Question about Acer 15 LCD PANEL FUJITSU Monitor
Please help me to solved this issue "No Power" i found burn resistor to the power board any one know the value of resistor R504.
  • Renato Valera
    Renato Valera May 18, 2011
    im very sorry , the unit is fujitsu model:VL-152SEW , thanks for the reply
  • 11,361 Answers
Please repost with make and model. Is it ACER or FUJITSU? Hard to help without details for us to do the research.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on May 18, 2011
Hisense LCD32V77
it must be a power supply malfunction; if you`re not a tehnician , please contact the nearest repair shop.
Nov 18, 2013 | Vizio L32 32 in. LCD HDTV
I have a Westinghouse LCM 19v7 monitor that stays on for a few seconds and picture goes off. I know about the capasitor replacement but there is another conponent that I need to replace. It is the pow
That is the correct value. That resistor just gets very hot and discolors the PC board around where it is soldered. You should be able to remove all of the old solder and scrape the resistor leg to get it bright, resolder the leg to the copper pad and you should be good to go.
Oct 09, 2012 | Westinghouse LCM-19v1 Monitor
I need to know the value of the Resistor "R1" in
Let us use a bit of logic to resolve this... I have an Axiom but it would be a lot of screws to take out to get to the part... so let us think about this. The resistor value starts with a "1" and we know it is 5% tolerance (gold). we know the resistor burnt up with likely 5 volts on it... Value could be 1000 ohms, however the voltages present (12 volts max) would NOT have burned up a resistor of 1000 ohms. The USB area is mostly 5 volts and across 100 ohms is only a quarter watt... not enough to really burn up a resistor... First thing is to MEASURE that the resistor s open... in spite of being burned, it MAY still be OK... these resistors now usually either open or remain close to their value. The resistor ALSO may be a fusible resistor intended to act as a fuse... Is the resistor open or not? is it near a resistance with a "1" as the first digit? If it is not open I suspect it is not all of the problem. In that case, look for a burned circuit trace on the board. If it is open, then MEASURE the voltage across the resistor with the power applied. If you find 5 volts, then it MIGHT be a 10 ohm used to limit the USB current to 500ma. Get back to me with your findings... I have unraveled many of these things...
Jul 12, 2011 | Music
Resistors R504 and R507 are burned, values are unknown.This is a Boka color monitor.I need the values of the resistors.
What is the serial number of your monitor!!
And which parts that's burned, can you tell me the exact locations...
Oct 16, 2009 | Computers & Internet
Please help me about my power supply it is compaq (24 pins)model no. ps-7231-6cf..the resistor is burned..i dont know color code or the value number of my resistor..only i know is in the circuit of my...
sir
pls dont try it your self. you should better call a repairman for it. He will if possible repair it or you would have to buy a new one.
thankyou for using fixya
dont forget to rate the solution
Mar 09, 2009 | Computers & Internet
Burned resistors r319,r320
ampmann,
hi mate, i might be able to help you but i need to know the exact model number and brand of your dvd player.kindly email it to workshop.fungkuei@vanuatu.com.vu
cheers,
markiez23
Jan 15, 2009 | Panasonic Televison & Video
Samsung projection tv convergence problem
I was just working on replacing my stk's and was wondering if you could tell me what value the resistors are? Here is my previous post if you would like to see it. http://www.fixya.com/support/t191186-blue_out
Sep 12, 2007 | Samsung HCL4715W 47" Rear Projection...
Computers & Internet Logo
64 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
