Question about Cub Cadet Garden
I have an LT 1045 (2007) and one of the heavy gauged seat springs broke in half. I need a part number to order a replacement. Any help????
Apllied park brake and a spring broke, need manual, part number, schematic to reinstall
Manual can be gotten in electronic form from sears at the searspartsdirect.com website (linked at end of post), where you can download manuals for lots of appliances, tools, etc. Flip up your tractor's seat and look for the model number sticker, should be near the battery if battery is under seat. You will need the model number (model, not serial) to find the right publications. When new, the tractor probably came with an owners manual and a parts manual.
Alternative: get your model number, google it and the term "parts manual," and you will probably get right to the info at several websites.
Amazon is a possible parts source, with some decent vendors and prices; I've ordered several repair parts for my 2009 YTS 3000, which is technically a model 917.289210. That should be the pattern for Craftsman model number: three digit number probably starting with nine, decimal point, six digit number. Note that my owners manual has a typo and omits last character of model number. Watch out for such printing errors; you might be actually looking at the correct publication but it's mismarked. Be sure to save a PDF copy of the manuals so you'll have them later. Craftsman Riding Mower Tractor Parts Repair Parts Sears PartsDirect
As for assembly, the parts views will be some help. Once you get the new part it might be pretty obvious. For example, there might only be one hole or hook relativley close by that other end of spring could attach to. In general, all the "parking brake" does is hold the foot brake pedal down in the applied postion, not much different from jamming pedal with a stick (no I do not recommend this method). Unfortunately, due to safety interlocks, you need the parking brake to work if you want to leave the seat while tractor is running, as you've probably discovered.
Jan 17, 2016 | Craftsman PYT 9000 26 HP 48" Yard Tractor
How to fix at reclining mecanism
Should only be 4 bolts holding it in ?, If You have the tools toremove lube up the frame , but be very careful about the recliner , usually a heavy duty Tension spring could get dangerous if you mess with it ! any Uposery shop should be able to fix it
Jun 06, 2014 | 2010 Chevrolet Chevrolet Malibu LT
Spring mechanism is broke. As a result, door is quite heavy and falls open quite easy.
If you need to replace the spring mechanism, go to Sears's website and access the parts direct section. Here you can enter your make and model. It will show you a cutsheet with part names and numbers. Order the parts you need from there.
Sep 04, 2011 | Hotpoint 23 in. BF41 Built-in Dishwasher
Fuel gauge reading half with full tank on 1997 Mitsubishi Mirage
It is a fuel gauge sensor also known as the level sensor, There is a level sensor that has a boot spring attached to it that is probraly jammed, or just simply damaged. This will need to be replaced, you can located this at your fuel pump, which in normal case is underneath you rear seat in which side is your fuel door is located. Once you located the opening of the fuel pump passage then there is normally 6-8 small bolt that is screwed to hold your fuel pump to the fuel tank and some cable harness. Theses will need to be taken off in order for you to take your fuel pump. In my best advice, you minus well replace your whole fuel pump system to save time and complication when installing
Jan 21, 2011 | 1997 Mitsubishi Mirage
I opened teh door and thought i felt something hit
Murray, It sounds like one of the door springs has broken and that is why the door seems heavier and opens with much more force.
You'll want to at least make a temporary repair and order a new replacment spring to get your dishwasher working like it should and so it's safer too.
You can check to see which side of the dishwasher the spring broke, by locking the door shut (with the cycle set to "off"). Now remove the lower access panel, beneath the main dishwasher door. There are a couple of screws near the top corner edges of the panel, just under the main door and a couple more on the toe kick near the very bottom.
Once you've got the lower access panel off, you'll be able to see the two door springs, (there is one on each side). Of course, the broken one might have fallen off the spring notches, so look around and you should see it.
With the door still closed and locked, you can remove the broken spring and see if it's just the hook end that broke. If that's the case, you can reform the end hook using a couple pairs of pliers and reinstall the spring on the door and frame mounting points. You'll have to use pliers to stretch the spring slightly to get it on the other mounting point, once you've got one end on a mounting point. If the spring broke off more than 3 coils, you'll need to replace it with a new one.
You can find a replacement by using searspartsdirect.com and putting in your model number to locate a line drawing and parts listing for your particular model. You can also order a new one from them, or use the part number to get one locally, if you wish.
Once you've got the spring back on the door and cabinet mount points, you can unlock the door and gently lower the door to see if everything is working properly. Once you've opened and closed the door several times, you can reinstall the lower access panel and you're back in business.
I hope you find this Very Helpful and best regards!
Oct 24, 2009 | KitchenAid Dishwashers
GE GSD900L-02 Door spring cable broke
Get 2 of the same springs part # PS259673
DOOR SPRING (YELLOW) (Heavy Duty Door Spring)
Sep 12, 2009 | GE Dishwashers
Door spring broke
What is the model number? If you go to this website, you can see what part to order and how much.
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
Jul 30, 2009 | KitchenAid Dishwashers
Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Mar 26, 2009 | KitchenAid Microwave Ovens
Broken Spring/Shock for my GLEQ642AS0 Fridigaire Dryer
there are no "suspension shocks/springs" on a dryer, those are usually on your washer. here is hte par number for he washer spring 134144700(which is about 8 inches long and 3/4" in diameter made of heavy gauge steel) youll need (2) and heres the suspension shock absorber number 134564200 its a set of 2, there shold only be 2 on your machine.
Dec 11, 2008 | Frigidaire Dryers
Parts for Mcculloch MC 1275 steam cleaner
You can find your parts on amazon. take a look here Amazon com Mcculloch MC 1275 parts. I hope this was helpful. cheers
Nov 15, 2008 | McCulloch MC1275 Steam Vacuum
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
