Question about Dryers
I have a frigadaire gle02152eso front load dryer that is not heating up . it just blows cool air .i checked the circuit board on another dryer and it works great .any help would be great
  • Dryers Master
  • 7,482 Answers
Hi ngbigboyford...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
Posted on May 18, 2011
DRYER HEAT TURNS OFF AFTER ABOUT 30 MINUTES
  • Get on with replacing the gas valve coils shown to you in the previous link, it will take care of your problem.
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Jun 07, 2008 | Whirlpool LGB6300 Gas Dryer
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 02, 2016 | Heating & Cooling
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
No heat or air blowing inside unit
Are you sure you dont have a clogged Dryer Vnet?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Feb 09, 2014 | Samsung DV419AEW 7.4 Cu. Ft. Electric...
I very recently-9/28/13- purchased an LG clothes dryer-model #DLE487OW. A breaker was kicked and since the electrity was restored, I am getting a check filter message with cool air only blowing in dryer. ...
Call LG people before you call the service man.
Really, you have no heat. Check out the heating circuit...heater, t/stats; vent. etc. Something is sensing that the filter is blocked when it is not....check air flow.
I doubt the board is a problem at this point.
Oct 18, 2013 | LG Dryers
My maytag front load dryer turns on and runs,it does not blow any hot air
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Jul 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer not heating
Jan 08, 2009 | Frigidaire Dryers
Gas dryer lgr 8648
Back in June I replaced the gas valve coils and that fixed the problem. It appears that when the coils are begining to fail, they'll work only when they are cold. After the dryer is up to full temperature the coils will not open the valve when more heat is needed...at least not until the dryer cools down.
I had this same problem with my furnace flame sensor. It failed in a way that it would only work when it was completely cooled down. Troubleshooting revealed that the furnace was failing at the 5 second "wait for flame sense". At that point the flame would go out and I could not restart it until everything cooled down. Thanks for all the help on this.
Jun 26, 2008 | Whirlpool LGR8648 Gas Dryer
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Dryers Logo
208 people viewed this question
Top Dryers Experts
