Question about Nordic Track NordicTrack Commercial 1500 Treadmill
Removed visible screws from tab holder but hood does not come off
    New Friend:
  • 326 Answers
Down load manual from web .It will show you where they are.
Posted on Dec 08, 2013
Change batteries on Oracode 660K
there should be a way to remove the inside cover to replace the battery , pretty sure its a 9 volt .
you may have to press in the retainer on the lever to remove it and then the cover plate should have a spot thats visible to use a small screwdriver to pop off the inside plate giveing you access to the battery compartment
Dec 20, 2014 | Ilco KABA Oracode 660K Lock for Rental...
Replace cord in Rowenta Iron
0) Unplug the iron.
1) Remove the (2 or more) screws holding the plastic bottom plate (that the iron stands up on).
The screws are likely to be #20 Torx "Security" screws -- for which you will need a special bit for your nut/screwdriver. A kit of various sizes of Torx security bits will cost you about $10.
2) Remove the plastic cord-holder assembly from the iron.
2a) If the cord-holder is held in place with screws (you are in luck!), simply unscrew them. If you see no screws, then it is being held in place by several (probably 4) plastic tabs that you must simultaneously release. This makes the job much more fiddly. Use a small/medium blade screwdriver to carefully bend and hold each of the plastic tabs out of the way of the latches. You'll need one screwdriver per tab/latch! Take care not to break the tabs...
2b) Carefully wiggle/pull/work the cord-holder assembly out of the iron taking care not to bend the pins of the integral plug (inside the iron) that are seated in the cord-holder socket. Basically, with the iron resting on its metal surface, pull/pry/wiggle the cord-holder straight upward until the cord-holder (socket) pulls free of the (3 or more) stiff wires that function as a "plug".
3) Note that there are 2 crimp-on connectors attaching the 2 wires of the cord to the rest of the wires in the iron. Take a photo of the wires and jot down notes of which wires are connected together. NOTE: One of the cord wires is "neutral" and is attached to the wider spade at the plug end of the cord. Typically the "neutral" wire is marked with a white stripe or ridge down length of the cord. Don't mix up the "neutral" wire and the "hot" wire when you re-connect them in a later step!
4) Cut off the crimp-on connectors and separate all the wires.
5) Remove the cord from the system of zig-zagging "strain-relief" notches that hold the cord securely in place. You may have to remove a small plastic clip first.
6) Cut off 6 inches of the cord. (Or supply a new cord, if the cord has been shortened too much in previous repairs.) This eliminates the broken section wire within the cord. You may use an ohm meter to verify that both wires have a low resistance again (less than 1 ohm).
7) Route the cord back into the "strain-relief" notches in the cord-holder. Don't forget the plastic clip (if there was one)...
8) Strip all wires, exposing about 3/8" of copper on each.
9) Referring to your notes and photo, re-connect all wires using proper-sized plastic wire-nuts for secure connections.
10) Re-attach the cord-holder to the iron body. Make sure you line up the stiff wire pins with the cord-holder socket. Push the cord-holder into place and secure it (via screws or snap-in-place plastic tabs).
11) Replace the plastic cover, taking care to position the wire-nuts and wires to allow it to drop into place without forcing it. Secure the cover with screws.
12) Plug in the iron and test it out!
Mar 23, 2014 | Rowenta Irons
Toshiba Tecra M2-S630 cmos clock battery location
It's under the Keyboard. It is referred to as an RTC battery. (Real Time Clock)
1) ALL power removed from the laptop. AC adapter (Charger) and Battery.
2) It would be in your best interest to buy, and wear an ESD wrist strap.
(Electro Static Discharge)
Connect the alligator clip to a good ground source.
The price of an ESD wrist strap averages from $3 to $12.
Carried in a multitude of stores.
Example of an ESD wrist strap,
http://ultrastatinc.com/ESD_Wrist_Straps.html
[ Your body carries Static electricity.
Static will fry out (Short Circuit) the hardware components inside a computer.
You may not see it, or feel it.
Your computer will. POOF!
I connect to the metal frame of an empty desktop computer case ]
3) Keyboard Removal:
Laptop closed turn the laptop over. There is 1 Philips screw to remove down in the middle of the Battery Compartment, towards the inside edge. (Battery removed)
Turn the laptop over to it's normal position. Open it.
There is a slim strip of plastic that covers screws that hold the Keyboard in place.
The name of it is Keyboard Holder.
It is right above the Keyboard on the LCD screen side, and below the strip of plastic that contains the Power On button, LED lights, and speaker ports.
(This strip of plastic above is part of a cover, that removes when the LCD Display is removed. It isn't an LED/Switch Cover, per se)
Ease your fingertips in-between the latches that hold the Keyboard Holder in place, and the computer, lift up on the Keyboard Holder.
[To explain:
The Keyboard Holder is a slim strip of plastic. Going along it are plastic protrusions, or tabs.
These tabs are on each side of the Keyboard Holder.
Starting from the Left side there are tabs on each side of the Keyboard holder.
Go towards the Right side approximately 2 inches, and there is another set of tabs.
There are 5 sets of tabs.
You need to ease up on the Keyboard Holder by placing your fingertips under it, in-between two sets of those tabs.
The plastic Keyboard Holder will slightly bend, and come up far enough for your fingertips. Then slide your fingertips towards one set of the tabs, and ease up. This part of the Keyboard Holder will pop up.
Keep going towards the next set of tabs, and keep popping the Keyboard Holder up.
Example: Start from the Left side. Come over about two inches from the Left end, ease up on the Keyboard Holder. Slide your fingertips towards the tab set on the Left. Pop the Keyboard Holder up. (The tabs will release) Now go to the right to the next set of tabs.
Once the Keyboard Holder is removed, there are two Philips head screws to remove, that hold the Keyboard in place.
These are at the ends of where the Keyboard Holder was. One screw on each end.
(You'll see plastic tabs coming from the Keyboard where the screws are)
Screws removed ease up on the Front of the Keyboard.
(Front is towards the LCD screen)
Turn the Keyboard over carefully towards you, lay it down on the Palm Rest Cover, (And Touchpad)
(Front of Keyboard comes up, and over towards you)
There will be a flat ribbon cable attached. You shouldn't have to disconnect it, or fully remove the Keyboard in order to access the RTC (CMOS) battery.
The RTC battery is similar to the normal batteries used in a desktop computer, (CR2032), but is smaller in size, and is enclosed in a plastic 'bag'. (Plastic holder)
There are two wires coming from it which end in a male connector. (White)
The male connector plugs into the motherboard of the laptop.
Use your fingernails to ease the male connector out.
This is a link to the Toshiba Satellite Tecra M2 Series Service Manual (Free)
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go down to the line that begins with Tecra.
Go across to M2, and click on it.
This is a 16MB PDF file. Takes time for it to download. You won't see anything happening until the file is almost fully downloaded, then the first page pops up.
(Medium speed DSL connection it took almost 2.5 minutes to download. May have to have a talk with my ISPO, lol!)
For questions about the above, or further questions please state in a comment.
Regards,
joecoolvette
Nov 02, 2010 | Toshiba Tecra M2-S630 Notebook
How do I remove the center front console, where coffee cup holder hood is?
Loosen the hex head set screw from the front of the Shifter knob. Pull it off, then remove the screws on the lower sides, as well as the ones hiding under the rubber cup holder. The entire assemble will now lift off.
Oct 29, 2010 | 2004 Chrysler Pacifica
Dyson dc11 replacing motor
DYSON DC-11 MOTOR REPLACEMENT
1. Remove dirt cylinders as normal
2. Using large flat screwdriver, remove airway splitter and hose
3. Undo 6 Torx screws from top and one at the back under tool holder
(Note that 2 front screws are shorter)
4. Make sure the screws are completely withdrawn
5. From the back, withdraw tool holder section
6. Unhook and withdraw hose holder section
7. Place large flat screwdriver behind the wheels and forcefully snap them off
8. Remove 2 more screws under each wheel
9. Cover now lifts off
10. Motor pod is now visible. Remove its 4 screws and lift its lid
11. Motor can now be lifted out. Disconnect its 2 wires
12. Remove the rubber base and transfer to the new motor
13. Connect wires, Red to Brown (Live) and Black to Blue (Neutral)
14. Make sure motor is correctly fits on its alignment studs in the pod and replace its cover and 4 screws
15. Replace top cover of machine, and the 4 screws under the wheels, but no other screws yet
16. Turn machine on its side and hammer each wheel back on - take care that no fingers are under wheels while doing this
17. Stretch and snap hose holder back into position
18. Slide tool holder forward into position
19. Replace the 6 screws into top section, and one into tool holder section
20. Replace filters, airway splitter and dirt cylinders, and the job is complete :D
May 22, 2010 | Dyson DC11 All Floors Bagless Canister...
How do I remove the stereo in my 97 mitsubishi diamante
You have to remove the center console there are four screws in each coner of it if you tri to remove it by releasing the two screws under the cup holder and you pull ti you will break the dash because there anre two screws that are not visible from the outside just remove the center console then youwill see a couple of more screw and you will get to the radio good luck and be patient.
Oct 05, 2009 | 1997 Mitsubishi Diamante
Audi A4 need to replace rear brake light on audi a4
Inside the boot is a plastic cap embeded in the boot liner. Remove the cap to reveal a screw. Undo the screw and the whole rear light cluster will come away in a sideways and not rearward direction to reveal all of the bulbs. Hope this helps.
Jun 04, 2009 | 2003 Audi A4 Cabriolet
How to change rear brake pads on audi a6 2006
Remove the tires, Remove the calaper bolts, (small heads on them 12mm or so) Remove calaper, Pads are setting in a holder. Lube new pads with litheum grease and place in holder. (look at old pads, one or both may have small metel tab on one end) If the new pads have the tab, put that pad where the old pad with the tab was. (ie. tab to the inside) Press pistion in with a 'C' clamp. If it won't go in easly, it may screw in. If the parking brake cable is hooked to the calaper, it probly screws in. Use large pliers to screw in calaper piston. Place calaper over pads and install bolts (lube bolts) Rember to pump brakes befor driving . to get a solid peddle.
May 20, 2009 | 2006 Audi A6
How do I replace the headlight assembly on a 2006 sebring?
  1. Remove the front bumper cover
  2. Remove the upper headlight housing mounting bolt and pushpin
  3. Remove the lower headlight housing mounting bolts
  4. Pull out the headlight housing assembly and disconnect the electrical connector.
Its pretty easy. Just raise the hood, see the two silver 8mm cap screws on top of the cross member that supports the radiator and fan assembly. Two screws on each side above the headlight housings. The outer screw is right next to the corner of the fender when the hood is raised. Remove the two screws, then the headlight assembly is loose. Just gently pull the headlight assembly forward enought to see the three lamp socket holders on the back side of the headlight assembly. From the outside corner to the inside are first, the parking turn signal, then the low beam lamp and finally the last, the high beam lamp. To remove the lamp socket, push the small plastic locking tab and turn the socket assemby counter clockwise about a half turn and remove the lamp. Now you can replace the lamp and install it back the same way you took it out. Don't touch the new lamp glass with your bare fingers. Oil from you skin will absorb into the glass causing the glass to turn dark and shorten the lamp life.
May 04, 2009 | 2006 Chrysler Sebring
KDS Valiant 671DP
first step: lay the screen fully down, then pry the two speaker covers outward. You may have to move the screen around to get them out.
second step: lift the center section containing the power button upward.
third step: loosen the two small phillips screws that hold the keyboard on.
fourth step: gently lift the keyboard up. There is a ribbon cable that plugs into a socket. There is a liftable tab on either side of the socket. Gently pry them up to release the ribbon cable and thus the keyboard.
fifth step: The hard drive is now visible. It is held in by three screws: one on the left and two on the connector. Once these three screws have been removed you can lift the drive out.
Take the old drive out of the holder and remove the connector. Install connector onto the new drive then secure into the drive holder.
Remainder of assembly is reverse of disassembly.
You may need to pry the ribbon tabs up to ensure that the ribbon cable seats down fully. Once the ribbon cable is down, push down the tabs to lock the keyboard in securely.
hope this helps.
Karl
Nov 09, 2007 | KDS Valiant 671DP Notebook
Nordic Track NordicTrack Commercial 1500 Treadmill Logo
118 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
