Question about Sylvania G-Netbook
Got netgear wireless router comcast modem on desktop and sylvania netbook with baud rate setting problem
    Genius:
  • 1,157 Answers
Hi jonathanw182,
Have you tried reconfiguring the Netgear Wireless router? The easiest way to resolve a connection problem is by reconfiguring the setting. Here's how to configure the netgear router.
1. Turn off and unplug your high-speed modem's power before connecting the device to your wireless router. Connect your high-speed modem to the Netgear wireless router . With an Ethernet cable, plug the Ethernet cable that was connected to your high-speed modem into the "Internet" port on the back of your Netgear wireless router. This port is located next to the wireless router's power port and is designated by a green color.
2. Connect your computer and the Netgear wireless router with an Ethernet cable. TUrn off your computer before connecting it to your wireless router. Connect one end of the short, blue Ethernet cable that came with your Netgear wireless router into your computer's Ethernet jack. Plug the other end of the cable into a LAN port on the back of your wireless router. Your wireless router will have several numbered LAN ports, designated by a yellow color. It does not matter which LAN port you use.
3. Turn on each device in order. First, power up your high-speed modem, then wait at least 2 minutes. Make sure that your high-speed modem's status indicators show that it has successfully connected to your ISP's server. Next, plug the Netgear AC power adapter into the Netgear wireless router and a power outlet. Wait at least 2 minutes for your wireless router to connect to your high-speed modem. You will know that it has successfully connected if all of the status lights on the front of the wireless router are on. Finally, turn on your computer.
4. Open your Web browser and connect to the wireless router's URL. In the address bar of your browser, type in the wireless router's address. The Netgear wireless router addresses are: http://www.routerlogin.net, http://www.routerlogin.com or http://192.168.1.1. You can use any one of these URLs. Press "Enter" on your keyboard once you have typed in the address.
5. Input the default user name and password. The default user name is "admin," and the default password is "password." The text boxes are case-sensitive, so it is important that you use lowercase letters.
6. Follow the Setup Wizard instructions. Once you log into the router, a Setup Wizard will load and ask if you want it to detect your Internet type. Click the "Yes" radio button, then click "Next." Once you have completed the wizard, configuration is complete, and you can access the Internet using the wireless router.
7. Configure wireless settings. If you have wireless devices that you want to connect to your Netgear wireless router, you must access your wireless settings. Log into the wireless router as described in Steps 4 and 5, then find and click the "Wireless Setting" link on the main menu. You can change the default SSID (wireless network name) from "NETGEAR" to a custom name, and you can change security settings such that a passcode is required to log onto your wireless network. When you finish changing your wireless settings, click "Apply." You must use this SSID and passcode to connect your wireless devices to your Netgear wireless router.
Please inform me if you still have the same problem after doing the steps above.
Hope it helps.
Thank you for using FixYa.
Posted on May 18, 2011
Getce6B1 screen comes up when I try to connect to a wireless server and then asks to change the baud rate setting
but without doing all of these steps is not possible?
I have only collergarmi with the wi-fi.
I do not have to configure the modem.
Mar 08, 2012 | Sylvania G-Netbook
What is the normal setting for the baud rate for the 7"Sylvania netbook?
YOu didnt post what model your netbook is, but i'll answer the best i can. Netbooks typically do not come with a modem, so you will most likely only be able to connect via WiFi or an Ethernet connection. If the netbook does by chance have a modem, it will be 56K.
Feb 09, 2011 | Sony Computers & Internet
Idk what 2 do w/ this iview netbook my daughter just got for christmas! i have comcast internet. that modem did go into my desktop but my desktop just broke so now comcast modem runs to a belkin wireless...
Under WAN settings: Enable Dynamic and Hostname : http://www.comcastbroadband.co.in (If above settings not works clone computer MAC address and assing to WAN port) You have to wait for 3min to max.then it will works. Step 2: By default DHCP enabled and IP will assigned to your computer and all connected devices. Step:3 First time you have to login with comcast website it may computer or laptop or any other device
Simply copy the WAN configurations from your laptop to your netbook WAN settings
Dec 22, 2010 | ASUS Eee PC 1000HE Netbook
Netgear MGT624: My netbook shows its connected to my router but
Re4place your Wireless Access code as set up with router control program. Often wireless access is denied when mistakes are made with this pass code. Just replace whatever code you have with another (simpler?) code or even going to "None" for Security. To try and establish comm through the router, if it succeeds with no security try again with perhaps WPA-[TKIP] coding.
Dec 12, 2009 | NetGear WGT624 Wireless Router
I have a NETGEAR wire/wireless router MBR624GU. My internet provider is Comcast using a high speed internet modem by Ambit model U10C018. I connected the Comcast modem to Router LAN port using a Ethernet...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 10, 2009 | NetGear MBR624GU Wireless Router
I'm trying to connect a netgear wpn 824 to a comcast router with windows 7
You are trying to set up the wireless router with the comcast modem, right ?
You can set up the router manually , without the disc.
Make sure that your computer is able to go online when connected to the comcast modem only.
If you have the router working already then you just need to add a computer to the network.
Click Here for step by step solution
Oct 27, 2009 | NetGear RangeMax WPN824 Router
Netgear wgt624 just stopped connecting to internet
I encountered the same problem, with the same modem and also Comcast, and here's what wound up working for me, after time spent with a nice guy on the Netgear customer support line:
1. Log into router: http://192.168.0.1 (or 192.168.1.1) - user: admin / password: password
2. Under Maintenance, click Router Status. If IP Address is listed as 0.0.0.0, there's your problem-- router isn't getting address from modem.
3. At bottom of Basic Settings, under Router MAC Address, change selection from Use Default Address to Use Computer MAC Address.
4. Click Apply.
5. Click Router Status again-- non-blank IP address should now be listed.
6. Basic Settings will now show MAC address under Use This MAC Address. See if you can get online now. I could, and I hope you can, too!
Dec 04, 2008 | NetGear WGT624 Wireless Router
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Sylvania G-Netbook Logo
60 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
