Question about Black & Decker Pivot Plus Cordless Drill/Screwdriver
Chuck is stuck , can't get it unlock to tighten around a new bit
    Problem Solver:
  • 15 Answers
Could be a dying battery making it not be able to open itself cuz theres not enough juice, try charging the battery and do it or get some wd-40 and spray it around the chuck and let it drip over the bit into it.
Posted on May 19, 2011
Psb 650 re
You have wound the threaded section of the jaws fast the thread in the case so sorry the chuck is broken as the teeth will be damaged. Best replace it with a new chuck
Jun 18, 2013 | Bosch Drills
The chuck on my new makita drill is stuck with a drill bit in it. It won't open back up.
This is caused by tightening the chuck using the drills power, if you clamp the bit in a vice and using a pair of multi grips on the chuck in an anti clockwise direction gently bounce the grips and after a few tries it will undo, don't use too much pressure or try to unwind it in one move or myou will damage the chuck sleeve
Oct 16, 2012 | Makita Drills
Mybrand new RZ20 keyless chuck will not close around a bit.
If a large enough drill bit is inserted too far so it bottoms in the chuck, the jaws run into the bottomed shank and will not close beyond a certain point due to the interference. If you hold the drill bit out about 1/2 inch from the bottom, the jaws should close on the bit. I assume you have tested the chuck without a bit to verify they can close.
Feb 15, 2012 | Drills
I have a rotozip 20 and the new keyless chuck just does not work. Am I doung something wrong?
Try not inserting the bit all the way in until it bottoms- it should not bottom. Also make sure it is the correct size range for the bits you have.
Feb 10, 2012 | Bosch Drills
A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Jul 19, 2010 | Bosch Drills
Bit tighten stuck open
If you mean the chuck jaws seem stuck open, spray around them with some penetrating oil or spray like WD-40, RP-7 or similar and let sit for a couple hours... Then you can tap around the chuck body with a light hammer or spanner etc... just lightly tap... Then if the chuck has an arbor lock to prevcent it from spinning, be sure that is engaged then try to release the chuck jaws. Sounds like they are stuck open through tight friction or rusting on the inside edges (that you dont see). Be careful not to leave them in the fully open position when stored as this is exactly what can happen!
Mar 31, 2010 | Makita 6304LR 1/2" Chuck Electric Drills
Black and Decker corded drill won't tighten around a bit.
the chuck sounds like it is bad or maybe stuck from rust, what you can try and do is spray some WD-40 on the jaws and then try and holding the collar with a glove and run the drill SLOWLY in forward/reverse and see if it loosens up if not you will need a new one.
Jan 14, 2010 | Black & Decker Drills
How to fit drill bit to drill
it depends what chuck (the part the drill bit goes into) on the old ones you had a chuck key that slots into the hole on the side and connects to the teeth to tighten the chuck around the bit, keyless chucks are tightened by hand instead of the key and the SDS have a collar that pulls down, you have to turn the bit so it then slots in then just release the collar to fix it in place good luck!!!
Jul 30, 2009 | Drills
Black & Decker Pivot Plus Cordless Drill/Screwdriver Logo
249 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
