Question about Whirlpool Duet GHW9150P Front Load Washer
Psyco whirlpool duet washer
Have been having problem with F11 error,but yesterday it just died, no lights,nothing. I reseated all connections and finally got the control lock light on, but can't get it to work still.
I held the cycle button down as instructed but it still won't work. The door will open and shut. Any suggestions would be greatly appreciated, Thanks
  • ivgjag Aug 16, 2008
    the washer will give me an F error before the rinse cycle starts.
    After manuevering through the buttons I got an error code with a number and a letter such as 3 H. What is going on?
  • 725 Answers
F!! ERROR
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires shouldshould be to the left when facing the MCU connectors.
Posted on Aug 16, 2008
SOURCE:
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    F11 and/or dl code on a whirlpool duet front load washer
    F11 is:
    Serial Communication Error
    Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
    Check for:
    Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
    Check the Drive system for any worn or failed components
    Check MCU
    Check CCU
    Check Motor
    Check Wire Harness
    http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
    Check the above link for a detailed article about the f11 error code.
    Courtesy:JSrock
    Apr 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    What does F11 error code mean on a whirlpool washing machine?
    This code indicates a serial communication error, meaning communication between the central control unit (ccu) and the motor control unit (mcu) cannot be sent correctly. Check the wiring harness connections at the CCU and the MCU. Unplug and reseat and make sure there is no corrosion. It can also indicate a problem with the door lock relay on the control board, a faulty hall sensor, or the mcu or ccu themselves. I think that I'd recommend getting an appliance tech to take a look at it, but try the unplug/reseat electrical connections fix first. Very sorry for your trouble. Hope this helped and best wishes.
    Sep 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Error code displayed on duet washer.
    Pull off the front bottom panel and check your service sheet to verify error codes. You probably have a bad door switch.
    Aug 19, 2009 | Whirlpool Duet WFW9550 Washer
    Washer stops with F and then 11 error message
    F11 is usually a generic code that indicates a communication error between the central control unit and the motor control unit. The first thing I would do is check the connection at the control board. A common problem is the connection jiggling loose. Unplug and reseat the plug and check for any corrosion which is the enemy of good electrical connections. Hope this helped and best wishes.
    Aug 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    NEW CCU for Whirlpool Washer
    I found this site, they actually repair the CCU for you. Mainly for the F11 Error Code. I see on the site that they have repaired 95 of them with 100% feedback.
    http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2#ht_2034wt_1165
    Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Older whirlpool duet washer has error F11
    F11 is a serial communication error between the central control unit and the motor control unit.
    Unplug the machine and open the panels.
    Unplug and re-plug all wire connectors from the ccu to the mcu.
    Inspect all wires and harnesses for a bad wire.
    Could be bad components; ccu or mcu or motor
    Feb 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool duet wahsher
    The following list of codes indicates an electronics communication problem with the washer:
    Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
    Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
    Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
    PLACEHOLDER FOR ART
    To remove the error display, press Pause/Cancel twice.
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    2. Plug in washer or reconnect power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, then call for service.
    please do not forget to rate and comment about your experience with fixya today.
    Aug 18, 2008 | Whirlpool Washing Machines
    Whirlpool Duet Washer GHW9150PWO Have F11 and DL errors. Have replaced the door lock 2 x and still have same error messages.
    Well du is a door lock error but it can also mean an error with communication to the main control board or ccu. f11 is also a communication error in either the ccu or the mcu ( motor control board)......easiest thing to try is to unplug all your connections to the ccu and plug them back in and try it again.....sometimes a wire harness just may be loose....if that dosent work I would look at replacing the ccu ( central control unit )
    Jul 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    F 11 code
    check the connections between the main control board and the motor control board, make sure that the connections are tight, might bee good to remove the blue and black wired terminals and reseat them if you still have an issue then one of the boards will be bad
    Apr 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    64 people viewed this question
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
    jimorris77
