Question about Parrot Par Ck3000 Evolution Ck3000 Handsfree Car
Just installed CK3000 along with BLU-GM29 to control on steering controls,,works great except CANNOT use or transfer CONTACTS, what is wrong and who has the FIX. Is it Apple or Parrot?
SOURCE: Parrot CK3000 Evolution
I fixed it myself :) All I did was press the green & red buttons together a couple of times to erase the memory and then I paired my phone to it again and it worked. All this stress and the solution was as simple as this lol.
Posted on Aug 16, 2008
SOURCE: My Nokio E52 'sees' the CK3000 Evol parrot, but will not connect.
Switched on the E52 the blue tooth option External SIM Modus to On and kept on trying. And then finally the phone asked for accepting the arrot connection. Entered 1234 and it worked.
Posted on Oct 13, 2009
dancandoit
  • 436 Answers
SOURCE: My Parrot ck3000 does not pair with nokia N97... I
Press and hold the red and green button to reset all prvious paired devices, then try again.
Posted on Feb 08, 2010
  • 21 Answers
SOURCE: pairing nokia n96 with parrot ck3000
Try sending an MP3 to the Parrot kit. I couldn't even get the Parrot BT in my car to ask for the BT password numbers but found out to try sending an MP3, which will fail by the way, and it asked for the password finally.
There was an error in my case, but then the phone asked to connect to the Parrot again and the pairing worked.
There is an issue with newer Nokia phones, something I will be thinking about next phone upgrade.
Posted on May 11, 2010
  • 21 Answers
SOURCE: connecting my new phone nokia n96.to parrot ck3000.
Posted on May 12, 2010
I have a parrot ck3000, but i dont know how to erase the memory using only the steering wheel contols. i have tried to hold the call and answer buttons simultaneously but it does nothing, i have tried with...
You will need to plug in the original parrot control to do this. contact the supplier if you do not have it as they should have left it with you. Otherwise Parrot web site has a list of certified engineers.
Feb 19, 2011 | Parrot Par Ck3000 Evolution Ck3000...
Horn does not work on a 1993 cutlass ciera
Try to find the horn and use a test light to try to ground out one or the other contacts. The horn should be energized at all times, as long as the battery is charged.
The horn should sound if you ground out one or the other terminal with a test light. If not, then the horn is bad.
Also, one can check the button at the steering wheel. If one uses a test light to ground out the switch there, the horn should sound.
See fig. 3 for wire for horn in steering wheel:
REMOVAL & INSTALLATION
Without Air Bag
See Figures 1, 2, 3, 4, 5, 6, 7 and 8
Disconnect the battery ground cable before removing the steering wheel. When installing a steering wheel, always make sure that the turn signal lever is in the neutral position.
  1. Disconnect the negative battery cable.
  2. If your vehicle is equipped with controls for the radio on the steering wheel proceed as follows:
Fig. Fig. 1: Pry out the control button assembly with a thin-bladed tool along the top of the edge, being careful not to damage the control assembly
  1. Pry out the control button assembly with a thin bladed tool along the top of the edge of the assembly.
  2. Disconnect the steering wheel control.
  1. On vehicles without the radio controls on the steering pad, take a thin-bladed tool and pry the pad off the steering wheel. On wheels with a center cap, pull off the cap.
Fig. Fig. 2: Common steering wheel pad types
  1. After lifting the trim off, pry the horn wires from the back of the pad. On some models gently push down on the horn lead and turn left, the wire and spring will then come out of the canceling cam tower.
Fig. Fig. 3: Carefully pry the lead wire for the horn off of the horn pad
  1. Remove the retainer ring with a pair of ring expanders, then remove the steering wheel nut.
Nov 19, 2010 | Oldsmobile Cutlass Ciera Cars & Trucks
Parrot CK3000(v5.10C) initating voice dial radio doesn't shut off
I would update the software to the latest version, 5.23 this should cure any pairing problems. The volume can not be increased any more.
Jun 02, 2010 | Parrot Par Ck3000 Evolution Ck3000...
My phone conects with my ck3000 but i have to keep pressing the green switch to hear the call
My parrot CK3100 conects to my phone but keeps saying memory full when i try to transfer phonebook
Feb 06, 2010 | Parrot Par Ck3000 Evolution Ck3000...
Have a 1996 crown vic and the horn did work now it doesnt work along with the cruise control my fuese under the dash are good but not mark
If the horn nor the steering wheel mounted cruise control switches work, it is likely that the problem is the contacts that are in the steering wheel and the steering column that send the signal for these switches. You have a circular type contact that rotates with your wheel, and a stationary circular contact on you steering column that the steering wheel fits over. Good Luck. I hope you find this very helpful!
Nov 27, 2009 | 1996 Ford Crown Victoria
Oct 12, 2009 | Parrot Par Ck3000 Evolution Ck3000...
Blackberry 8110 contact transferring to Parrot CK3000
make sure you are just transferring contacts with phone numbers and nothing else (email addresses et. etc. ) also make sure the area code is included(even on local ones) take the parrot's battery out for about three minutes, do the same to the blackberry) should fix....enjoy
Jul 26, 2009 | Parrot Par Ck3000 Evolution Ck3000...
after a reset try to push the parrot in pairing with your phone.< for any G3 phone the below should work. The menu could be differnet on yours this is for a nokia G3 phone. Object Push: * From your phone go to MENU / COMMUNIC. / CONTACTS * Select the desired contact to send * Go to OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH / ALL CONTACT DATA * Phone will search for available bluetooth devices * Select from the list Parrot Product and press SELECT * wait until the contact is transferred. After contact is sent, it is neccessary to register "Contact's Name"
Aug 14, 2008 | Parrot Par Ck3000 Evolution Ck3000...
Parrot Par Ck3000 Evolution Ck3000 Handsfree Car Logo
Top Parrot Cell Phones Experts
Andrew Wright
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
