Question about Merit Fitness 725T Treadmill
I've lost the emergency stop magnet thing... where can i get a new one?
Sole treadmill says "INITIAL" on the screen and won't run. This occurred after I removed the magnetic emergency stop switch.
Normally you must put the key in the hole, after you press the button start and ready.
However I recommend you to follow the instr. manual for easy start. Since that every manufacturer has a little diferrent mode of start. If you do not have it download free from
www.fitness.manualsonline.com
God bless you
Dec 17, 2012 | RTO Sole Fitness Package F85 Treadmill &...
Emergency fuel shutoff location
If it is an emergency, ask a firefighter. Check the manual to see if there is such a valve. I'm not an expert mechanic but I've seen a few sunrises and I have seen manual shutoff valves on motorcycles, I've never used one on an automobile.
Google 'hyundai accent fuel shutoff valve'
Sep 13, 2012 | Hyundai Accent Cars & Trucks
Proform 405 CE Elliptical display and Silent Magnetic Resistance control stopped working
1) adjust magnet with the bolt looses with a wrench, tight very well.
2) proof the magnet for attraction or repulsion with the magnet from your refrigerator, if NOT pass the test replace it.
God bless you
Jul 24, 2012 | Exercise & Fitness
Putting in new coil
i rotate the flywheel to the magnet the place a piece of a brown paper bag between the coil and the magnet
May 12, 2012 | Garden
WOODWAY "replace magnetic key SAFETY"
Yes, it is likely that it is the switch directly underneath the magnet - it may be possible to bypass it, but not a good idea. You can order a switch direct from Woodway 1800WOODWAY
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Mar 18, 2012 | Exercise & Fitness
1991 honda accord lx... i was driving it and it just stopped running,no prior performance problems,it seems it ran out of spark. i've got a new coil and checked electrical....i'm lost
not sure if it is the same thing that happened to mine but I have to replace the main relay, located under the dash. I was told the two main things that go wrong with our honda's is either the coil or the main relay. My coil was fine. Hope that helps you.
Have you ever had issues with your battery light flickering while braking, by chance? this is my other issue. I have replaced the alternator but still doing it. :) thanks.
Aug 01, 2011 | 1991 Honda Accord
My Bowman treadmill 7 series stopped working. It just shows 2 words: safe out. Please help.
Make sure the magnetic safety key ('safety pull' or 'emergency stop magnet') is in place. SAFE OUT indicates that the safety key is not in position or is otherwise not working properly.
For more information consult the following manuals:
http://download.dfxi.com/supportdocs/OM/Bowflex/BFX_TM3-5-7_OM_RevD_web.pdf
http://www.pdfstock.com/bowflex-3-5-7-series-treadmills-assembly-manual-pdf.html
May 05, 2011 | Bowflex Treadmill Series 7
Merit Fitness 725T Treadmill Logo
152 people viewed this question
Top Merit Exercise & Fitness Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Merit Exercise and Fitnes Expert? Answer questions, earn points and help others
