Question about Canon PIXMA MP600 all-In-One InkJet Printer
What is error code 6AOO - Canon PIXMA MP600 all-In-One InkJet Printer
  • Canon Master
  • 4,338 Answers
The 6A00 is a Canon generic code for paper path jam. Somewhere in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if it is jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs Incidentally, the 6A00 error pertains to all Canon printers made in the last several years; it is not just used in one model. And it is always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has an electrical pump to milk the print heads and test for ink flow. Move back and forth several times (with the power off)
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on May 18, 2011
Have canon mp610 printer....wont print . msg "service error 6AOO " Have switched off printer , does not correct fault. thanks
Welcome to Fixya.
Here are the items that you can try to resolve this problem :
  • Uninstall the printer driver via (Windows) : Control Panel/Remove programs
  • Restart your computer
  • Download the updated driver from the below link. Choose your operating system then download until it's complete.
  • Launch the setup application after download and follow on-screen instructions
  • Restart computer
Canon Updated Driver
Thanks for using Fixya.
Jul 06, 2011 | Canon Office Equipment & Supplies
Canon Pixma MP600. Have an 6AOO error problem. Tried various corrections, still no luck in resolving it.
Thanks, Joe
Feb 03, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP830 Error Code 6AOO
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
Jul 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
ERROR 6AOO
With thanks to anonymous canon tech Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
May 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error 6aoo can't clear it
Take off the side and top covers off to reveal the print head. There is a device that slides back and forth and acts like a window cleaners squeegie on the printhead. This mechanism might be stuck at its full extention rather than being back at its starting position. Turn on the printer and make sure that it moves if it doesn't push it a little bit not to hard. It may have been blocked from dry ink. Do not force any part of the covers. There are little arrows in the plastic indicating where the snap locks are, stick a flat head screw driver in to release. Trial and error will release the right ones first. Some are hidden under or on opening covers so keep looking. Use damp rag to clean. If you have no experience with this type of thing I would suggest going to a canon repair shop.
HAVE THE CONON PIXMA mp830 ALL IN ONE PRINTER GETTING
thank you have a nice day
May 02, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
HAVE THE CONON PIXMA ALL IN ONE PRINTER GETTING THE 6AOO ERROR CAN'T PURGE THE EXCESS OR DO ANYTHING,i TURN IT OFF, UNPLUG THE POWER DISCONNECTED FROM PUTER BUT AFTER A FEW SECONDS THE ERROR SHOWS AGAIN...
With thanks to a canon tech Ok Well again I will repeat this answer with a titch more detail.
Switch printer on,just get grinding noise on right hand
try
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 13, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
MY PRINTER
strip the purge unit ( cleaning/waste unit ) out. its got stuck of all the waste ink inside the purge unit that got dry. the machine is thinking that there is blocking of paper or it cant get the printer head to its home posision. and also clean the carrige unit bar. normally this is done by a printer tech.
Nov 07, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Error code 6A00
TThere is a prblem with the carriage lift mechanism.
Probale causes
1.PR Lift shaft assembly
2.Sheet Feed Unit
3.Logic Board
Send the printer for repair ,
Apr 21, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
85 people viewed this question
old marine
old marine
