Question about Toro Super Recycler Super Bagger Lawn Mower Rear Bagger 5
How do I raise and lower the blade - Toro Super Recycler Super Bagger Lawn Mower Rear Bagger 5
  • 577 Answers
Each wheel has an adjuster on it Usually A is lowest setting and E is highest setting
Posted on May 18, 2011
How to correctly put on the belt that raises and lowers blade on a 2004 Dixie Chopped 72in xt3200
I don't recall a belt that raises and lowers the blade. Normally you would have either an electric or mechanical deck lift that raises and lowers the whole deck
Jul 04, 2014 | Garden
Blade on table saw will not raise
typically this is a thrust washer issue. need to look at the play between raise and lower..also ensure trunion is cleaned and lubed.
Dec 27, 2013 | Bosch Power Tools Bosch 4100-09 Worksite...
What s the ideal setting for the blade control; raise and lower
What are you talking about? Is it GPS , a lawnmower or a hair clipper?
Nov 07, 2013 | GPS
Troy bilt lawn mower
sounds like wrong belt you raise it belts tighter lower belts looser or the tensioner has come loose
Jul 13, 2013 | Garden
How to raise and lower saw blade
You raise and lower the table plate, NOT the blade. There is a knob to lossen and tighen the tension on the table plate and you can adjust the blade height by lowering the plate and vice versa.
Jun 20, 2011 | Dewalt DW364 7 - 1/4'' Heavy Duty circular...
I cannot easily raise/lower my blade on my Craftsman 10 inch table. I've cleaned out the say thouroughly and nothing appears to be obstructing mechanism to raise/lower the blade, but yet, it takes two...
mine did the same and i sprayed WD-40 on the assemblys or large screws and keep working it until free. but, check things over because some had a lock so the blade wont move after the hieght is set.
Dec 19, 2010 | Craftsman 10" Table Saw
Can't find my owners manual. How do I change the blade. Bolt hits on a guard that covers the arbor. On a DW713 combination saw.
Removing the Blade
1. Unplug the saw.
2. Raise the arm to the upper position and raise the lower guard as far as possible.
3. Loosen, but do not remove guard bracket screw until the bracket can be raised far
enough to access the blade screw. Lower guard will remain raised due to the position
of the guard bracket screw.
4. Depress the spindle lock button (Fig. 3) while carefully rotating the saw blade by hand
until the lock engages
5. Keeping the button depressed, use the other hand and
the wrench provided to loosen the blade screw. (Turn
clockwise, left-hand threads.)
6. Remove the blade screw, outer blade clamp, and
blade. The inner blade clamp may be left on the
spindle.
Installing a Blade
1. Unplug the saw.
2. With the arm raised, the lower guard held open and the
guard bracket, place the blade on the spindle against
the inner blade clamp with the teeth at the bottom of
the blade pointing toward the back of the saw.
3. Assemble the outer blade clamp onto the spindle.
4. Install the blade screw and, engaging the spindle lock,
tighten the screw firmly with wrench provided. (Turn
counterclockwise, left-hand threads.)
5. Return the guard bracket to its original position and
firmly tighten the guard bracket screw to hold bracket
in place.
WARNING:
• The guard bracket must be returned
to its original position and the
screw tightened before activating
the saw.
• Failure to do so may allow the guard
to contact the spinning saw blade
resulting in damage to the saw and
severe personal injury
you can download a manual at: http://www.dewalt.com/tools/machinery-miter-saws-dw713.aspx
Jul 20, 2010 | Garden
Raising and lowering the blade is really tight.
what I do is turn it over and using compressed air blow out as much of the dust as you can and then find a dry silicone type lubricant to thoroughly spray the threads and the slide portion of the saw. let dry and then move blade up and down a few times, you might have to repeat this but it works.
May 23, 2010 | Dewalt DW744X 10" Portable Table Saw
Lokking to raise blade heigth. Is there something
they are 2 nuts that raise and lower deck one on each side turn up to raise it,, hope this help,, good luck
Aug 08, 2009 | Garden
Toro Super Recycler Super Bagger Lawn Mower Rear Bagger  5 Logo
126 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
