjustment ????
there is no adjustment. may have failed hydaulic master or slave cylinder. also I would try bleeding 1st they may have opened system when they did clutch.
Mar 23, 2009 | 1995 Volkswagen Jetta
Can't shift when car is cold
I have a1998 VW jetta vr6 glx with the same problem and living in New England it gets really cold, but i did some research and it worked.... With the car in neutral and the E-break engaged, reach down and pull up on the clutch pedal, thus "resetting" the tension in the cable, it will be a bit higher on your foot and the release/engage point will be higher as well but i did this when it was 10*f and i could not get any gear, after pulling up on the clutch, shifts with ease,,,, such a relief
Sep 10, 2008 | 1998 Volkswagen Jetta
2000 VW Jetta VR6 My check engine light started flashing. My car was idleing very rough and missing. The parts store checked and the code showed misfire 1. We replaced the spark plugs. It runs a little...
You may have a bad coil pack - try moving two of them around and see if the misfire follows the coil pack or stays at the same cylinder. If it follows the coil pack, get a new one. If it stays in the same cylinder, inspect your spark plug wires and make sure the plug is gapped correctly.
Aug 08, 2008 | Volkswagen Jetta Cars & Trucks
Vehicle Parts & Accessories Logo
85 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
