Question about Kenmore Elite Stainless Steel 24" BuiltIn Dishwasher with TurboZone Rotating Spray Jets 13103
Kenmore dishwasher 655.16033401..the 2 top spay arms are not getting water to them..I put a bowl on the top shelf and does not fill with water at all..water is getting to the machine fine and the inside looks fine..no crud...
  • 1462 Answers
SOURCE: Dishwasher not getting water into spray arm, so no clean dishes
two possibilities: open door when in use. check if water is coming out of the spray arms. if it is and at a good rate, then the problem may be the spray arm jets blocked. the spray arms are only rotated by water coming out of the angled jets at their end or is the main circulating pump running ok?
Posted on Apr 02, 2007
catriver
  • 878 Answers
SOURCE: Top rack arm doesn't spin.
matt, did you get down to the chopper screen? If that screen is clogged the flow to the upper arm will be restricted. Check out the pic, Catriver
Posted on Sep 29, 2007
the dr
  • 447 Answers
SOURCE: Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Posted on Nov 16, 2007
watugot
  • 290 Answers
SOURCE: dishwasher - no spray arm action
If it is filling with water properly then it sounds like the chopper screen is clogged so that water isn't getting into the pump. You can remove the top of the pump housing and get to the screen and chopper blade to inspect it. Go to sears.com, click on parts and enter your model number and you can view a diagram of the pump parts to help in disassembling it.
If the pump is not clogged then you have a problem with the impeller or motor. If this is the case you can replace the entire sump assembly just about as cheap as replacing individual parts of the pump.
Post back with any questions.
Thanks, Mike
Posted on Feb 16, 2008
  • 3 Answers
SOURCE: GE dishwasher Quiet Pro 3 middle washing arm
Try unscrewing it from the bottom, remove it and give it a clean. If it is full of food it will not turn.
Check the funnel on top of the basket is free of food too.
Posted on Jun 11, 2008
On my Kenmore model 665.13489K900, it does not clean well and appears to have a problem with getting or circulating water inside to all areas, especially the top shelf.
Check the center wash arm assembly. If the center wash arm isn't getting water, all of the dishes in the upper rack will come out dirty. Check to be sure the center wash arm assembly is mating properly with the water supply nozzle in the back of the dishwasher. Also check to be sure the little holes in the center wash arm aren't clogged or blocked. * Run empty cycle using vinegar and baking soda lime scale problem will resolve.
Nov 13, 2013 | Kenmore 15912 Built-in Dishwasher
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Top water sprayer not getting water. does not clean dishes on top shelf.
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 06, 2010 | Kenmore Dishwashers
My top shelve sprayer arm does not spin
its just clipped over the cap remove and clean also check the seal is not damages on the pipe that goes into case.
Jun 18, 2017 | KitchenAid 24 in. KUDI02IRBS Stainless...
The dishes on the top rack are not getting clean.
sound like circulation pump test by putting a glass on top shelf to see if gets filled. or let wash the check the top for water drips
Feb 24, 2010 | Kenmore 16602 / 16604 / 16609 Built-in...
Top rack not cleaning properly, not sure if top spay arm is working ?
Ensure that the spray arm is movable. Inspect the spray holes in the top spray arm. If clogged, clean the openings. If no clog, position the spray arm in a certain position (e.g.: arms facing front and back). Then activate the dishwasher for a minute or so and open the door to determine if the spray arm has moved. If not, there may be an issue with the water feeding to the spray arm (typically via the water pump, etc.).
Feb 19, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishes are not clean
HI, there are three different reasons why this will occur in this type of unit. inspect these areas carefully.
1. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
2.Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
3. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher. Make sure the temp is proper.
Jul 19, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Glasses do not get cleaned
HI, i recommend inspecting these areas below to combat this issue.
Not enough water
Clogged spay arms
Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Jun 18, 2009 | Maytag Dishwashers
Kenmore Elite dishwasher not cleaning well and leaving dark stains on the dishwasher walls. water pumps in to correct level and pumps out. First cup of soap the water is just warm. Second up its hot and...
Check the following to address this issue
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
3. Clogged spay arms
4. Water temperature is too low
5. Not enough soap
6. Smoky film on dishes and glasses
Jun 04, 2009 | Kenmore 24 in. 16049 Built-in Dishwasher
Dishwasher
basic checks:
is water entering into the machine.
is it hot.
is it being heated during pre-wash
is the soap being dispensed
is the pump running when cycling?
do the arms turn freely?
you mentioned the top and bottom shelves. are there places where the dishes 'are' being cleaned?, or are you meaning that in general they are not being cleaned at all?
most of the above indicators are observable by stopping the wash cycle from time to time in various modes.
to see if water is being pumped at all, put a bowl on the top and bottom shelf, and nothing else. if there is water in it after it cycles then the pump is moving at least some water.
start with these observations and please report back
good luck
mark
Dec 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Elite Stainless Steel 24" BuiltIn Dishwasher with TurboZone Rotating Spray Jets 13103 Logo
60 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
