Question about Mitsubishi CS-35503 TV
1991 CS3515R has vertical instability. (picture often flips vertically. Seems worse when there is more light color on the screen. I remember old sets that had horrizontal and vertical stability controls. This does not. Anything I can do that would be cost effective? Otherwise it gets a beautiful picture.
  • howschwart May 18, 2011
    Does this set have a vertical stability control knob? You mentioned one. Is it inside the TV? If so where is it. Is this something I can get to without killing myself? Otherwise, how mich would i have to pay someone to fix the electronic problem you mentioned? Are the parts needed available? Is this worth doing? Or should I junk the set if there is no "Knob" inside that can fix the problem. Thanks.
  • 4,889 Answers
By stability control do you mean the V-hold knob inside the tv? If not then the only way to fix this is to find the source of the fault in the deflection circuits. Be wary that this is a high voltage circuit and should not be handled unless you have prior experience in working on electronics. The HOT probably needs to be replaced as this is the most common cause of the problem and it requires soldering skills too.
Posted on May 18, 2011
  • eagle338
    eagle338 May 18, 2011
    I am not sure your tv has one. Since the tv is pretty old I cannot find a service manual. However you can turn off the tv and carefully remove the back cover and just LOOK for a two knobs . One will be marked V-hold and other H-Hold. It will be near the on a board on the chassis not on the CRT tube(avoid the tube it is the most dangerous part in a CRT tv). If you can't find one you will have to test the horizontal and vertical output transistors and replace them if necessary. A tech should do this for you for about 100-150$
Blue line
This usually happens when there is a defective CCD unit, This is the part that looks at the image and sends the signals to the cameras electronic systems. the unit has failed and will need to be replaced.
Jan 21, 2013 | Canon PowerShot SX130 IS Digital Camera
Picture problems
There is a problem with the vertical circuit. Eventually th foldover will get worse. If you are comfortable working inside the set, with a little investigation, you should be able to resolve this yourself. If you would like to attempt the repair, update this and I'll provide additional details and instructions. Realize that this will take a few interactions to locate the defective part.
Dan
Jan 29, 2009 | Televison & Video
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
May 22, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Magnavox 25inch TV picture problem
That's a vertical deflection problem and is probably caused by a capacitor going bad in the vertical stages or the power supply stages that supply the vertical IC . And you're right, as the cap dries out more, it'll only get worse.
There is a company called PTS Electronics that rebuilds main boards and sells them on an exchange basis. You might check into that, but you really need to have a little knowledge about that stuff to install a main PCB.
You'll need the part number off the board.
Hope that helps...
Geno
Apr 03, 2008 | Televison & Video
Vertical hold adjustment
Loss of vertical sync or any other problem with your Mits is
likely caused by bad power supply capacitors....they are made by Rubicon and are notorious "leakers"......very tedious and
expensive to fix...................good set back in the day.......T.
Mar 10, 2008 | Televison & Video
Vertical lines on one half the screen
Sounds like Light engine sizzle noise makes me think color wheel.
Nov 18, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Picture shows only about a 2-3" blue,green,or red vertical line down the middle
If your seeing vertical line across the screen you need to check the components in the vertical stage as well as the vertical IC could be bad, or the yoke could open.
Also check if any voltage reaching the vertical stage.
Good luck.
Was this help full.
Oct 31, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Picture flipping
The P52940 uses the 195 series chassis. The vert/hgt control is for vertical height. It adjusts the size of the picture from top to bottom. If your picture is flipping, it most likely means that something is wrong in the vertical circuits. I have seen fluid leak out of one of the CRTs and drip down on the vertical output IC, causeing the picture to go crazy vertically. The set should be serviced by a qualified tech experienced in the RCA 195 chassis.
Aug 18, 2007 | RCA P52940 52" Rear Projection Television
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Televison & Video Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
