Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwaser I have Bosch 5306 dishwasher, the display has H2 that comes on when sycle starts.
  • 2,071 Answers
WHAT IS WRONG WITH YOUR DISHWASHER?
Bosch dishwaser - small_9_26.jpg For a detailed Dishwasher illustration, click below.
Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Hope this may help;
DON'T FORGET TO RATE;
Posted on Aug 22, 2008
Need a bosch manual sgs45e08gb for dishwaser
Hi -
Please click the link below to download the user manual for the Bosch SGS45E08GB dishwasher.
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=ockqjpccdcso0mchdb---n5y&UMOBID=ockqjrbcdcso0mchdb---n5y
You will need to have Adobe Reader or another PDF file viewer installed on your PC to view the manual:
http://get.adobe.com/uk/reader/
If you need assistance with your Bosch dishwasher, please let me know.
Regards,
BElectric
Oct 19, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Delayed start says H2 won't stop running...please advise!
Hello, Welcome to FixYa. On Bosch dishwashers with display such as yours the 2H indicates the cycle wash time is exceeding two hours and it should not. This is typical of a heating error so the cause must be determined. The question must be asked, is it a heater, a flow switch, an NTC or the actual control ? I can also tell you most times it is the control. I am presently on my iphone and as such don't have access to my files but if you check out my profile under dishwashers you will find a detailed explaination of how the check. Look specifically for units that show "1" and run & run. You will also find a link to the Bosch website on info regarding a recall which relates directly to your model and said issue. Otherwise I will post more info for you in the AM . Regards, Macmarkus :)
Mar 07, 2011 | Bosch SHU5316UC Dishwasher
How to add and subtract rational expressions? 8/x-4 2x/4 y - 1
hi ihave a bosch dishwaser that has been stood for a while its working going through the programs ok but its not washing pots properly any ideas please
Aug 29, 2010 | Bosch Dishwashers
My bosch dishwasher takes 4-5 hours to finish the sycle, what is the problem
the last time i checked a bosch unit with that problem i replaced the module .it was bad. replace and that will solve the problem. let me know what happened.
Dec 22, 2009 | Bosch SHU3036UC Dishwasher
Hi my bosh dishwaser wont fill with water
check dicharge hose needs to be 3/4 high on dishwasher about 18 in above floor
Sep 11, 2009 | Bosch Dishwashers
Dishwasher will not drain
MY BOSCH EXXCEL DISHWASER WONT DRAIN?
Dec 17, 2008 | Dishwashers
Shu43 built in dishwasher
Running the hot water in the sink until you get the water hot then, make shore you are using jet dry. Bosh dishwasher dry with condensation. Let me know
Aug 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwaser is stuck in Rinse/Dry cycle
It could be a sensor or timer solenoid in the dishwasher maybe broken and needs replacing.
http://www.repairclinic.com/bosch-dishwasher-parts-gg.htm
Apr 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwaser
need to look at operating booklet and see what F stands for.then rectify it.
Oct 05, 2007 | Bosch 24 in. SHE56C05UC Stainless Steel...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
307 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
