Question about Naxa Electronics NDL431 Theater System
Why my naxa ndl-431 power button is blinking?
How do you set and turn clock display on naxa nx667
Naxa Electronics NX-667 Clock setting - Questions - Fixya
www.fixya.com > ... > Naxa Electronics > Naxa Electronics NX-667
Naxa Electronics NX-667, clock setting related issues. ... set up the clock time 1: press Source button to turn off unit 2: press Clock button to display clock 3: press ...
Naxa Electronics NX-667 Kd s35 manual - Questions - Fixya
...kd-s35 Press and hold SEL button. Press ^ button 3 times to display H (hour) turnvolume knob to change hour setting, press down 1 time to select M (minute) ...
General FAQs - Naxa.com
Dec 12, 2015 | Car Audio & Video
Power lite flashing red
It's a signal for low battery or any notification on whats app or other app.
Aug 17, 2014 | Naxa Ndl-431 7-inch Motorized Dvd Micro...
My acer aspire v5-431 won't power on what do I do?
1. remove the battery and try AC only
2. Is the AC power supply warm?
3. Is the power light on but the computer is unresponsive?
1. Battery may have a short stopping the laptop from booting, replace the battery.
2. The AC power supply may be defective or the connector on the laptop is broken, replace the power supply/take the laptop to a shop.
3. The laptop may be in Sleep/Hibernate mode, press and hold the power button for up to a minute.
If nothing happens/is fixed at this point, Warranty/replace/take it to a shop
Apr 12, 2014 | Acer Aspire ASV5-431, V5-431 Charger,...
I have an "naxa tv" and I really need the code for
  1. Turn on the component to be programmed.
  2. On the remote control, press and hold the S button.
  3. While holding the S button, press and release the POWER button
  4. Release the S button.
  5. Press and release the appropriate component button for the component being set up.
  6. While pointing the remote control at the component, press and release the CH + button.
  7. Press and release the POWER button.
  8. NOTE: Repeat the previous two steps until the component responds. It may take 70 tries until the correct code is located.
  9. When the component responds, press the ENT button.
Jun 03, 2011 | Sony RM-V202 Remote Control
Need a NAXA remote code for dish network Remote
Hopefully you have resolved this issue, but if you have any additional problems or questions, here is some help. Follow the directions below, and that remote will be programmed right away.
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
Jun 16, 2010 | Naxa Electronics NX-556 19 in. LCD TV
How to change the volume on my naxa nx 144 mp3 player
You can change the volume of your naxa nx 144 video player by;
1.Pressing and then holding down the VOL Button for about four to five seconds
2.After you do that you will see the number near the center of the bottom of the screen on the player's screen start to blink or flash.
3.When it is still flashing press the |<< O >>| or what some people including myself call the Rewind or Fast Forward buttons until the number that is still flashing on the bottom of the screen is a diffirent number then when it was when it started flashing earlier.
4. After you change the still flashing number for the player's volume until you get it as loud or as quiet as you desire repeat the first step by holding down the VOL Button once again for about four or five seconds and....v`iola it should be adjusted to your liking now.
Oh yeah before I forget here is a friendly word of advice for you. DO NOT FORGET and leave the volume on real loud and then play your song,video or,ect. before turning you volume back down because it will be REALLY LOUD and REALLY PAINFUL ON YOU EARS.
Thank You and I hope this helps for you.
May 14, 2010 | Audio Players & Recorders
I HAVE A NAXA NX-671 AND CAN'T FIGURE OUT HOW TO SET THE CLOCK
I got a 671 from jujudeals.com and the exact same thing happened. When I talked to them, they said to first, go into clock mode. While you're in clock mode, press and hold select (SEL). Still holding select, use the Fast Forward and Reverse buttons to change the time. FF will change the hour, REV will change the minute. Hope that helps, and if not, you can contact the Naxa support people at this page:
http://www.naxa.com/newsite/support.html
Mar 04, 2010 | Naxa Electronics NX-671 Car CD/ MP3 Player
My naxa mp3 player
Mine used to do that. My sugestion is to plug it into the computer. when you do that it starts to charge. I think that the problem is that it has a low battery. That is what was the problem with mine.
Sep 17, 2007 | GPS
Naxa Electronics NDL431 Theater System Logo
80 people viewed this question
Top Naxa Electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Naxa Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
